Can't view just "Other Forums"
/ Can't view just "Other Forums" #1
jmurray01
Scotland
I did have a pedal John Deere once...
I can view the main forum, but can't hone in on just "Other Forums" as I often do so I just see the sections in that area.
Darn it :laughing:
/ Can't view just "Other Forums" #4
I miss the drop down where you could easily select a specific forum to view, so now I judt go to "Today's Posts".
/ Can't view just "Other Forums" #5
Confused, are you trying to see the posts in all of the "other forums" subforums at the same time, or just see the list of "Other Forums"?
If it is the latter, they can be seen at: Other Forums
Aaron Z
/ Can't view just "Other Forums" #6
Yeah, I know what you're talking about. I could have sworn that when I read this thread, I was having the same issue. But now I'm not. :confused3: Didn't change anything... unless I did it in my sleep. :confused2:
/ Can't view just "Other Forums" #7
Any plans to have a drop down like on the old format or am I missing it?
/ Can't view just "Other Forums" #9
jmurray01
With all due respects,
Just curious why you have to spread your signature all over the page. Sure take up a lot of space and nothing is really said.
Do you really need to be recognized that much.
/ Can't view just "Other Forums" #11
jmurray01
Must be your screen size. It doesn't show up like that for me.
/ Can't view just "Other Forums" #12
I think he is talking about when you put the pointer on the "forums" tab there use to be a drop down of all the forums and you could choose a specific one. Now the dropdown window does not come up. I noticed the same thing.
/ Can't view just "Other Forums" #14
Signatures can be turned off:
MY HOME
General Settings
Visible Post Elements
Show Signatures (uncheck)
Save Changes
/ Can't view just "Other Forums" #15
Old forum, if you hovered over the FORUMS, a drop-down list would appear, from which you could select the forum you wanted to view.
Now you must select FORUM, which brings up a page with all the forums on it, you must scroll down to the forum you want to view, and select it.
/ Can't view just "Other Forums" #16
Yes, it is true that you can turn the signatures off, but the large white space is still there and is wasted space.
As in this post.
Aaron Z
Nope, it brings me to the main forum.
As for my signature, I've never had any other complaints about it...
/ Can't view just "Other Forums" #18
As in this post.
An alternative is to use the Ignore List:
MY HOME
Edit Ignore List
Type User Name
Click Okay
Save Changes
Asphalt Melter (A61572)
Asphalt Melter...
500 GAL WATER TANK (A68842)
500 GAL WATER TANK...
(INOP) 2020 JOHN DEERE 333G SKID STEER (A65054)
(INOP) 2020 JOHN...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
213101 (A64276)
213101 (A64276)
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
