First time towing checklist
/ First time towing checklist #1
lhfarm
Central Indiana
NH TC40DA
Just purchased an 18' car hauler for hauling my 1949 Farm Jeep. The dealer is a couple of hours away, just off I-65, so most of the trip will be interstate driving. I have a 2007 F150 V8 4x4 with the tow package. I purchased a Tekonsha P-3 brake controller and have it installed, but never had a trailer hooked up.
Since I've never towed a trailer with this setup, I'd like to know the steps I should take before I tow the trailer off the lot and other preparations for towing the empty trailer home. Do you have a checklist for the first time you tow a trailer?
Thanks,
/ First time towing checklist #3
Get the dealer to help you out, they are suppose to be experts. Some things I check, make sure the ball is tight, tire pressures, saftey chains (crossed under the hitch) trailer lights, test the brakes before leaving, make sure there is a pin installed on the ball latch. I usually try and do a walk around after I've gone a few miles. Thats all I can think of know.
/ First time towing checklist #4
Check your mirrors and adjust as necessary.
Trailer jack
Blocks
Practice backing up and turning on lot
Take a picture cause otherwise it didn't happen:laughing::thumbsup:
/ First time towing checklist #5
Have the proper lug wrench, a bottle jack, some blocking, make sure the tires are at max psi on the trailer, check the spare also, check the lights and brakes, ect.
First time towing any trailer re-torque the lugs after 100 miles. I usually do them after about 20 then 100 also.
As for the truck all the normal before you drive stuff applies but pay close attention to the tires on it also. They should be inflated properly.
Good basic tool kit with some stuff to fix wiring is also a good idea.
Chris
/ First time towing checklist #6
Look on your state DMV website. They should have the Commercial Driver Handbook. There is a comprehensive pre-trip inspection in there; it is a required part of the test for Class-A and Class-B commercial drivers test.
Start at the hitch. these are not in any particular order, but I start at the hitch, and walk around till I get to the hitch again. I also look at like my EMT stuff, I am always looking for DCAP-BTLS(Deformities, Contusions, Abrasions, Penetrations, Burns, Tenderness, Lacerations, Swelling). While we check patients for many more things, we are constantly on the lookout for those things.
I look for: cracks, broken or failing welds, broken wire, dangling wires, broken or damaged lighting, missing parts, weather cracking, black widows, etc.
My list looks long, but it only takes a couple of minutes. I do this any time I trailer, new trailer or those that I have had for a long time. This goes for my flatbed, utility, and 5th wheel RV.
I check everything, even if I have a helper(son, Dad, friend) helping with the hookup.
- Before you hitch, check the ball. Is it the correct size, and weight rating(have seen a 2-5/16 hitch on a 2" ball towed over 1000 miles...)
- Hitch up
- Check that the hitch latch is properly latched
- Check that the hitch latch is locked(I use a Masterlock instead of the hairclip)
- Check your safety chains; are they crossed and secure?
- Check the brake-away cable; is it secure to the truck?
- You can check the break-away; pull the pin and try move the truck; the brakes should work on the trailer.
- Check the cable harness and connector; it it properly inserted in the receptacle on the truck, and free of any pinch point, not dragging
- Start down the left side of the trailer...
- Check the trailer jack; is it raised, and if applicable, in a locked position?
- Look at the wiring along the tongue; is it in good condition?
- As you walk around, you are looking at the frame of the trailer, above and below for cracks and broken welds.
- As you get to the left front, are the marker lights working, in good condition, and properly attached?
- Approaching the fender, is it properly attached and covering the wheels?
- Check the tires for wear and proper inflation
- Check lugnuts visually and verify they are torqued properly, and look for cracking of the rim around the lugs
- As you get to the left rear, are the marker lights working, in good condition, and properly attached? Look below to make sure the wiring is in good condition, and nothing is dangling below the trailer
- At the left rear corner, are the brake/tail lights working, in good condition, and properly attached? Are the wires secure, and not and dangling?
- While at the left rear corner, is the left ramp stowed correctly, and secured properly?
- Is the license plate on correctly, has correct tags, and illuminated correctly by tail light or separate light?
- Check and verify operation of any rear marker lights. Verify wiring is secure and not dangling
- Start up the right side...
- at the right rear corner, is the left ramp stowed correctly, and secured properly?
- At the right rear corner, are the brake/tail lights working, in good condition, and properly attached? Are the wires secure, and not and dangling?
- As you work up the right side, are the marker lights working, in good condition, and properly attached? Look below to make sure the wiring is in good condition, and nothing is dangling below the trailer
- As you get to the right front, are the marker lights working, in good condition, and properly attached?
