Small Saw
/ Small Saw #1
retired007
Member
New Holland 3930 Kobota Zd21 Mule 4010 New HollandTZ25DA
Need small saw that is easy to start,light weight(8lbs or so) and dependable. What would you recommend?
Thanks
/ Small Saw #2
Don't know how extensive your cutting will be but if it is only occasional, I'd recommend just about anything (except maybe Poulan) . If it is for regular use, first recommendation is Dolmar 350 (but is closer to 10#) Light weight is usually home owner except fpr Dolmar. Echo would be probably the best bet for you as Dolmar's service and product distribution is a crap shoot there are so few of them.
/ Small Saw #4
About the only way to get that light is with a plastic cased homeowner saw. And since you are asking, I assume you dont want to just run to walmart and pick up a craftsman or poulan.
I second the Dolmar PS-350 or even the 420. The 420 is the same saw just a bigger jug and slug for more power in the same package. These saws are typically in the $250-$300, and for the money, I dont think there is a better small saw out there.
/ Small Saw #5
I would personally recommend any of the top handle Tanaka chainsaws. Every model in the series has the features you are looking for. All of the top handle saws come with a 3 year consumer warranty, have S-Start for 50% easier starting, and weigh anywhere from 8-10 lbs. They even meet California emissions standards without any loss of power!
/ Small Saw #6
I wouldnt reccomend a top-handle saw to anyone unless they are climbing trees for a living. All chainsaws are dangerous, but a top-handle is MUCH more so, especially in the hands of a homeowner type user. The lighter weight is enticing, but a few lbs more for a much safer saw just makes more sense to me.
/ Small Saw #7
Echo CS-271T top handle saw that weighs 7Lbs.
/ Small Saw #8
It is not simply the "weight" of a saw governing handling comfort. Top handles were designed to be used in a bucket and many times with one extended hand to provide more reach. Thus lightness being critical to one handed operation. A rear handled saw at 10 Ibs could conceivably feel lighter than an 8 pound top handle because of weight dispersion between a two handed grip. Ever notice how some chainsaws actually feel better balanced and giving the impression of lighter weight when a longer bar is installed? Its actually heavier with the longer bar but it "feels" lighter. In my estimation, balance is much more important than weight as far as handling a screaming chainsaw in the more traditional ways.
/ Small Saw #9
Thanks
Exactly what are you going to be using this for? Bucking or Limbing? What size wood etc.
Limbing I like my top handle saws (plus I can 1 hand when needed). Yeah yeah I know. Bucking I prefer the rear handle, even though I have used the top handles for doing such. Heck I used my Solo 637 top handle (only because I sold my 200T) to make 60+ tomato stacks, ripping and cutting to length. Just because of the light weight of top handle.
Just throwing other ideas out there to look at.
I liked the Redmax 3800 (no longer made) for light weight saw in rear handle with pro type build. Bolt on cylinder etc. Not like that clamshell plastic saws like the MS170 etc cheap and light though.
Shindaiwa 377 was another nice pro type built saw that was light weight.
/ Small Saw #10
My thoughts would be unless you have been handling saws for a long time and are familiar with kickback and wood under tension you stick with a rear handle saw. Top Handles are great for lightness and speed. Down side is if you get over confident reaching with it or start to get tired the saw doesn't care. We just had a proffesional tree climber cut his wrist pretty badly in a tree the other day. He stayed in the tree holding up his wrist and hand until rescue could pluck him out and treat him. So even the pro's can get bit when they aren't expecting it. For the money on a saw that is not going to be used fairly often the Echo is a good deal. I haven't run Dolmars but have heard a lot of good about them. Right now I am running Husky's and Stihls for my work.
/ Small Saw #11
Yeah, I probably wouldn't go with a top handle unless you were experienced and knew it was the right saw.
retired007, I don't know where you're located, but I have a small Tanaka 34cc saw, 14" bar, new in the box that is looking for a good home. I just have too many saws, and it's smaller than I normally need. It is a super light weight homeowner saw, not a heavy duty saw.
/ Small Saw
Thanks guys for all the info. Very helpful. Ended up buying a saw that just fit my needs to a T and bought it from a member of the fourm. Now where else in the world can you go and get this kind of service.
/ Small Saw #13
Congrats. Do you mind sharing what kind of saw you ended up getting??
/ Small Saw #14
Betcha on above LD1
/ Small Saw #15
Yep, that was it, the little Tanaka.
/ Small Saw
It's a Tanaka.
/ Small Saw #17
I use a Stihl 009 with a 14 inch bar ( Also have a 16 Inch bar 14 is on it most of the time ) I love this little saw it has been though floods and all and it just keeps going. It is my go to saw around the house.
/ Small Saw #18
I use a Stihl 009 with a 14 inch bar ( Also have a 16 Inch bar 14 is on it most of the time ) I love this little saw it has been though floods and all and it just keeps going. It is my go to saw around the house.[/QUOTE
X2 on the 009. I have owned my 009 for about 15 years. It has been a great little saw.
2008 New Holland T2420 (A60462)
2008 New Holland...
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
2016 KENWORTH T680 6X4 T/A DAY CAB TRUCK TRACTOR (A59914)
2016 KENWORTH T680...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2003 International 4300 Bucket Truck (A62613)
2003 International...
2019 Ford F450 4x4 Service Truck w/ Tommy Gate (A62613)
2019 Ford F450 4x4...
