BX23 Noise Question
/ BX23 Noise Question #1
timswi
Super Member
Beaver County Pa
Kubota BX23 TLB, Kubota RTV1100, Kubota Z724 & Polaris RZR 900 Trail
My BX makes a clicking noise (sounds like a few pieces of gravel hitting the mower deck) for the first 30 seconds of run time when it's cold...After that the noise is gone...Doesn't seem to be valves and it sounds like it's coming from the front of the engine...The air filter bracket is fine adn everything seems tight....Muffler maybe....
Any suggestions or experiences...BTW 330 hours on the clock and fully maintained.
/ BX23 Noise Question #2
I was thinking muffler too. Clicking noise as it warms up. I've not noticed mine making any similar noises. Mine is at 525 hours.
/ BX23 Noise Question #3
X2...likely exhaust expanding as heats up. Retorquing might fix...
Thanks...That was what I what thinking...It runs perfect otherwise. Other opinions?
/ BX23 Noise Question #5
If it is the exhaust /muffler, just tune it out of your mind, it doesn't matter. :)
/ BX23 Noise Question #6
Inadequate oil flow to a certain part of the engine will make similar noises also(usuallly a lifter). Working carefully due to moving parts, you can use a hose or a stethoscope to locate the noise.
/ BX23 Noise Question #7
Mine has always done that since new...Sounds more like metal parts rattling around in the engine compartment. I just figured it was normal...
That's what mine sounds like...it just started doing it this year...
2012 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2012 Caterpillar...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2019 Ford F-150...
2018 Ford Mustang GT Premium Coupe (A64557)
2018 Ford Mustang...
2005 Acura RSX Coupe (A64557)
2005 Acura RSX...
2011 FORD F-350 FLATBED DUMP TRUCK (A64278)
2011 FORD F-350...
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
