Makeshift welding table
/ Makeshift welding table #1
IslandTractor
Super Star Member
Prudence Island, RI
2007 Kioti DK40se HST, Woods BH
OK, here is a challenge: What have you used as a makeshift welding table in the field?
I had to weld up some simple hanger fixtures and found this to be a handy arrangement for stick welding with 1/16" 6013 on some 16 gauge curtain rod hangers.
We don't have Rednecks up here in the Northeast, we have Swamp Yankees so this is a Swamp Yankee set up. Ground was hooked to the thin strip of 14 gauge that lays across the grill. I thought about just using the grill but figured I'd get better ground with the non greasy hot rolled sheet. Worked fine.
/ Makeshift welding table #2
Against me anyway, you win hands down! :D
/ Makeshift welding table #3
I used an old home made bbq stand, with some rebar welded across it. It sucked, I had to be on my knees to use it. I have also used a concrete pad, some scraps of angle iron to prop pieces off floors, I think I have used a brick. The worst was a 4x4" piece of 1/8 plate, on a wood table. I was soldering or brazing some pieces of coat hangers together to make some little decorations. Got a few burn marks on it, luckely it was a shop table.
/ Makeshift welding table #4
Oh this could be an endless list, but lets see. Chunk of 12" x 12" creosote timber. Chunks of beam. Wood saw horses with 2" x 4" for table. Tracks on crawler cranes. Out rigger beams of mobile cranes. Concrete floor.
I'm sure there are more, just can't think of any now. :laughing:
I love the tracks on crawler cranes one. :thumbsup: I hope he had his battery disconnected!:laughing:
/ Makeshift welding table #6
I use my Harbor Freight portable work table- like the one Island Tractor's welder is on- with a piece of 12 gauge plate sitting on it.
/ Makeshift welding table #7
Now we need a new line of 'you might be a swamp yankee...' jokes.
I forgot to mention that the Mark I version Swamp Yankee welding table was the same portable work table with a piece of aluminum foil covered particle board.:eek::laughing: Worked fine for the first two hundreds of a second until the arc blasted right though the four layers of foil.
/ Makeshift welding table #9
You might be a Swamp Yankee if you use a metal 55 gallon drum for a welding table?
Works for me. Have a piece of bed frame angle iron welded on the edge for a flat surface and a place to clamp the ground. Have a bearing outer race welded to the other end as a stinger holder. The top is at a comfortable working height and it's easy to move - just tip it and roll it to where the action is.
-Jim
-Jim
I've seen 55 gallon drums used as cutting tables which makes a lot of sense, especially with a slatted top and a bit of water in the bottom. Making a convertable 55 gallon drum that could serve as either a welding or cutting station would be great. It could even serve as a shop trash can when not needed for metalwork.:thumbsup:
2016 FREIGHTLINER CASCADIA 125 6X4 T/A MID ROOF SLEEPER TRUCK TRACTOR (A59906)
2016 FREIGHTLINER...
Sakai SV505 Vibratory Roller (A53317)
Sakai SV505...
60" HYD BRUSH CUTTER (A52706)
60" HYD BRUSH...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
John Deere 1025R (A53317)
John Deere 1025R...
2020 FORD F-150 XL CREW CAB TRUCK (A59823)
2020 FORD F-150 XL...
