HAY WAGON RUNNING GEAR
/ HAY WAGON RUNNING GEAR #1
Professor Marvel
Virginia near Culpeper
Ford 5000, Kubota 2150 HST, NH TC45 D, JD 375 Baby Skid Steer --- STUFF THAT GOES ON EM, Schwinn Stingray
I am looking for a small hay wagon running gear. Any ideas?
Thanks
/ HAY WAGON RUNNING GEAR #2
How small you talkin. I have a 4' x 8' wagon from Northern tool to put my hit and miss engine on. The wagon is rated at 2200lbs.
/ HAY WAGON RUNNING GEAR #3
How about one this size, 3000# rated, probably better pics of it under my username, Kory brand.
/ HAY WAGON RUNNING GEAR #4
Here is another with a 2200 pound running gear.
/ HAY WAGON RUNNING GEAR #5
Thanks
I've got the next to the smallest EZ-Trail that they make - the 260, with the wide (60") track .... have it set up as a 6' x 10'.
The gear is adjustable for length), with a wheelbase of 55" to 86" .... it's rated at 2 ton capacity:
E-Z Trail Running Gears
It's a nice, well-built gear - think it was around a grand with shipping ....
/ HAY WAGON RUNNING GEAR #6
I see in their Add, there are 3 tires on the ground and 1 on the tail gate of a pick-up.
Question, how do the stringers attach front to back to allow this much flexing?
/ HAY WAGON RUNNING GEAR #7
You'd probably have to use some leaf springs that have a lot of articulation to them.
/ HAY WAGON RUNNING GEAR #10
Yeah, I was just looking at some more info on their website and saw this:
Doesn't seem to make much sense to me to build something with that much articulation if you can't take advantage of it.
/ HAY WAGON RUNNING GEAR #11
An ad on CL for two days and these two appeared. Can't beat the price... fifty dollars. They are a little beat up but stucturally fine. They will be flower or garden carts. Need new designs though.017.jpg
/ HAY WAGON RUNNING GEAR #12
/ HAY WAGON RUNNING GEAR #13
That would be the first time I made a profit on anything. Seems like I buy high and when sale time comes its not the right size, color, or model. The first one was a fun project bending the arches and planning the structure. I like cutting, bending, and fabricating with metal so I am searching the computer for additional designs. It just would not be the same with just boards and soil.
/ HAY WAGON RUNNING GEAR #14
I make mobile hen houses out of old running gears. The biggest problem I find is that the tires are often dry rotted and leak air.
/ HAY WAGON RUNNING GEAR #15
Yes tires are usually cooked in the sun if it was not used currently for hauling. I guess it is a consideration in the price. One of mine has a new yellow rim from a chopper or such. Probably cost more than the rest of the trailer. I have extra tires but I may look for some steel spoke rims. They would dress up a flower cart and never need any maint.
2022 EZ-GO ELITE...
1998 Freightliner MT45 Step Van Food Truck (A64556)
1998 Freightliner...
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A64553)
2025 BrushFox...
500 GALLON FUEL TANK (A64278)
500 GALLON FUEL...
2022 EZ-GO ELITE...
2015 CATERPILLAR TH255C TELESCOPIC FORKLIFT (A65053)
2015 CATERPILLAR...
