Ford loader mod and install on YM336D
/ Ford loader mod and install on YM336D #1
Domush
Kentucky, US
1981 Yanmar 336D
Recently I bought a FEL which the seller claims went to a Ford 2000. It is hardly an awesome FEL, but it should get me started.
What I have to work with:
In looking at how the OEM bracket is designed, there is no way I'll get it to work. I'm just going to recreate the entire thing.
The bucket is tiny, but I don't see me needing anything huge, so it should do for now. The big problem is a hay spear the PO welded into the bucket. Removing that thing will be a pain in the butt. For scale, the trailer it is on is 16' long x 8' wide
The ghetto hay spear
The center brace is a massive piece of sheet steel which seems to do a better job blocking your bucket line of sight than add structural integrity. I'll likely cut that out and weld in a large pipe like most loaders have today.
These brackets came with it, but I have no idea why. Either way they'll likely just be good for scrap steel.
The loader valves. The good news is they all have quick disconnects and, even better, there is a third one! This means I'll end up having a rear remote, which is very exciting! Alternatively, if I ever get around to it, I can add a grapple to the bucket.
Sorry for the dark photo. I'll get a better one soon.
It seems to have all of the needed hoses and connectors, but a couple of hoses are pretty rotten, so I'll have to replace them.
As for the length of the loader arms.. I think they may be too long for my tractor, but I have yet to made any measurements to verify.
What's next you ask? Well, I have no idea how these loaders connect to this tractor, so if anyone can please post their 336 or similar FEL mounts I'd really appreciate it!
I have a bunch of photos of a 170 or something, but I'd much rather see how a frame attaches to this specific tractor series. I'd rather not break my frame after all of this effort :thumbsup:
Cheers!
/ Ford loader mod and install on YM336D #2
Well here is what I have for you in hi-res sorry TBN hth. :)
Just me thinking out loud here but the basic bracket is not that much steel.
I can only imagine it not being super expensive from Koyker but seem to remember the quick attach option being $100?
If that is these pieces that would be a bargain just saying...
/ Ford loader mod and install on YM336D #3
CarDoc,
Thant tractor looks great being kneedeep in new rubber !!!!!
/ Ford loader mod and install on YM336D #4
After seeing the loader, you might consider leaving the lower arms as-is and finding a way to attach to the rear of the tractor. I believe they were attached to the under side of the rear axle on the ford they came off of. If the arms are close in length you might be able to fabricate the front brackets to hold the arms in place easier than cutting it up to fit the new style brackets.
Did you do some measuring to see where the unit ends up on the tractor ?DO a search for some pics of this loader on the early fords to see how the arms attach,its a strong loader and the arms to the rear axle are farily easy to attach,maybe just a plate under the axle ...
/ Ford loader mod and install on YM336D #6
It looks like what I would do is set the loader and mount frame assembled together at about 16-20" say off the ground on boards or jack stands, hang it whatever, and drive the tractor into it and then start the design process from there.
The bucket can be replaced with about any 5' bucket I bet. fwtw my bucket I have off mine for other work has a mount bracket that is 45.5" on the outside of the loader arm and has a 2 7/8" opening and uses 1" pins.
I can see the rear end mount they had rigged up and that may or may not work if it does fit and is level with the rest hey its added strength id use it. :thumbsup:
btw you probably got $400 worth of hoses and valves alone if they are as good in person as they look in the pics.
/ Ford loader mod and install on YM336D #7
From my own experience of building a loader an a FX24
From my own experience from building a loader for my FX24D, it is critical to keep the bucket as close to the front of the tractor as possible. Shorten the bucket arms and adjust the angle at the attachment points to the lift arms. Keeping the center of gravity close and the weight as close to the front axles will prolong their lives.
Don't forget to build it so it is easy to remove. Look at the newer FELs to see how they do it. Easier to mount/dismount the more flexible will be its use.
If I think of any other things, I will respond.
Hey all,
So I finally got some time to clean up the FEL valve assembly as it was caked in grease and I found an unexpected surprise.. it has a PB port! :thumbsup:
Here are some better, daytime photos of the assembly..
The valve is made by "Cross", which I've never heard of seeing as I've never done anything with hydraulics before this. I couldn't find anything which looked like a model #
Anyone had experience with this valve system before? Quality? Cheapo?
As a side note, I cleaned it with my new-to-me 5HP gas power washer which I bought at a flea market for $30! :D
The guy said it wouldn't activate the sprayer, but a simple carb rebuild later and, aside from the soap feeder, it now works perfectly!
With a bit of google searching I found it is a Cross 4Z00009, which is the older version of the still-in-production Cross Model BA 3 spool valve.
I'm not sure if this is open center or not, though. There is apparently a closed-center conversion kit still sold by cross which leads me to believe it comes default as open-center, but I'm not sure if it is currently open center. Anyone know how to tell the difference?
/ Ford loader mod and install on YM336D #10
If JJ or LD1 sees this they will know what it is and what to do with it. Nice find on the washer btw! :D
/ Ford loader mod and install on YM336D #14
my loader mounts look much like those of CarDocs,I have not forgotten just been working too much and have not had chance to get some pics...................
More to follow..
Preston
/ Ford loader mod and install on YM336D #15
I agree about keeping the bucket as close to the frontend of the tractor BUT I would not try to shorten the arms of the beem unless it was necessary/ I would first try to keep the frame masts as far rearward as practical. by shortening the boom you reduce overall lift height and reach.
Update on the loader situation. I decided not to use that loader, as I wasn't keen on yet another project. I'll likely just build a carry-all and call it good. There isn't much I need a FEL for on my little property. The good news is.. I kept the valves and hoses, so I now have a 3 spool valve for rear remotes! :thumbsup: .. Now to figure out what to use rear remotes for..
/ Ford loader mod and install on YM336D #17
Did you loose on the deal? Or did you at least come close to recouping your purchase price and just loose the gas $ and time to get it?
I broke even on expense, the time didn't matter to me, it was a nice drive. I gained on keeping the valve and hoses. Overall worth it for me and the buyer was thrilled, too. Win-win
Sent from my SCH-I500 using TractorByNet
/ Ford loader mod and install on YM336D #19
3 pt log splitter, tilt and turn back blade, hyd controlled land leveler, back hoe, hydraulic PHD.....lots of things possible I cant even think about all of them good idea you kept them just in case haha!
/ Ford loader mod and install on YM336D #20
I just saw this thread and noticed you are ditching the loader but keeping the valve.
It is most likely an open center valve if it was on a loader. Because a closed center valve would build and hold pressure when you werent using the loader and keeping the pump under load all of the time. Open center allows the oil to continue to circulate through the valve with little to no pressure until you hit a valve and that diverts the fluid to go do "work".
I would also "highly" suggest getting rid of those sch40 water pipe fittings. Those have no business in a hydraulic application. Get steel fittings MADE FOR HYDRAULICS.
2011 CARGO CRAFT PUMP CONTROL TRAILER (A67714)
2011 CARGO CRAFT...
2014 Ram 2500 4x4 Crew Cab Pickup Truck (A64194)
2014 Ram 2500 4x4...
2019 Chevrolet Tahoe SUV (A66738)
2019 Chevrolet...
2023 CHEVROLET W5500 4X2 S/A 16FT FLOOR TRUCK (A67148)
2023 CHEVROLET...
1978 Fruehaue Chipper Trailer (A62613)
1978 Fruehaue...
2019 Westinghouse WSTBT1503 Wireless Speaker (A61574)
2019 Westinghouse...
