Oil change recommedations
   / Oil change recommedations #1
Mike_Kanzer
Gold Member
Chester county, PA
Kubota L3830 HST, JD Gator 855D
Hi-
I am getting ready to do a 500 hr oil and filter change on my L3830 Kubota. Kubota recommends using 10w30, 10w40 or SAE30 oil - all are okay with temperature ranges I live in. Lows of 10Fin winter and highs of 95-100F in summer. Is there any rhyme or reason as to what to use? I would assume a multiviscosity oil makes the most sense, but which one?
   / Oil change recommedations #2
multi vis is the way to go. in colder temps ( pa right? ) that straight 30 will be like grease on startup.
in hot desert temps.. maybee not bad.. but still.. a nice oil like a 15w40 C rated is the general diesel catch all for dino.. and 5w40 C rated for synthetic for moderate temperatures. in cold climates for dino, a 10w30 C rated oil.
Note. many places do not stock 10w30 C rated.. though S rated is common. as for 10w40 oil.. I see S rated oils.. but not sure I have ever seen 10w40 C rated. whatever you do.. use a C rated oil that meets the minimum spec in the book. IE.. the 2nd letter and number combo after the 'C' ( CI, CI-4, CJ etc.. )
soundguy
   / Oil change recommedations #3
soundguy
Years ago, I spent some time trying to make sense of the oil requirements for our various machines, and we settled on Delo 15W-40 for all of the diesels (Kubota, JD and Navistar).
In fact, the two closest Kubota dealers both quietly recommend it (or similar 15W-40 brands), despite the fact that they carry much more expensive factory oils.
Costco and many others sell Delo.....
   / Oil change recommedations #4
i pretty much use 15w40 in all my tractors.. save one that I switched to synthetic after a bent pushrod and stuck valve situation. my trucks all get 4w40 syn.
soundguy
   / Oil change recommedations #5
EVERYTHING....including my gasoline powered equipment and all my diesel equipment gets Shell Rotella 5w-40 synthetic. It's expensive, but a lot easier to have one oil for eveything. My main concern is the well being of my diesels. The gasoline engines are getting the benefit by default. :thumbsup:
   / Oil change recommedations #6
kinda the same here. I have a mix of diesel and gas tractors. I use 15w40 for all them.. thus the gassers are geting a benefit.
my truck diesels and 1 tractor are getting synthetic.. I want the engines lasting... I do some multi state hauls fething antique machines and not uncommon to make runs to the lower southeast / west 1-4 states away on weekends hauling a gooseneck trailer.. running with 2 drivers, extra fuel tank and driving straight thru with few stops save food/tinkle.. last trip to texas ran 46 hours straight pretty much...
   / Oil change recommedations #7
Wow, what an idiot I am!! How simple a solution so obvious a monkey could figure it out. I have synthetics for mt ATV's, different oils for my lawn tractors and chipper and now 15w40 for my tractor. Thanks for pointing out the obvious to me, now I know why I love this site so much, even simple things can be valuable lessons.
   / Oil change recommedations #8
I think 'idiot' is being kinda harsh on yerself. Nothing -wrong- with running a specific oil in each equipment.
it's just that some of us consolodate. 15w40 S/C rated oils, in a wide range of climates are good for both diesel and gassers.. especially small engine gassers and slightly older gas vehicles that don't cal for a 0w/5w 20 type energy saving oil... thus stocking 1 oil for many engines. that way you can buy by the pail or drum. heck.. my lawnmowers even get 15w40 or syn.
same deal on the 5w40 syn's or other types of syn. for their specifics.
same deal with using a UTF fluid to replace plain hyd oil, and gear oil in some non HD applications.
for a guy with varried equipment.. buying a drum of 15w40 and a drum of UTF and perhaps a pail of gear oil... can mostly service ALL his stuff.. :)
and you've always got some spare!
soundguy
   / Oil change recommedations #9
most of the loggers & hd equip operators around here use shell rotella 15/40 dyno which i'm sure serves them well. along with others in this thread, i have gone over to rotella syn 5/40 in all my equip from zero turn, log splitter, vehicles, & my M8540...obviously it's convenient to use 1 in all....but what changed my mind is when i changed rotella 15/40 dyno in tractor in close to freezing temp...yes the warmed oil drained fine, but man the pouring the new oil in the crankcase took forever it seemed....on a cold start up @ 10 degrees how long does it take to flow to engine parts? but i know it's all about residual film on journals, etc too....really it's personal i think, & how well you sleep @ night.. time to turn in.
