Throttle Lock/tension
/ Throttle Lock/tension #1
fastdriver1
Gettysburg PA
John Deere 3320
3320 JD having trouble keeping throttle at PTO speed. Lever seems to slip back and lose RPM's. Anyone had this problem and found the solution? Tension/Friction nut/bolt?
/ Throttle Lock/tension #2
:welcome: to the forum.
There is a friction disk to adjust, I believe.
And it is located right at the pivot point of the throttle lever. Tighten the nut to gain some friction.
Thanks for the response. How is that pivot point accessed? Remove the rear panel? Dash Panel?
And thanks for the welcome. I have been 'lurking' for some time.
/ Throttle Lock/tension #4
parts key # 6 is what beenthere is referring to tighten.
Thanks, got that, just don't know how to get to it. Do I have to remove the cowl or instrument cluster?
/ Throttle Lock/tension #6
Will need to remove whatever it takes to get to the nut to tighten it. A little exploration and being careful not to break any tabs along the way.
jdparts may show the different parts that make up the 'covers' that need to come off, at least enough to reach the nut. Hopefully can reach up through the fuze cover door, or in beside the fuel tank.
/ Throttle Lock/tension #8
I just had to do it to my 4300 today. I had to take the screws out for the trim around the instument cluster and lift it to gain access. Took me about 10 minutes.
The 'torx' screws around the right side green trim? I'll try it this weekend. Thanks.
(APPROX. 12) 13' 2" - 26GA R-LOC IVORY TIN (A63290)
(APPROX. 12) 13'...
2013 Volvo VN Semi (A64047)
2013 Volvo VN Semi...
2013 FORD F250 (A60460)
2013 FORD F250...
John Deere 8400 Tractor w/ Duals (A64047)
John Deere 8400...
Hobart Champion 16 AC/DC Engine-driven Welder and generator (A63118)
Hobart Champion 16...
2015 TEXAS PRIDE GOOSENECK (A63569)
2015 TEXAS PRIDE...
