Oil & Fuel How much oil ???
/ How much oil ??? #1
Railbender
northwest Tennessee
kubota 5740 hstc-3
Anyone else run into this problem ? I have a 2011 kubota L-5740 hstc-3,
decided to change oil and filter for first time, went to dealer and told
them I wanted oil & filter and ask them how much oil I needed for this
tractor . They looked it up on computer and said 9.9 qts. I looked in my manual
when I got home and it also said 9.9 qts. I put 9.9 qts. in tractor and the stick
showed at least 1" above full mark. I had to drain almost 2 qts. out before
it checked to the full mark. Ask dealer about this and they said there were
two different oil pans on these tractors. Their mechanic said this 9.9 qts. was
if engine was completely DRY, other wise there would be a quart & one half
too 2 quarts trapped up in engine. Now when you change oil I thought you
were supposed to let it DRAIN completely. I had never heard of this before !!
Why would Kubota not mention this in manual ? How about all the other
fluid levels ? Can you depend on them or not ?
/ How much oil ??? #2
Got your PM but I assumed you meant Owning/Operating in the Kubota section of the site :mad:
When I did mine this past winter I only put in around 8 liters. I don't remember what the manual said it took but it was more. The manual is only a rough amount based on a completely dry engine as in brand new with never any oil in it.
I usually put in 3/4 the amount the manual calls for then keep checking it as I add to the proper amount. It's the safest and easiest way to do it.
I always prime my oil filter first as well. Yes I know it's on it's side but fill it half way with oil, let it settle for a few minutes then screw it on the engine. Your motor will love you for it. :thumbsup:
/ How much oil ??? #3
Did you pull BOTH plugs???????
/ How much oil ??? #4
I am guessing he only pulled the one drain plug if there were 2 quarts extra.. that is about right for what is in the other pan.
James K0UA
/ How much oil ??? #6
When I read his post I took it that when he said he looked in his manual he also checked to see how to actually change the oil :confused:
Well hard to say for sure, but the 2 quarts sounds like a lot to be just what is left in the galleys. I wasn't there, but that is what it sounds like to me.
Of course your method of the 3/4 fill and keep checking is prudent for any circumstance.:thumbsup:
James K0UA
/ How much oil ??? #7
James K0UA
I'd think the guy would have to see the two drain plugs unless he's blind in one eye and can't see out of the other :laughing:
It will be interesting to hear if he drained the two and your right. It would be the two quart difference if he didn't. :thumbsup:
/ How much oil ??? #8
Been more than one on here that only pulled one plug.
/ How much oil ??? #10
After reading the manual :confused:
Hey, if people can't see a 75 foot long semi, barreling down on them at 65 MPH, and pull out in front of it............anything is possible:cool:
/ How much oil ??? #12
He makes no mention of opening 2 drains so I made my assumptions!!!!;)
By the way - my 3940 calls for 8 qts and takes 8 qts give or take a couple ounces.
/ How much oil ??? #13
When I changed the engine oil in my LS, I got one plug out OK using a pipe wrench because I didnt have any allen wrenches big enough to fit. While the oil was draining, I took the plug to auto parts and got a fit for the allen head. When I took the other plug out which was really tight by the way, not more than 1/2 guart of oil remained. Unless the Kubota engine is a lot different than my engine, I cant see it being 2 quarts in that channel
/ How much oil ???
hey guys, I'm not an amateur at changing oil in these tractors or for that
matter in any machinery. I've been at it several years now, just had not run
into a manual that was that far off on the amount in any other machinery.
this was my point in asking the question. I had also never heard that there
could be as much as 1 to 2 qts. of oil left in a small motor like like this
after you let it drain properly !! Also that there was two different oil pans
on these tractors.
Just a warning too others that might not be as familiar with equipment
as you all are.
/ How much oil ??? #15
Will try that out on our next oil change. Is your Kubota filter a short one?
/ How much oil ??? #16
So did you remove BOTH drain plugs????
/ How much oil ??? #17
Yep. It's a short one. I've been priming my filters most of my life ad it DO make a difference especially during the initial start up after the oil change. Yes it might be a little messy but it's really wort it.
I must admit I've ever heard of two different oil pans on the Kubota Grand L 5740. I don't remember seeing any mention of it in the factory service manual either.
:confused:
/ How much oil ??? #18
on these tractors.
as you all are.
We are all just curious, did you pull both drain plugs or not? There are two halves to the oil pan and has has an island in the middle of the pan so that there is a place for the drive shaft that drives the front differential to fit through. So if you only pulled one drain plug there would be a fair amount of oil in the other half of the pan. Now I am not sure how much would be trapped on the other side if you did not pull the plug, but it would be a fair amount. The reason we want to know whether you did that or not, is to get an idea of how much would be left, so that the next person that comes along with this problem, we would be able to advise them better. That is all, we are not trying to make you feel bad or anything. We want to help people.
James K0UA
/ How much oil ??? #19
The reason we want to know whether you did that or not, is to get an idea of how much would be left, so that the next person that comes along with this problem, we would be able to advise them better. James K0UA
When I change mine, I am guessing that one side holds about 2 quarts by the difference in drain pan levels.
When I look in my book they show one style pan for the 3240, 3940, 4240, 4740 & one style for the 3540, 5040, 5240, 5740
/ How much oil ???
Yes I did take out both drain plugs. I thought I mentioned that I had previously
owned a kubota L 4200 some years back and it had the same divided oil pan.
I don't understand why a Kubota mechanic would say there was two different
pans and the manual does not . Or how this little motor could trap the 1 1/2
to 2 qts. of oil up in it.
There has got to be some other explanation for what they say it
holds ? Later
APPROX (23) 1" X 6" X 12"' & (12) 1" X 6" X 12' (A64281)
APPROX (23) 1" X...
2000 Ford F-750 Debris Truck, VIN # 3FEXF75H8YMA01188 (A65563)
2000 Ford F-750...
Caterpillar D4 Dozer Parts and Service Manuals (A63117)
Caterpillar D4...
2021 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2021 ASV RT-25...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
(INOP) 2013 KAWASAKI MULE 4010 UTV (A64280)
(INOP) 2013...