   / Oil change recommedations #10
Shell Rotella, Mobil Delvac or Delo 400 15W40 in everything I own from tractors, cars, trucks, motorcycles, ATV's, and all small engine stuff. The ONLY exception I make is for when I buy a new vehicle and the mfg recommends 5W20 or 5W30 while it is still under warranty, after that it gets the mentioned oil.
   / Oil change recommedations #11
I've been running Shell Rotella Synthetic 5w40 in the B2910 for the last 1000 hours or so .... no complaints (other than price :laughing:)
I'll be changing the oil later today (hopefully) and will be switching over to Mobil 1 Turbo Diesel Truck 5w40.
I've been running Mobil 1 0w40 "European Car Formula" in the Dodge (Mercedes 5 cylinder diesel) Sprinter van for the entirety of it's 376,000 miles (save for one OC) and the UOA's have shown very low wear numbers. May switch that one over to M1 TDT as well.
Stopped at dealer today to pick up the oil/filter. He puts Rotella T 15w-40 in all the tractors he services, so that's what I got for my L3830 - Thanks for the feedback guys.
   / Oil change recommedations #13
I remember years ago, cowboydoc days, you stated you use traveler oil in my antiques, and valvolene oil in my 'new' ones Or you stated you use "regular oil" and be fine..
So now synthetic will make the engine last longer? I use synthetics and that question is something no one can prove.So why did you change since you nailed a few old users on it.
   / Oil change recommedations #14
.So why did you change .
so you are judging what I put in my tractors now, based on what I put in my tractors in 2002.. and same for my trucks?
I didn't own a diesel truck let alone 2 back in 02.. So that point is moot. ( though the ones I own now ARE getting valvoline )
I had but 1 diesel tractor back then.. and it got 'regular' dino 15w40. that still holds true. no change.
i now have more diesel tractors. guess what. same deal.. STILL using dino 15w40 in them???
same with my gassers.. still dino oil. about the only change is brand. Traveler is no loger the best price / value oil. I've switched to another brand.
I do have a tractor, as mentioned on synthetic. i recently rebuilt the top end due to bent push rods and stuck valves... that one is getting synthetic.
so.. nothing I've stated disagrees with anything I stated before.. I've simply changed brands and added machines and serviced them accordingly.
Any other 10 year old info you'd like to pull up and try to misconstrue as an untruth? or was that enough????
I changed brands. i don't see that as an issue. as for the ADDITION. It would have been impossible for me to write a post covering units I would not own till the future.. thus my comments can't be looked at in hindsite and seriously be applied to events that happened AFTER they were made?
   / Oil change recommedations #15
Different circumstances..
the 1 tractor i put on syn after working on the engine, I did so for the detergent effect to clean the engine up. I had gotten alot of fuel related deposits ( my theory ) in the top end.. etc.
as for the syn in my trucks. As I stated before.. i didn't have those diesels back then.. I do now. when i got them, they had been run on synthetics. i chose to continue to do so for a number of reasons. extended oil change was the least of those reasons. More for temperature handling for the turbo engines, especially since I use them on extended hauls pulling heavy loads. these trucks have high ratio rear ends.. one is a 4.88 rear meaning to run interstate speed I'm nearing redline. a syn gives me a lil more leeway on a hard pull to prevent oil breakdown.
in any case.. you are attempting to compair apples to future pears.. thus no comparison at all to the circumstances I was in then, and now.
IMHO.. extended drain intervals are still the least of my concern when considering a synthetic. I have been doing some testing on some syns int he way of UOA. on an engine needing 5qts oil.. it's not a good retun on investment.. on an engine needing 15 qts.. it becomes reasonable.
add to that that dino oil tech, especially with reguard to diesel oil and particulate filtration is an entire different ballgame than 10ys ago.
on my old gasser tractors, I'd still rather go with a less cost dino oil, and change the oil 2x as often, vs an extended change on syn, as I want 2x oil changes per year.
using a 15w40 C(s) rated oil in them old gassers is a benefit over a ZDDP depleted S rated oil made nowadays for environmental purposes.
again. stuff that happened a decade ago has changed due to materials changes and circumstance changes...
soundguy
   / Oil change recommedations #16
soundguy
What are YOU expecting on a return from a UOA using synthetic? Funny the military does not have set milage for drains (90,000 lb trucks; I work there). All are done by UOA, for cost savings etc. UOA are worth there weight in gold if you use them correctly. Not getting into it since this is a old topic.
So if you are still holding the same why did you change? For top end cleanup is pretty lame. MMO will do it when added to oil. Years ago dino was crap for a turbo and you think it has changed? 800 to 1,000 F is great on shut-down for a cheaper oil.
