HAY WAGON RUNNING GEAR
/ HAY WAGON RUNNING GEAR #1
Professor Marvel
Virginia near Culpeper
Ford 5000, Kubota 2150 HST, NH TC45 D, JD 375 Baby Skid Steer --- STUFF THAT GOES ON EM, Schwinn Stingray
I am looking for a small hay wagon running gear. Any ideas?
Thanks
/ HAY WAGON RUNNING GEAR #2
How small you talkin. I have a 4' x 8' wagon from Northern tool to put my hit and miss engine on. The wagon is rated at 2200lbs.
/ HAY WAGON RUNNING GEAR #3
How about one this size, 3000# rated, probably better pics of it under my username, Kory brand.
/ HAY WAGON RUNNING GEAR #4
Here is another with a 2200 pound running gear.
/ HAY WAGON RUNNING GEAR #5
Thanks
I've got the next to the smallest EZ-Trail that they make - the 260, with the wide (60") track .... have it set up as a 6' x 10'.
The gear is adjustable for length), with a wheelbase of 55" to 86" .... it's rated at 2 ton capacity:
E-Z Trail Running Gears
It's a nice, well-built gear - think it was around a grand with shipping ....
/ HAY WAGON RUNNING GEAR #6
I see in their Add, there are 3 tires on the ground and 1 on the tail gate of a pick-up.
Question, how do the stringers attach front to back to allow this much flexing?
/ HAY WAGON RUNNING GEAR #7
You'd probably have to use some leaf springs that have a lot of articulation to them.
/ HAY WAGON RUNNING GEAR #10
Yeah, I was just looking at some more info on their website and saw this:
Doesn't seem to make much sense to me to build something with that much articulation if you can't take advantage of it.
/ HAY WAGON RUNNING GEAR #11
An ad on CL for two days and these two appeared. Can't beat the price... fifty dollars. They are a little beat up but stucturally fine. They will be flower or garden carts. Need new designs though.017.jpg
/ HAY WAGON RUNNING GEAR #12
/ HAY WAGON RUNNING GEAR #13
That would be the first time I made a profit on anything. Seems like I buy high and when sale time comes its not the right size, color, or model. The first one was a fun project bending the arches and planning the structure. I like cutting, bending, and fabricating with metal so I am searching the computer for additional designs. It just would not be the same with just boards and soil.
/ HAY WAGON RUNNING GEAR #14
I make mobile hen houses out of old running gears. The biggest problem I find is that the tires are often dry rotted and leak air.
/ HAY WAGON RUNNING GEAR #15
Yes tires are usually cooked in the sun if it was not used currently for hauling. I guess it is a consideration in the price. One of mine has a new yellow rim from a chopper or such. Probably cost more than the rest of the trailer. I have extra tires but I may look for some steel spoke rims. They would dress up a flower cart and never need any maint.
Large Gun Safe (A64557)
Large Gun Safe...
2020 KUBOTA KX080-4 EXCAVATOR (A65053)
2020 KUBOTA...
2015 Ford F-550 Crew Cab and Chassis Truck (A64556)
2015 Ford F-550...
2013 JCB 506-36 TELESCOPIC FORLKLIFT (A65053)
2013 JCB 506-36...
CATERPILLAR D1 CRAWLER DOZER (A65053)
CATERPILLAR D1...
2005 Anderson 24ft T/A Dovetail Tag Trailer (A64556)
2005 Anderson 24ft...
