MF 231 questions
   / MF 231 questions #1
tomstewart
Richmond, TX
MF 231
I have recently came into a MF 231. I have never owned a Massey. I have owned several tractors. I have ordered a parts and service manual, but would like to start some projects on the machine and would like to ask a few questions pls. The tractor looks rough but runs fine.
1. There are two handles for lowering and raising the 3 point. I assume that one is for draft and one to raise and lower. I cannot read the writing and do not know how to set them. One has a round knob and the other has a square plastic knob on the end. I think I know what draft is, but I don't need it. Where would I set these knobs so that one of them operates the three point (raise and lower)?
2. Is the oil fill location on the left hand side of the tractor (from a seated poistion) near the front? This fill tube is located just in front of and a little higher than the oil filter, but looks to be a resevoir for something. It doesn't just fill into the block in other words.
3. The power steering hoses were broken off at the steering cylinders on each side (all 4 of them) and the powering steering obviously doesn't work. I will get 4 new hoses pressed and reattached. Will this system bleed itself after filling with oil? What oil do I use? Anything I should know before replacing the hoses and filling with oil?
4. SAE 30 or 15w40 engine oil?
5. Guages....Tach is broken...Temp guage I do not like and the fuel guage MIGHT work as the needle appears to be floating around....I don't need a fuel guage. I will buy a temp and oil pressure guage and a new tach....I know how to trace down and replace the tach and tach cable....I know how to replace the temp guage....The tractor currently does not have a oil pressure guage and I do NOT know where to make this connection on the engine. Can you tell me where to connect?
I picked the tractor up Friday. It has been sitting for quite some time, but it fired up first try....I now have all of the skin off for repainting....The fenders are rusted beyond repair. I have searched and searched for replacements and cannot locate for MF 231...Any suggestions for online purchase?
I am going to spray down with degreaser and pressure was the frame for new gray paint.....Anything I should be aware of before hitting with pressure washer (starter and alternator should be avoided I assume)???????
Thanks for your help. I really like this site.
Tom
   / MF 231 questions #2
Sorry no answers yet. Maybe someone will reply. I am looking at a Massey also so I will follow this. Is yours a diesel? How many hours?
   / MF 231 questions
HJCtractor:
I got the service manual and operator manual in and they answered all of my questions and many more....I was trying to get a head start on the process of rehabbing this tractor... feel free to ask me anything you want now that i have the manuals and gave gone through it, I feel fairly confident.
TS
   / MF 231 questions #4
I have had a MF250 about 14 years. Very satisfied with it. Parts are out there but can take some serious looking. Engine parts not too hard, sheet metal a little harder to find. Internet is first place to start of course. There are numerous tractor parts houses that have printed catalogs, but not much presence on the web. Just takes some looking. Like all tractors, parts can be pricey. Change all fluids AFTER pressure washing. Also, check or replace shift leaver boots, probably the most common source of water in trans. Good luck with your project:thumbsup:
   / MF 231 questions #5
G.day tomstewart .
check out agriline they are in the u.k they have reasonable Quality parts at the right price also try BARECO . SPAREX .
I think the 135 /148 mudguards are the same just check with them first.
Hope this helps .
See Ya .
Hutch.
   / MF 231 questions #6
Tom, I just joined you. Bought a Massey 240 last night so I may be picking your brain soon! I ordered the manuals from Ebay
   / MF 231 questions #7
We ought to be sharing our manuals....I've posted a thread on that just a little bit ago, but this thread gives the reason why....maybe some moderator can figure out how to get something set up.
   / MF 231 questions #8
I have a MF 231 with a shop manual .. the tractor is 42 HP, rated at 38 HP on the PTO... the guy i bought mine from told me incorrectly it was 48HP tractor. i like it, though the tach on mine is broken, and lights do not work. parts are pricey, but overal it has been a good tractor.
The tractor i have was built in Poland, but sold in USA.
If you get your tack to work, let me know what you did. I puchased an aftermarket tach on ebay for $30, but still can not even get the new one to work.
2013 Chevrolet Van (A55973)
2013 Chevrolet Van...
Teak Wood Dining Table (A59231)
Teak Wood Dining...
2006 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A59575)
2006 INTERNATIONAL...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A55315)
2023 NEW HOLLAND...
Sellick S80 (A60462)
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A56438)
2011 Ford F-550...
