TBN HTML code issues - Admins this is directly for you!!!!
Status
Not open for further replies.
/ TBN HTML code issues - Admins this is directly for you!!!! #1
MossflowerWoods
Super Member
Fredericksburg, VA
Kioti DK50SE HST w/FEL, Gravely 60" ZTR Mower. Stihl MS290 (selling), CS261, & FS190 + Echo CS400 & 2010 F-350 6.4 PSD snowplow truck
Muhammad & crew,
Dudes, you need to roll TBN back to the last known good code and start over. The "white space" issue is 100% something swanky you tried to do with automatic ad stuff and it is killing this forum.
The simple fact that when the problem occurs I cannot attach pics makes the forum almost unusable.
I LOVE TBN, and you deserve and need to make a good living, so you've gotta have ads, I'm cool with that. But there is a serious problem and you need to fix it ASAP.
Roll the forum code back. Take out the new additions.
Yesterday I was at "work" and the systems there that can access the internet have rigid security and access policies and TBN worked every time, and the block of ads typically between the header and the content was ALWAYS Marked as not allowed due to security. That is EXACTLY where your bad code is.
Stop chasing your tails. I've been in high tech for 30 years and typically when a system suddenly starts behaving erratically, it is whatever YOU just changed.
This is no different.
Please fix TBN. I am addicted to TBN and I NEED it back!
Respectfully,
David
/ TBN HTML code issues - Admins this is directly for you!!!! #2
And....fix your email notification issues that are now going on SEVEN months
/ TBN HTML code issues - Admins this is directly for you!!!! #3
David, appreciate your tactful message and willingness to help them with this issue.
/ TBN HTML code issues - Admins this is directly for you!!!! #5
Look Muhammad...You are being hacked...this has to be a hacker at work or else you need to close the site down for however long you need to clear this up...You will lose members I fear...Just sayin' Good Luck.
/ TBN HTML code issues - Admins this is directly for you!!!! #6
I posted 2 weeks ago my norton blocked this site twice for hacking.
/ TBN HTML code issues - Admins this is directly for you!!!! #7
We're in the process of working this out. If we had made a change, we would have rolled back instantly. It's nothing so simple, unfortunately.
But we do have a plan and we're going to be implementing the plan very soon.
Ibrahim,
I understand. I'm pretty certain it is in the routine that auto selects which ad to display. Somebody hacked it, or somebody has inserted "bad" ads into the hopper.
I love TBN and I want it to work.
David
/ TBN HTML code issues - Admins this is directly for you!!!! #9
Yep, that's where we are looking. We're also looking at redesigning and updating some of the code so we aren't reliant on things that can get interfered with like that.
Excellent!
I'm glad you guys take such good care of TBN.
Thanks,
David
MUCH BETTER NOW!!!!!
:thumbsup:
Thanks for fixing it!
David
/ TBN HTML code issues - Admins this is directly for you!!!! #12
Whats this ... I'm getting this 7 out of ten times and can not log in.
Todd,
Scroll down, the problem is simply spacing. everything you want (except the ads) is there (mostly, some links dont work).
Also click on "keep me logged in" :) so you do not need to log in again.
I was having the "white space" issue really bad earlier this week, and I seemed fixed for me...
Hmmm...
David
/ TBN HTML code issues - Admins this is directly for you!!!! #14
Thanks, I never did scroll down ... just kept checking back until I could log in.
/ TBN HTML code issues - Admins this is directly for you!!!! #15
Everything was fine until 5 minutes ago, but now the white space at the beginning has reappeared. Eventually TBN will correct the problem as was previously stated.
/ TBN HTML code issues - Admins this is directly for you!!!! #18
There is a spacing issue once again.
/ TBN HTML code issues - Admins this is directly for you!!!! #19
I have never had to work with software and am so glad for that. When I worked as a carpenter and something didn't fit right I could apply one of the "3-P" methods (Press, Pry, or Pound) because it was easy to SEE the problem. I know they will get this fixed, just wish I could hammer on something for them to make it work !!
/ TBN HTML code issues - Admins this is directly for you!!!! #20
don't get it. haven't seen any problem. does it make a diff I'm on a mac?
Status
