1026r mower question
/ 1026r mower question #41
This is without a doubt a DEALER problem. The machine was delivered not working properly - now the dealer does not "know where to turn"? How many AutoConnect mowers has this dealer sold / delivered? We have almost thirty "1" Series out of my location alone - and yes we had some issues with the first few - but none of them left before they were working properly. Dont blame Deere when the dealer is the problem.
/ 1026r mower question #42
Hey jdphan why would you say that. When dealer drop it off at my house it would not latch after install deck. So saying john deere trained guy is manlfunction.You are wrong. How about tractor it self is malfunction.You drive over deck it should latch itself.If it don't its john deere problem.
This is a dealer issue not a mfg issue. The mfg is NOT reading this thread so you are really wasting your time if you think they will contact you because of your posts here. Nobody is saying the tech is stupid, maybe not trained properly or as mentioned above the dealer has little experience with this style of deck. There really are too many of these out there functioning very well as Bleed Green mentions. Here is my super arrogant opinion... The dealer is blowing you off because you are a complete (insert). I could be wrong but can't seem to figure out what you are after by repeating over and over that it is mfg. You may find that you will need to contact Deere directly which is pretty easy to do, and if you get a review sheet fill it in accordingly. Otherwise just keep on posting the same thing repeatedly as it appears to be resolving your issue;).
/ 1026r mower question #43
Sorry, I know I am not fixing anything here but could not help myself.
/ 1026r mower question #44
Hope your dealer is taking care of your problem. Ordered my 1026r ,dealer asked me if I wanted auto connect mower ,told her no way.. She told me they work like a charm and have had no problems. I told her of the troubles I read here and other sites about auto connect and just wasn't going to try my luck that I was still able to get down and connect pto myself. Told me no problem would order 7 iron deck regular hookup. Hoping to have mower at dealership 11th or 12th..
/ 1026r mower question #45
I did just the opposite. I would not own a 1026R if it were not for the auto connect deck. I have had zero trouble with mine so far.
bleedgreen that did you to repair the ones you did have problems with.I heard on net some where bending arms drilling bigger holes.If need to bend arms make bigger holes .I would say that is problem with john deere?
bleengreen what do i need to parts remove hydraulic lift and make it mechanical lift?
/ 1026r mower question #48
Ask your dealer. If it were me I'd install a diverter valve and eliminate the quick connect fitting swapping.
/ 1026r mower question #49
WOW !! Maybe, while your learning about the proper setup for your tractor and mower deck here at tractorbynet you could spend a little time learning how to type in more complete sentences so we can all understand your problem better.
Wow. A little harsh, huh? Hey, as long as we're pointing fingers, you made a "your/you're" error. Some people don't speak English as a first language. Is that the kind of welcome you want to give them? I understood his question just fine.
/ 1026r mower question #50
You know this tractor was suppose to be released like 4-6 months earlier than it did. Was this deck issue part of the problem or was it something else?
/ 1026r mower question #51
Popular rumor said it was a front axle casting issue.
/ 1026r mower question #52
Dp.........
/ 1026r mower question #53
In the post you qouted, I can't find how "your" is used incorrectly.
/ 1026r mower question #54
mrBardwelliscorrectitshouldbeyou'reasinyouaremycongratulationsgotohimforfindingitittookawhilebutsomeonedidfinditnonthelessadditionallyicouldhaveskippedthewordmorebuthopefullyevenwiththeblundersitappearsasthoughhegotmymessagemaybei'mtheonlyonethathadahardtimedecipheringtheposts
/ 1026r mower question #55
Goodnight folks, you've been a wonderful audience!
/ 1026r mower question #56
oh no biggie hahahaha most of these guys on here have VERY thin skin which i figured out awhile ago.
/ 1026r mower question #57
shortthrow50 I've decided you are right about that. I thought I'd add a little humor. Sorry to the op for getting so far off topic.
/ 1026r mower question #58
The poster wrote, "maybe, while your learning about the proper setup for your tractor...". Should be you're because it is the conjunction of "to be," "you are," not possessive, "your." Not that I really give a ****, mind you, because we all make mistakes. I just thought he was being a little harsh to the OP, who may not even speak English as a first language, and even if he did, didn't deserve the treatment he got. Two sayings come to mind: if you can't say anything nice, don't say anything at all, and people who live in grammatical glass houses shouldn't throw stones.
/ 1026r mower question #59
yeah that guy showed me the grammer error. I looked over it. I can see why he made the comment about the guys broken english though. The op obviously has a tractor not set up right and is makin uncalled for comments about john deere in a john deere section. The op doesnt appear to have any mechanical know how either so he just strikes it off as john deere is junk. My 3520 came setup wrong with the 72 mmm. They couldnt figure it out and the dealer owns all the dealerships locally. I have good amount of mechanical skills and figured out why my mower was connecting just as the op. The dealer had the wrong bracket on as well as not having it adjusted properly. I gladly told my dealer that they need to cut loose the guy that worked on my machine twice to remedy the problem and didnt fix it. I fixed it my self without going to the "school". I did not slander john deere.
2018 Chevrolet Tahoe SUV (A61569)
2018 Chevrolet...
2025 LandHonor MAD-73-05C Auger Mini Skid Steer Attachment with Bits (A60353)
2025 LandHonor...
2011 Komatsu PC200LC-8 Hydraulic Excavator (A60352)
2011 Komatsu...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A63118)
2023 New Holland...
UNUSED RAYTREE REDM32-32" EXCAVATOR MULCHER (A62131)
UNUSED RAYTREE...
Trump 2028 Metal Decorative Sign (A61569)
Trump 2028 Metal...
