Cat 2 Quick Hitch Dimensions
/ Cat 2 Quick Hitch Dimensions #1
clee4020
Mississippi
Kubota M9540 HD 4x4
I'm sure this has been discussed before. I have a bushhog and hay forks that have been used/abused and need a little TLC. While I was reworking them I was gonna adapt them to a quick hitch. Got 3 tractors, JD 4020, JD 7330, and Kubota M9540. Currently none of the tractors have a quick hitch, but would like to get a couple. The 4020 and 9540 can hookup to all implements, but the 7330's arms will not go in enough to hookup some implements, so maybe the 7330 is Cat 3N. All 3 have the same diameter pin holes (Cat 2). I do have a Harbor Freight quick hitch, but it seems a little light duty for some tasks, so it rarely gets used. I don't think that HF uses the industry standard demensions (if there is one). I found a link to JD quick hitch measurements and was wondering if this is just JD or for all quick hitches?
Hitch, dimensions
I guess I may not have been clear. My question is there a standard measurement/dimension for Cat 2 quick hitch?
/ Cat 2 Quick Hitch Dimensions #3
Yes there is a standard but that does not mean everyone follows it or that all implements are compatible with the standard. Unfortunately I am on the road and don't have easy access to the dimension right now. If no one comes up with them I will get them to you tomorrow when I get back. I would guess that what you have in the link is correct however. Your JD 4020 has cat 2 pins?
Yes, all 3 tractors have Cat 2 pns.
/ Cat 2 Quick Hitch Dimensions #5
The standard is ASAE s278.6, but - just as important - are the old implements you intend to rework also Cat2? Or are they Cat 1 that you're going to attempt to stretch to Cat 2 dimensions. I ask, because - whereas that JD Quick-Coupler is a true Cat 2 hitch - the hook placement is incorrect for Cat 1 implements.
//greg//
Yes, they have Cat 2 pins, just not in the right location for quick hitch.
/ Cat 2 Quick Hitch Dimensions #7
That was my point. Just adding bigger pins doesn't give you a Cat2 implement.
Width A is about 26" on Cat1, but 32" on Cat2. Height B is about 18" on Cat1, but 24" on Cat2. So you can see what will happen when you back up a Cat2 Quick Coupler to a Cat1 implement, regardless of pin size and/or bushings used. Yes, you can try to weld on lift pin and top link hole extensions, but I question the resulting strength under load.
I suggest that you consider repairing/restoring the implements in their Cat1 configuration, but consider something more like Pat's Easy Change system for the lower lift arms instead of a rigid 3point quick hitch. I was where you were at one time, and started out with a Harbor Freight quick hitch too. I was always getting off the tractor to fiddle with getting the toplink hooked properly anyway. So I eventually sold the QH for scrap - went to the PEC system - and never looked back.
//greg//
//greg//
Thanks, for info. All implements are what I consider Cat.2., they are relatively large, medium to heavy duty, just not set up for QH. Some of the pins spacing are just shy of 32" or just over 32". I think I could bring them in or out an inch or so and it should be good. I agree with you on PEC. Just put a set on the M9540 and got to use them with a JD 6 row planter recentley (which WAS almost impossible to hook up to). Since my M9540 had the sliding lower arms, Pat built me a set of new slides and they work great. Either way, I've got to do some rebuilding of a few implements.
Measured my Harbor Freight Cat. 2 Quick Hitch and it is approx. 35" between lower arms. I have been leaning towards buying a JD Cat. Quick Hitch since most of the bigger implements are JD and are set up for Cat.2 or Cat. 3 QH.
CAT 963 4-in-1 Bucket (A68134)
CAT 963 4-in-1...
Hoelscher 110 Bale Grapple (A64126)
Hoelscher 110 Bale...
16in. Bucket with Teeth Excavator Attachment (A68183)
16in. Bucket with...
2017 Caterpillar DP70N1 15,500lb. Straight Mast Diesel Forklift (A64194)
2017 Caterpillar...
2011 HUTCHISON CRUDE TRAILER (A67714)
2011 HUTCHISON...
DYNAPAC  CP271 PNEUMATIC ROLLER (A67714)
DYNAPAC CP271...
