TBN HTML code issues - Admins this is directly for you!!!!
Status
Not open for further replies.
   / TBN HTML code issues - Admins this is directly for you!!!!
MUCH BETTER NOW!!!!!
:thumbsup:
Thanks for fixing it!
David
   / TBN HTML code issues - Admins this is directly for you!!!! #12
Whats this ... I'm getting this 7 out of ten times and can not log in.
Todd,
Scroll down, the problem is simply spacing. everything you want (except the ads) is there (mostly, some links dont work).
Also click on "keep me logged in" :) so you do not need to log in again.
I was having the "white space" issue really bad earlier this week, and I seemed fixed for me...
Hmmm...
David
   / TBN HTML code issues - Admins this is directly for you!!!! #14
Thanks, I never did scroll down ... just kept checking back until I could log in.
   / TBN HTML code issues - Admins this is directly for you!!!! #15
Everything was fine until 5 minutes ago, but now the white space at the beginning has reappeared. Eventually TBN will correct the problem as was previously stated.
   / TBN HTML code issues - Admins this is directly for you!!!! #17
   / TBN HTML code issues - Admins this is directly for you!!!! #18
There is a spacing issue once again.
   / TBN HTML code issues - Admins this is directly for you!!!! #19
I have never had to work with software and am so glad for that. When I worked as a carpenter and something didn't fit right I could apply one of the "3-P" methods (Press, Pry, or Pound) because it was easy to SEE the problem. I know they will get this fixed, just wish I could hammer on something for them to make it work !!
   / TBN HTML code issues - Admins this is directly for you!!!! #20
don't get it. haven't seen any problem. does it make a diff I'm on a mac?
Status
Mayrath 10 x 32 Auger (A50514)
Mayrath 10 x 32...
John 4 x 4 cart (A50323)
John 4 x 4 cart...
2015 Polaris Sportsman 570 SP ATV (A50514)
2015 Polaris...
30' Harvest Hand Head Cart (A50514)
30' Harvest Hand...
2005 FORD F650 4X2 XL SUPER DUTY FUEL/LUBE TRUCK (A51243)
2005 FORD F650 4X2...
2014 Gillig 31+56 Low Floor Bus (A50323)
2014 Gillig 31+56...
