GAS: Regular? Premium? Ethanol?
/ GAS: Regular? Premium? Ethanol? #41
this is one of the reasons you want premium,it sours less quickly,has less ethenol,
That's a common myth, but completely untrue. All grades of an ethanol-blend (commonly E10) will have the same percentage of ethanol.
/ GAS: Regular? Premium? Ethanol? #42
****, can't even get ethanol free around here. It's all 10%. I'm more worried about the ethanol than the octane. Dealer said they have a TON of ethanol related issues. I almost went with the Stihl MotoMix just so I could get the ethanol free gas.
/ GAS: Regular? Premium? Ethanol? #43
I guess what I meant to say is ethanol free fuel. You are correct in saying E10 grades are always a mix of 90% gas and 10% ethanol.
Do you think they do the percentage of the mix by the gallon, or by the octane percentage?
I will still stick to my comment on the souring of the premix when placed next to a non ethonol fuel, reguardless of grade I may add, and that ethanol is not designed for two stroke engines, something the EPA has been wanting to cripple for years.
Waldershrek, I have one word, aviation fuel. You will have to readjust your high and low mix according to the owners manual that came with your machine,as well as your idle. Check the plug after the first one or two tanks to be sure you have the high/low/mixture correct. The high/low mix more or less adjusts the fuel/air mixture. You can richen up the high octane with less air.
I set my husky's up according to the owners manual, and run 50:1. You can also go 32:1 if you feel uneasy about the higher octane until you get more comfortable with it. I pay 5.20 a gallon here for av gas at the podunk airport.
/ GAS: Regular? Premium? Ethanol? #44
People will continue to tell you that and with some continual research you will find that 2 stroke engines where developed to run on high test gasoline.
I will look into it. I have never seen a 2-stroke device's manual call for anything over 87 octane, but I'm not exactly running high-performance equipment. A little Poulan chainsaw, a Cub Cadet weed eater, and so forth.
I actually have to look hard in my area,but with a web search of non e10 premium gas on google I got quite a few hits.
Sure, sure. You can buy non-E10. You see "ethanol free" advertised here and there. But what I'm asking is, if I pull into a given gas station that is selling E10, are you saying the 93 octane is going to have less ethanol than the lower octanes? Everything I've found says E10 is E10, regardless of octane.
Now in this day and age and the rising issues thay have with ethanol deterating carb seals, breakdown of premix,combined with the water absorption
I'm totally with you on the ethanol issue. Like I said earlier, I destroyed two carbs with it before I figured out what the cause was. I'm just not convinced that higher octane gas has less ethanol, generally.
/ GAS: Regular? Premium? Ethanol? #45
It's by volume, is what I read.
/ GAS: Regular? Premium? Ethanol? #46
The raw gasoline and the raw ethanol are mixed by volume to make the blend (90% gas, 10% ethanol). Then octane is added (it's amount by volume is puny). Most stations have two tanks, one 87 and one 91 or 93. They are mixed to get mid grade 89.
/ GAS: Regular? Premium? Ethanol? #47
Rule of thumb is anytime you mix oil with you fuel in the recommended ratio, you loose 2 octane points. Therefore, mixing an 87 octane willgive you an 85. Typically and I must say,I have never read any owners manual that recommends anything below an 89 octane on a two stroke.
It will continue to be a long argument,much as an oil thread, I am just happy I am not the one asking the questions and have found what works well for me until they try to cripple us more. I have never had to rebuild a carb unless it sat for years after a purchase,and who knows what they put in the tank,smelled like vinegarand could have been for all I know. I don;t claim to have all the answers,but know enough to keep my stuff running at its peak and outa the shop.
Oh..as for lesser ethanol,no its mixed the same throughout the grades 90/10, but with high octane it is less likely to sour as quick,and your two stroke will run like its intended too.
Its hard ot get good allthe information on a forum,check online for dependable reference sources such as wikipedia and a fewmore and learn allyou can and see what works best for you. I am content and honestly,I am still running 2 year old premix.... No complaints here.