- Is the spare tire attached to its mount properly?(Mine is mounted on the right front of the trailer).
- Check the spare tire for wear, proper inflation, and check rim for any cracks, check around lug holes
- Check the jack, lug wrench, and chocks(the jack and lug wrench from your tow vehicle probably do not fit the trailer...)
- Check flares and/or warning triangles(safety markers in case you do break down)
- Now the trailer is verified, check you brakes and controller, per instructions included with your brake controller and/or trailer brake manufacturer.
- Double check everything after the first 25 miles. If new trailer, double check, especially lug nuts, at the manufacturer recommended mileage.
- Don't forget to do a similar walk-around on your tow vehicle.
Edit: I forgot...
- While checking the tires/rims on either side, look underneath at the spring, shackles, ubolts, and perches. Cracks, breaks, loose bolts/nuts, overall condition. You should also be able to see the wires to the brakes on the other side... Are they in good shape, not dangling etc
/ First time towing checklist #8
Unless I missed it, no one mentioned tongue weight. A rule of Thumb is that 10% of your load should be on the tongue. The receiver on your truck should have a placard that lists not only total towing weight by max allowed tongue weight. Buy or borrow a tongue weight scale and adjust your load to insure you don't have too much or worse too little weight on the hitch. Too much and the rear suspension of the tow vehicle id compressed which also means that the front end is too high. Conversely too little tongue weight can be exciting to say the least.
By the way Robertn good checklist.
/ First time towing checklist #9
I think an adjustable ball mount is a good thing to bring with you when picking up a trailer or other unfamiliar load. Since you are buying the trailer from a dealer, they should have mounts for sale, so you can get one with more drop/rise from them if you find it necessary. I carry the Curt D900 and a straight mount (no drop/rise) when I am not sure what I'll need.
Thanks for all the great info and links. One more question. Since I've never used the brake controller and since I won't be hauling anything, can I start by setting the voltage to a low level? The manual says to set it at 6.0, drive up to 25MPH and hit the manual control. If the wheels lock, lower the voltage, if they turn freely, raise it. Since I'm not sure I'll have access to a helper or even a good place to test for wheel lock-up, I was thinking of setting the voltage in the 4.5 to 5 volt range.
Or does someone have a method for adjusting the controller for the first time pulling a trailer?
/ First time towing checklist #11
Best way is lockup test. That pretty much is the way to adjust the controller for the first time pulling a trailer.
Remember too, this will not be like a travel trailer, where it generally weighs the same every time. You may be empty, may have Jeep(~2500lbs+/-), a tractor, lumber...
You'll get a feel for it over time and use, but the lockup test is what the brake controller and brake manufacturers(it is in the Dexter manual) recommend.
/ First time towing checklist #12
The real reason they suggest doing that test is to make sure the brakes are working correctly. You can adjust your brake controller easily while rolling down the road.
When I tow with my Suburban, I change mine when I get on/off the highway, because its controller is not fancy and just sends voltage when you tap the pedal. Doing 30 MPH stop-and-go city traffic, a setting of 2 or 3 is good for my rig, but on the highway I turn it to 5 or so, then I turn it back down once I get on the surface streets again. When parking I usually set it on 0.
I think the Prodigy you have might make this kind of adjusting unnecessary because it is more sophisticated, but you can certainly dial in the brake strength you need without leaving black marks all over the road.
You mentioned not being sure where you'll test the thing once you pick it up. Ask the salesman for a good route back to the highway so you'll be on regular streets for a few miles first, passing a really big parking lot or two if possible. If you want, just scout yourself out a good route before you arrive at the dealership. It is really helpful to know a couple of spots you can stop before you hit the highway.
If you are totally new to towing, you might want to bring an experienced friend with you for the long trip back. Parking a trailer is a whole different process too, don't run over your wife's car or anything. A few tall cones can be very helpful if you have to back your trailer up without help.
/ First time towing checklist #13
Good point about parking.
I'd strongly suggest in investing in a trailer dolly.
You can toss it in the back of the truck.
And some sort of 3pt trailer mover.
I picked up the trailer this morning and both truck and trailer performed well. The dealer helped me do the brake test in his lot. Thanks again for all the good advice. I'm now going through all the messages on tie-down methods. More questions later!
Thanks
/ First time towing checklist #15
straps, wheel chocks.
set brakes on a back road.. make sure tounge weight is good.. check tire pressure.. make sure you have a jack, spare and tire iron..