Sounds like you are playing both sides. I am making it a point since you nailed alot of users for wasting money etc and now it is okay. Just comical since it sounds like they had added value [back then] that you did not get to there level of use yet. Nothing personal just funny ....Hence, why this is not the forum for oil talk...lacking....and yes I stop in at time..
   / Oil change recommedations #17
i'm guessing you DID NOT read any of my post.. at all.
I said I WAS doing some UOA to see what's going on. you seem to state otherwise.
I also said on my turbo machines I WAS using synthetics. you seem to state otherwise.
What cheanged? EVERYTHING changed. oil types, formulations, machines, circumstances. everything changes except the old gassers I have.. and for those.. they still get the same old oil they got back 'then'. And I still like a cheaper dino oil in them for multiple changes vs a spendy synthetic.
As for detergent action of a synthetic.. I believe you are very much underestimating it's ability. in any case. that engine I put back together is a test case. It was designed for dino oil, ran dino oil all it's life, I swapepd it to syn after the rebuild. it sure won't hurt it any.. I'm checking to see if it will clean it any better. thus the test. I already had been using MMO in my oil .. so can't throw that into the mix.
this weird ethanol, water friendly gas we are getting now seems to be a problem for many small gas engine owners. on other forums I've seen a huge rise in small gas engine failures, everything from plugged and gummed fuel systems to seized engines. of course the complaints are tapering off now as the move to ethanol was a while abck and the damage is done and almost forgotton now. the antique tractor community is still seeing some effects due to low hour usage machines still subcoming.
I'm not palyiong both sides of anything. I like a dino oil for multiple changes vs a more expensive syn and a singe change on my gassers. same thing i said 10 ys ago. my gassers are still getting dino. brands may have changed.. and weights, but that's about it. I used to keep some on 30w etc.. and switched just about everything to 15w40 foe a couple reasons. keeping 1 'most' used oil around lets me stock less oil types, plus I can buy in more bulk for more cost savings. 15w40 is a good multi weight oil that has good temp range coverage for the region I'm in. it's a decent weight oil for a machine designed to run 10w to 20w in the winter, 30w normally, and 40w in hot weather. pretty much covers the entire range int he owners manual, all in 1 oil. add to the fact that the epa zapped zddp levels in S rated oil a few years back, thus using a C(s) rated oil is a wise choice for flat tappet engines.
as for changes.. i have some diesel equipment now.. new equipment.. new practices.
if you'd like to argue, lets go to email.
if you'd rather sling mud.. lets not do it at all.
I consider this my last post on this topic cluttering the forum. again.. you've been invited to email if you wish.. or if you want to sling mud..I'll just add you to the ignore list. I've no desire to clutter this forum up with someone attacking me on a difference of practice, on different equiopment that I didn't own 10ys ago.
i've explained my thoughts pretty clearly, not hasing words. i explained what i did for servicing practices then and now, and why I made those choices. you can choose to argue with what i did or why.. or move on... your call as I'm done on the topic. I've explained myself about 4 times now, as youve asked. clearly. in the open.
soundguy
   / Oil change recommedations #18
soundguy
This is why years ago it was a joke to post anything hat did not agree with you. Case in point you nailed people years ago, now they are right (go figutr); since you have, oh boy, "new practices. "...maybe they had them long before you did; but, you nailed them then...Still pointless years later that 90% of users will not get it...Cowboydoc left and so did others, for good reasons I think. Lack of understanding............for 1 thing..,,,,seems, based on your postings now, you have issues with this topic..take it to PM or emails since this is the same issues from years ago...amazing.
   / Oil change recommedations #19
cowboydoc and I talked often.. i'd venture to say we were friends
   / Oil change recommedations #20
good for you..Cowboydoc is well, I have several emails from users on what he did to them out there (played mr Doc) ..If you are friends, you can have him...
78in Bucket Skid Steer Attachment (A59228)
78in Bucket Skid...
UNUSED IRMC HIGH END MASSAGE CHAIR (A60432)
UNUSED IRMC HIGH...
UNUSED IRANCH 38" MINI LAND LEVELER (A60432)
UNUSED IRANCH 38"...
KAWASAKI 42ZV WHEEL LOADER (A60429)
KAWASAKI 42ZV...
JOHN DEERE 9560R SCAPER SPECIAL TRACTOR (A60430)
JOHN DEERE 9560R...
SKID STEER ATTACHMENT TILLER (A58214)
SKID STEER...