/ GAS: Regular? Premium? Ethanol? #48
I'd be curious to know where you got that rule of thumb (sounds like malarky to me). It would suggest that adding oil into the fuel changes the energy content and combustion properties of the fuel itself, but that's not the case for a two stroke. You know how two strokes work and how the oil separates out into lubrication while the energy in the gas goes into combustion. The octane controls the speed of the combustion (slowing it from and explosion into a fast burn). The octane and the oil are independent.
Technically, the lean/rich tune of a carb is altered by the presence of oil in the fuel and will be different whether you mix 50:1 or 32:1. It's a small difference, but technically true. In that case, it's because the air:fuel ratio is changed for a given amount of mix passing through the carb. But the octane content of the gas itself is not changed at all. It's per volume of gas, and independent of air or oil.
My two newest saws, a Stihl and an Echo, both call for mid-grade fuel or better in the owner's manual (no octane numbers are mentioned anywhere, just "mid grade"). My three older saws, dating 10, 17, and 40 years old, make no mention of fuel grade at all (the 40 year old saw was made in the era of leaded gas in fact).
Some guys on arboristsite did deterioration tests of ethanol fuel, and saw no difference with the premium grades -- it went to crap just like the lower grades. Higher grade fuels do have better additives, but they are independent of ethanol (that has been the case even before we had ethanol blends -- higher grades always had better detergents and additives).
Bottom line is that ethanol blends have a short shelf life, and can really trash a carb if left to sit. In general, the consensus is to not use ethanol blends in a saw if they have been sitting around for more than 6 weeks or so.
/ GAS: Regular? Premium? Ethanol? #49
Citgo, at least, advertises the same additives in all its grades of gas. If you look around, you may find other brands that do the same.
Do fuel stabilizers like Sta-bil change this equation? I had real problems with stale fuel in my saw until I started using Sta-bil. I don't leave fuel in the saw if I can help it, because of damage to the carburetor, but I store fuel for longer than 6 weeks without apparent problem. Somewhere between 8-12 weeks, I toss whatever is left into my car's gas tank and use it up that way.
/ GAS: Regular? Premium? Ethanol? #50
when I first started driving, the gas stations had 3 choices, 87, 89with ethanol and 91
what i was told the 89 is 87 plus ethanol. because the ethanol is higher octane than gasoline.
the only avantages a 2 stroke has are lighter weight, more compact and cheaper to make. but the disadvantage is they have a very narrow powerband and are dirtier than a comparable 4 stroke.
finding a compact 4 stroke is difficult to find and is more expensive than a comparable 2 stroke, but they are becoming more readily available.
/ GAS: Regular? Premium? Ethanol? #51
It was not intended as a scientific explanation, but since you are on the subject of malarky, at what point does the dilution of premium with oil make it non flamable in a two stroke, after all, if they are independent as you say?
Gas is dirived from oil, we add it for lubrication, but we also dilute the fuel and everything in the fuel, therefore I will stick by my words you reduced the octane by 2 points or so when adding premix as a general rule.
/ GAS: Regular? Premium? Ethanol? #52
I've been using aviation gas for well over 20 years in all my small engines and two-strokes. Zero problems.
Had a Honda generator that I tried to cheap out on and used 87 10% car gas with stabil, left it sit too long, son did not run it dry last time he used it, cost me a new carb. Never again.
/ GAS: Regular? Premium? Ethanol? #53
I have used Stabil with regular gas for a long time, and do believe it helps. I also use it with the ethanol fuel that I run in my lawn tractor (4-stroke). I do believe Stabil can help with any fuel blend, but it will not offset the unique problems with ethanol (nothing can). So you definitely still want to exercise caution when storing ethanol.
I am good friends with the local Stihl mechanic, who services a lot of chainsaws that develop carb problems due to ethanol. Stihl puts a fuel stabilizer additive in their oil that is like Stabil, and helps extend the shelf life of a gas/oil mix. Sadly, it doesn't solve the problems with ethanol. His dealership hands out a pink flyer with all their equipment, cautioning customers about ethanol issues and that stabilizers only help a little. From what he tells me, the biggest problem is that the ethanol portion separates out, attracts moisture, and eventually you get layers of separated gas, water, and ethanol, where they each start to degrade equipment in different ways.
/ GAS: Regular? Premium? Ethanol? #54
That's probably not true, as octane is separate and independent of the fuel, whether it's gas or ethanol. The gas or ethanol doesn't naturally have octane in it.
