Buying Advice BX vs B for mowing
/ BX vs B for mowing #1
ChetB
AL
Kubota BX2660
From reading threads, I've gotten the impression that the BX line is better at mowing than the B series. Is that true and why?
I've just bought 5 acres. The whole thing is a hill and one side is somewhat steep, but don't think it will be a problem.
The primary use will be mowing, but we will be building and landscaping soon. Also, I hope to smooth out some of the bumpy field over time.
I have looked at used BX2200, BX2350, BX2360, B7500, and B7800 (as well as a John Deere 2305 and 2210). I'm not sure what all I will use it for, but I want a FEL in addition to a 60" MMM.
Thoughts? Suggestions?
/ BX vs B for mowing #2
If you're cutting on a hill , get rear spacers on she'll be on her side
with you hanging on too ! The BX is too narrow in the rear . Get a
Dealer to bring something out for a demo .
/ BX vs B for mowing #4
Yup. imho, the B with the spacers is equally stable. I'd spring for them, even though GAG!!! The price!!! But, safety first.
/ BX vs B for mowing #5
I have a b2920. It would be fine for mowing open areas, and i use mine on very steep slopes a lot with no issues. You don't get turf damage if your not in 4wd, in 4wd very tight turns tend to dig up grass with the front wheels, small turns are fine. I wouldn't use the b for mowing tight areas with lots of obstacles, its maneuverable, but much larger than the bx for that job. I use a smaller jd for mowing. The b will likely be better for all non mowing tasks than the bx due to size a d weight.
/ BX vs B for mowing #7
I have a 2660 and am very pleased with the 60" mmm. I also have the 48" rear Brush Bull, Woods mower which I have used very little. The BX did handle it well. I remove the FEL and any rear implements and just run the mmm when mowing. It is much more stable on a slope in this configuration. I'm a chicken and only run up and down the slopes right up and down the fall line. That has worked very well on some pretty good slopes. I have been very pleased with my BX. It has plenty of power. More than enough actually as I run out of traction long before I run out of power. I guess the extra power does no good if you can't put it on the ground. That extra power does go to the PTO though.
This is my first tractor and initially I was reluctant to remove the FEL/mmm etc. I found it to be a snap. I can have the mower off in a couple minutes and back on in 5. The FEL is 3 minutes off and probably the same back on.
I've been very pleased with my BX, BUT, if I was starting over, knowing what I know now I'd give the B a really long look. My only problem with the BX is lack of ground clearance in the gardening dept, but I'm doing a lot of that now,so it is an issue.
/ BX vs B for mowing #8
My first Kubota was a BX2200 MMM FEL which I bought a bit over 9 years ago. The ground clearance was also an issue. I found out tractors can be traded just like cars which I had done often. I traded that BX to a B7800 FEL and RFM which I kept for 3 years before trading it and the BX1500 MMM that I had bought for two different Kubotas.
I believe the first Kubota is the trial Kubota to buy and better determine your actual needs and then go for the one that meets your needs best.:D
Life is to short to waste any of it on keeping the wrong machine when it's as simple as a call or contact to Barlows. They'll take the wrong one and bring you the right one with just a few signatures, it's only money and your peace of mind and happiness with a new tractor is more valuable than that ole money.:laughing:
Well, over the years I've signed 13 contracts with Barlows and have finally landed with 5 Kubotas to help me be the most happy. Working toward number 14 now and not saying there won't end up being 15 eventually when I get more paid down on this geared B2320 to send it on down the road for a B2320HST.
/ BX vs B for mowing #9
That's interesting. Sometimes, no matter how much we research, life changes. We find ourselves doing things we couldn't have foreseen. A piece of land comes up adjacent to ours and it requires logging? Didn't see that coming?
I had a BX and LOVED it, but quite unexpectedly, our gardening business and road stand sales took off, the little BX had to go. It simply doesn't have the ground clearance for serious produce farming activities, where the B does.
Yup, had to make that change myself, but unlike JohnThomas, I took my time, sold it outright, saved an additional $1500 over just trading it in, bought the B and moved on. JT is comfortable with what he does, and so am I.
Who is to say that life won't reverse those contexts in 5 years and I'll be looking at the brand, new, extra-ordinary, super, duper little BX again? Could happen. :laughing::laughing:
/ BX vs B for mowing #10
BP,
do you have a MMM or a RFM on you "B"? How's the mowing compared to your former BX? I'm considering moving to a "B" due to my increase gardening. And my arthritic hands just can't take much more hoeing.:( But I really love to hand hoe because it's so peaceful and uncomplicated. :)
/ BX vs B for mowing #11
I believe from my reading that the BX is used more for mowing because you can't do a lot more with it. It is more suited for mowing with less ground clearance.
