Many hour Kubota
/ Many hour Kubota #1
devildog1
Up-State New York
Grand L 3540 HST-3, R4's
Gee I wonder if this qualifies for a long life tractor? Never the less do you think this shows that Kubota goes the distance?
Kubota Farm Tractor
DevilDog
/ Many hour Kubota #2
Kubota Farm Tractor
DevilDog
Tractor looks to be mowed around,she may be about done in:D but if that true hrs be nice to get the same out of mine....
/ Many hour Kubota #3
Probably a typo, especially for a 245. Great tractor and would likely do the time if well cared for but that's a lot of hours for actual use.
/ Many hour Kubota #4
13173 is a bit much. I suspect a case of decimal creep?
/ Many hour Kubota #5
Might be hard to tell; my old B8200HSTD was a 1986 model; it only counted to 999 hours. So there is no real way to verify that hour total, unless the owners took exceptional records. That proof/hour meter would have rolled over 13 times...
In the past here on TBN, there have been discussions relating 5000 hours being a reasonable goal for a HST tractor. I could certainly see, with proper care, how that gear tractor could rack up high hours, if well taken care of, and depending on the jobs it was used for.
Look at some of the old Farmalls, Ford N series etc that have a bazillion hours on them.
That would not happen for me though. I had the Kubota for 12 years, taking care of my 5 acres, parents 8 acres, and a little side work. That still only came to 800 hours on the meter(60-80 hours a year). Over the last couple years, I have put more time in with my NH TC40D, mostly because of adding a 3pt splitter and pto chipper recently.
/ Many hour Kubota #6
I don't know, I have 46 on my Kioti and I have used it for about a month.
and I don't use the tractor much. Compared to some people.
James K0UA
/ Many hour Kubota #7
I bet the hours are a typo. But that's a very good old tractor! And looks in good cosmetic shape. I had a L245 for about 20 years and could not kill it. Put about 5000 hours on it with a 5' bush hog.
/ Many hour Kubota #8
If that time is correct, then they took exceptional care of it. Probably good for another 13k. Our B5100 has 1100 or so and it looks beat, but runs great. We are likely the 3rd or 4th owners. Looks like the Kubota design team had a poster of the Farmall Cub on the wall when they layed ink to vellum. Not a bad choice.
/ Many hour Kubota #9
I'll bet the new 2012 plastic models won't make it to 13K hrs.:(
/ Many hour Kubota #10
Yeah it does. My old L245 wasn't offset like that and mine looked like **** after 5000 hrs! Have never seen a Kubota like it. Kind a cool though. :thumbsup:
/ Many hour Kubota #11
Looked at an 8950 a little newer but as of this past weekend it had 8956 for hours and untouched except a clutch.
/ Many hour Kubota #13
My Dad's last tractor was a Fiat 540 DT Special that he bought new in the early 80's. It was a 54hp tractor. The DT referred to the fact that the tractor was a 4WD and the "Special" meant it had hand PTO clutch, as opposed to the 2 stage clutch on the non-Special models.
When dad sold the farm, and ultimately the tractor, it had 8885 genuine hours. It was still a great tractor and had heaps of life left in it.
Dad used to rack up around 500 to 600 hours per year. He had looked after the tractor in line with his philosophy that "grease and oil is cheaper than spare parts."
It is quite conceivable that the Kubota in question could have clocked up 13173 hours, if it has been well maintained.
2023 John Deere XUV 825M S4 (A60462)
2023 John Deere...
Unverferth 632 (A64119)
Unverferth 632...
Towable Dual-Line Pipe Road Crossing Trailer (A63689)
Towable Dual-Line...
2018 FREIGHTLINER M2 FORESTRY UTILITY BUCKET TRUCK (A63276)
2018 FREIGHTLINER...
LOT OF METAL GATES (A63291)
LOT OF METAL GATES...
