Makeshift welding table
/ Makeshift welding table #11
Not even 1 post about using endlessly adjustable FEL / Forks?!? :shocked:
Would you use those without disconnecting your battery??
I've thought that using a spare skidsteer attachment plate with a couple of receiver hitches and a mating table or set of tables (one for cutting, one for welding, maybe one for bending etc.) would be a great way to have a portable and height flexible metal working set up. However the fear of frying electrical components on the tractor has disuaded me to date. I suppose one could install an insulator somewhere in the mount (?rubber or silicone sheet over the tractor side skidsteer adapter).
/ Makeshift welding table #13
Hey folks, careful welding on / near concrete. The moisture within the concrete can make the concrete explode if exposed to high heat.
/ Makeshift welding table #14
Is there a back story :eek: ???????
RC
/ Makeshift welding table #15
On my very first job right out of welding school I had to cut something with a O/A torch, there was a real handy concrete floor about 12-inches high from the dirt. Luckily for me I didn't take the time to put on my burning goggles just flipped down my welding hood, and started burning. BAM! WTF was that:eek:?! Looked down and a big chunk of the slab was missing!:eek:
/ Makeshift welding table #16
RC
Shield Arc's story was pretty entertaining. I don't have one personally (and thankfully for that). I did hear about this danger and figured it was worth passing along as it never occurred to me until I heard it.
/ Makeshift welding table #17
Speaking of the concrete, I saw a picture where someone sat a charcoal chimney starter for their bbq on a concrete driveway, and lit it. WHen they lifted it to dump the coals in the bbq, there was a circle of spalling the size of the chimney on the driveway. Looked like someone whacked away at it with a hammer for a while.
/ Makeshift welding table #18
I'm a bit embarrassed to admit I didn't recognize the term "Swamp Yankee." I looked it up here http://en.wikipedia.org/wiki/Swamp_Yankee and then knew why I didn't recognize it- I come from Western Massachusetts and Vermont!
Still on topic- growing up as a kid in the mid-60s, I remember my best friend entertaining himself by using his father's torch to heat up the concrete floor in their garage until it exploded. it's a miracle we never suffered any injuries beyond scrapes and cuts from that. It was the same torch we used to cast lead toy soldiers- his dad was a plumbing contractor.
/ Makeshift welding table #19
Kind of surprising any of us survived childhood! LOL
/ Makeshift welding table #20
I'm a bit embarrassed to admit I didn't recognize the term "Swamp Yankee." I looked it up here Swamp Yankee - Wikipedia, the free encyclopedia and then knew why I didn't recognize it- I come from Western Massachusetts and Vermont!
It sounds to me if them thar "Swamp Yankees" and us "Hillbilly's" would get along pretty good.:thumbsup: I am thinking we are one and the same. Long lost cousins as it were.:)
James K0UA
AGT Industrial ExRC54 (A60463)
AGT Industrial...
(INOPERABLE) DYNAPAC DOUBLE DRUM ROLLER (A58214)
(INOPERABLE)...
2024 Case IH Farmall 75A (A60462)
2024 Case IH...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
Case SV280B (A60462)
2016 Ford Explorer (A59231)
2016 Ford Explorer...
