GAS: Regular? Premium? Ethanol?
/ GAS: Regular? Premium? Ethanol? #11
Like Bird I cannot get ethanol free gas, (yes, the lake is too far away).
I burn premium in both my Stihl saw and trimmer, with Stihl oil. I bur regular in the mowers, blowers and generator.
I run the generator, saw, & trimmer dry before I store them (because my dealer said too do this).
Be well,
David
/ GAS: Regular? Premium? Ethanol? #12
Use premium, i know it says 89 in the manual, but the premium wont hurt it and get it ETHONOL FREE. The oil u use if you use quality stihl oil or husky will have a fuel stabalizer in it and i have not had a problem using it after 1 year. I have run premium or mid in my stihl and had it for 8 years no problem. i heat with wood and use to cut wood for family before that.
Trust me you dont want the junk that the ethonol gas forms. Its makes crystals that are hard. they almost look like seasalt or table salt or sand inside your carb float bowl and plugging your jets. Before it totally dries its a goo, that wont really suck through your jets either, kind of like a vaseline. Buy quality fuel!!!!! Best practice is to dump it after 6 months or so of sitting. I put it in my pickup (there 22 and 32yrs old) or will put it in the lawnmower and then get new fresh fuel to run in the tiny 2 strokes (my saw is $500 maybe more now a days?)
/ GAS: Regular? Premium? Ethanol? #13
joshuabardwell said:
My understanding is that higher-octane gas is only necessary for high-compression engines, such as those with a turbocharger. The higher octane resists precombustion ("knocking") at higher compression ratios. In engines running at lower compression ratios, the extra octane is totally wasted. I only put 87-octane into my yard equipment. If I ever notice it knocking, I'll reconsider ;-)
Turbo engines have less compression.
/ GAS: Regular? Premium? Ethanol? #14
I use ethanol free premium in all my stuff; they say the chain saws/trimmers, etc. run cooler with the premium gasoline.
/ GAS: Regular? Premium? Ethanol? #15
I have a stihl 230 chainsaw. The manual says ( yes I am guilty of reading it :) ) 89 octane lead free gasoline or higher . Reason stated is that lower octane may cause engine over heating . As a personal rule I only use ethanol free ' cause I can get it .
I 'll stick with the manufacturer 's recommendation .
/ GAS: Regular? Premium? Ethanol? #16
I read a while ago that the fuel octane drops when you mix it with oil so that is why you start with a higher octane fuel. Another problem with ethanol is it will boil at a lower temp than non ethanol fuel.
/ GAS: Regular? Premium? Ethanol? #17
Seems like most of the loggers here run the 87 ethanol gas in their saws. I have a couple of stihl saws and trimmer, and don't have problems with it.
/ GAS: Regular? Premium? Ethanol? #18
But isn't the flip-side of this that 2-stroke engines are designed to run in a gas-oil mixture? So the question is, what octane fuel are they designed to run off of? And I submit if they required 93-octane, or whatever, the owner's manual would say so--just like the owner's manual of my car's turbo-charged engine does. So I submit that small engines are designed for 87-octane, unless specified otherwise, and putting higher-octane fuel in has little or no advantage. Again: it's my understanding that higher-octane gas offers additional knock-resistance, but that's it. So an engine that is computer-timed can run higher compression and get more horsepower with higher octane gas. But your chainsaw isn't computer-timed. It runs the exact same timing whether you have 87 octane or 93 octane. And therefore, if you put higher-octane gas in it, it's not actually benefiting from the additional octane. Unless you're the type of person who can and will adjust the timing of your chainsaw, in which case more power to you.
BTW, some have made the case that higher-octane fuel is better because it often comes with detergents and so forth that are not in lower-octane gas. This depends entirely on where you buy your gas from, but is independent of the argument about octane itself.
/ GAS: Regular? Premium? Ethanol? #20
scrappy isb67 said:
the wife's car is turbocharged and running 12:1 compression. just because it is turbocharged does not mean it is lower than NA. especially in modern engines.
What is it? A diesel?
Redirective Crash Cushion Guardrail (A59230)
Redirective Crash...
2012 ISUZU NPR CREWCAB 16FT BOX TRUCK (A59905)
2012 ISUZU NPR...
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A59231)
2014 Glasstream...
2005 JLG 600S 4x4 Telescopic Boom lift (A59228)
2005 JLG 600S 4x4...
2023 FONTAINE INFINITY FLATBED TRAILER (A59823)
2023 FONTAINE...
2023 John Deere 333G for Parts (A61306)
2023 John Deere...