What is true is that ethanol contains about 15% less energy per volume than gas. So you really start to lose out when mixing ethanol into gas. It's actually noticeable if you can carefully measure and track MPG on a vehicle.
/ GAS: Regular? Premium? Ethanol? #55
Listen, you can't extrapolate out into extremes and expect the logic to hold (or for me to keep going on with this). Obviously the fuel/oil mix won't work if there is too much oil for the carb to properly atomize everything, or for the fuel/air to ignite and the oil to separate out and lubricate. But that has nothing to do with my point. The point is that the octane is chemically part of the fuel, and the octane sticks with the fuel during the combustion process to control the burn. That is a totally different concept than "mixing" which just combines things in a non-chemical way in a container. The oil and fuel are mixed, and not chemically bonded (they will separate back out if you wait long enough, which is why it's important to shake the mix after it's been sitting a long time). You need to understand that. It's almost like you're saying that mixing vegetable oil and vinegar into salad dressing chemically changes the vinegar, but obviously that's not true -- they simply mix, and can be separated back out.
Here's how you have to look at it. The carb controls flow rate of the gas+oil mix that is combined with air, so it must be adjusted to send the proper amount of gas+oil flow through to the engine such that the independent amount of gas present, combined with air, is correct for proper combustion and performance. The portion of the mix that is gas (with its chemically included octane) and the air it mixes with is what matters for combustion. The oil has been along for the ride up until this point, and it now separates and goes into lubrication (and some of it burns up and goes out the exhaust).
So bottom line, no matter what ratio of gas to oil you add to a two-stroke (in the realm of possibility), as long as the carb is properly adjusted so that the right amount of gas+oil mix passes through to later provide the proper gas+air mix, independent of the oil, then you're OK. The oil is not diluting anything at that point (like octane content) since it has separated back out.
/ GAS: Regular? Premium? Ethanol? #57
So bottom line, no matter what ratio of gas:eek:il you add to a two-stroke (in the realm of possibility), as long as the carb is properly adjusted so that the right amount of gas+oil mix passes through to later provide the proper gas+air mix, independent of the oil, then you're OK. The oil is not diluting anything at that point (like octane content) since it has separated back out.
I'll buy that, very nice explanation on the molecular level, well done (some times I just have to call your hand). One more question: Where the h e l l where ya 3 pages ago? (And yes, I will still stick to the 2 point reduction of octane....sorry, due to the combustion area of the cylinder head, and the point that we have diluted the gas with oil. I believe octane ratings where intended for the product undiluted, therefore,I feel once oil is added, we do not get the biggest bang for the buck, just lubrication. )
/ GAS: Regular? Premium? Ethanol? #59
Airfoolers.com » Premix 101 – 2 schools of thought.
quote: One of the things you should do, is run high octane gas with any two-stroke mix. When all of the two strokes (the old days) were developed, they all used Castrol petroleum oil at a 20:1 ratio and found that 92 octane gas had the octane reduced to 72 with presence of that much oil. Modern oils won’t affect the fuel quite as much, but if you started with 86 or 87 octane regular fuel, you can see where you’ll end with a very low octane mix.
/ GAS: Regular? Premium? Ethanol? #60
Another premix item.....does changing premix ratio change the air/fuel mixture? Quote from article: A typical example: you go from a 50:1 ratio to a 20:1 ratio. Your engine will now run leaner, and you値l have to make jetting changes. You値l need bigger (in number) jets because the oil molecules are thicker and the flow rate (the amount coming through the jet) is less.
Aha! The volume of fuel has changed. The oil takes up some volume that the gas used to occupy, so your engine is getting less gas and needs to be richened up.
(We used to do quick jetting changes by changing premix ratios when we were ice racing.)
2011 Ram 1500 Pickup Truck (A59230)
2011 Ram 1500...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
Year: 2018 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 77793 Plate: Body Type: 4 (A59231)
Year: 2018 Make...
2015 MACK GRANITE GU713 DUMP TRUCK (A59823)
2015 MACK GRANITE...
LMC 6' SOIL CONDITIONER (A59823)
LMC 6' SOIL...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