How much of that do you WANT to mow? How much more are you going to get?
Thoughts:
To ME even a quarter acre around the house is more than I WANT to mow.
Big lawns are a marketing strategy for Scott's.
If you plan on mowing much more than 2 acres I'd say get a zero turn.
The B's beat the BX's in ground clearance, lift capacity and HST fan breakage. I've never had and don't plan to have a BX.
Don't trust everything JohnThomas writes because he lives at Barlows :) And despite saying he had kicked his Kubota trading addiction he continues to do so :) and very well!
I on the other hand am addicted to a backhoe on my B7610.
Suggestions:
You are probably looking at buying your first of many tractors. Properly taken care of they should last for a long time. If you decide on a tractor the "little B's" (< 30 HP) should do all you need for 5 acres. They are about 4' wide (good for getting thru gates), have over a foot of clearance, and a lift capacity at 24" beyond the lift point of > 1,000lbs (half ton) .
The BX's are all < 45" wide, have < 9" clearance, lift capacity of 670 lbs at 24" and much smaller front tires.
If you plan on moving much dirt, carrying ten 50lb bags of anything, picking up an old Freezer
or moving a log you'll need the extra capacity.
You can usually mow with the larger tractor, but you can't always lift with the smaller.
/ BX vs B for mowing #12
/ BX vs B for mowing #14
BP,
Did not have a MMM on the BX nor the B. Yes, RFM. Lawn mowing isn't all that important to me, priority wise. We have a yard, not a lawn. We're delighted to have nice grass, when it rains properly, but it just isn't a priority amidst the work we have to do out here. I'm very pragmatic about it all. Get 'er done, with the least amount of expense, time and effort. Hope that makes sense.
I also never wanted to put the fool MMM on, and MMM off, over and over again. Not what I wanted. Each guy does what's best for his own situation.
/ BX vs B for mowing #16
For whatever it's worth, I spent much of the last year obsessing over whether I should buy a BX, a B or a smallish L. My brand new B2620 was delivered just last Friday with a FL, 60" MMM, remotes and some other goodies. I promptly removed the loader and mowed a few acres of community property I help maintain. Trees, fences to mow around, a few hills. It does a fantastic job. Then I took her home, put the loader back on and moved some telephone poles that have been in my way for years. I looked long and hard at the BX25 & BX26 but couldn't be happier that I went with the slightly larger tractor.
/ BX vs B for mowing #17
have a B2920, found out when I bought it that with the 60" MMM you can NOT use wheel spacers for stability, they interfere with the anti scalp wheels on deck.
Told a friend not to consider a grass catcher with B2920 because if it doesn't cut it fine enough the first pass, go over excess cut grass a second time and it disappears, no need to catch or rake.
My B2920 is way oversized for my yard (takes about 15 min. to cut) but is right size for digging and fork lift use as well as my 400 feet of driveway snow.
/ BX vs B for mowing #18
That's a good tip on going over the cuttings a second time. I ended up doing just that on some of the heavier areas. I was also cutting grass that hadn't been cut yet this year. I considered renting a rotary cutter for the the first cut but the 60" MMM had no trouble at all.
/ BX vs B for mowing #19
I had BX25 with mmm. Was really pleased with the way it cut grass.
Moved up to a b2620 with mmm and cut as well as the BX. But zI can't
the grass as short as I want, because the clippings are really heavy.
I alao use a 5' rfm. Reardischarge. Very nice cut, but I can't cut as low
as I would like. I have watch to the rear when close to objests that
I don't want to hit with the rfm, or cut down, and alsoo pay attention
ro where I am going. With mmm, i can look down at mower
edges without haveing to look to the rear. That is a plus for thr
mmm in my book.
Also, if you store tractor inside: If it stsrts to rain, with mmm
you just run it inside and park. With the rfm, you will have to
unhook, before heading for shelter:thumbsup:
MILLER BIG 30 PORTABLE WELDER / GENERATOR (A63290)
MILLER BIG 30...
207271 (A52708)
207271 (A52708)
2010 Toyota 7FDKU40 7,350lb. Straight Mast Diesel Forklift (A60460)
2010 Toyota...
2016 John Deere Z535M Zero Turn (A63116)
2016 John Deere...
SECTION OF PALLET RACKING (A63745)
SECTION OF PALLET...
2005 Komatsu PC 200 LC (A60462)
2005 Komatsu PC...
