sick tractor
/ sick tractor #1
bob188
ca.
case 530 ck
i have a case 530 CK. diesel It was runing fine as i was working the front loader , than the motor quit , no sputtering just quit. No prior indications of a problem. I had fule pump rebuilt , new fule filters , and changed timing , still will not start . any suggestions . thank you bob
/ sick tractor #2
Welcome to the forum from Oklahoma. Try posting in the Case forum, some sharp guys that may be able to help you.
Ken
/ sick tractor #6
Now that I've read the post more slowly, I'll try again. :eek:
When you removed the injector pump, did you remove the shaft with the pump or leave it attached to the drive gear?
Did you make sure the pump timing marks were lined up before you removed the pump, as well as making sure the engine timing marks were in the right position?
You said you changed the timing? In what way did you change the timing? Did you rotate the injector pump in its slots or change the position of the drive gear?
Are you certain that the injector pump is turning?
You could have a broken shaft or a stripped gear in the timing gear train.
When you installed the rebuilt pump, did you remove the little window so you could see the timing marks inside the pump to make sure they were aligned?
If you left the shaft in the drive gear when you removed the pump, did you check the end of the shaft to make sure the "dot" on the shaft lined up with the "dot" inside the pump?
Did the pump rebuilder give you any indication he found something wrong with the pump that could have caused your initial problem?
Give us some more info and we'll help all we can.
Mark
2007 INTERNATIONAL 7400 SBA 4X2 VACUUM TRUCK (A63276)
2007 INTERNATIONAL...
2022 EZ-GO ELITE...
2021 TORO TRAILER (A65643)
2021 TORO TRAILER...
John Deere 670GP (A64126)
John Deere 670GP...
(3) Pieces of 30' Sticks of Heavy Wall Poly Pipe (A62679)
(3) Pieces of 30'...
High Hood All Aluminum Timpte 720 Trailer (A63689)
High Hood All...
