Mowing Mowing with a B Series
/ Mowing with a B Series #1
marxman
North Eastern MA
Kubota B3200
All,
Currently I cut the grass around my house say... Just over 1 acre (i think) with a craftsman lawn tractor 42" deck. If I don't bag it takes about 2 - 2.5 hours. The lawn tractor is getting old and I would like a more efficient method (more fun) way to cut the grass.
Would people recommend the MMM say a 60" deck to mount to the B3200?
Does it do a good job of cutting? Is it worth the $2000 or so?
I like the idea of a zero turn, but without heading to a store like Sears and picking one up there a good one can be fairly expensive.
Also the area around the house is not a finely manicured lawn, it's just grass.
thanks
/ Mowing with a B Series #2
With a B3200 , you would go for a 72" . These are not cheap , because
they're machine model specific . Considered a rear attached deck ?
Easy to get secondhand , and sell on if you're not too happy.
/ Mowing with a B Series #3
I had for a week a bx2360 +60"mmm and as a mower it did a wonderful job on our hilly 3.5 acres, our new one is a yanmar ea2400 with a 60" rear mount and it did a great job in the trials and was abut $1500 cheaper than the mmm
version and I will be able to hang it over creek and drop off edges plus poke in under branch overhangs but you need to be wary and not forget it's out the back when turning. regards
/ Mowing with a B Series #4
I have a B3200 with rear finish mower. I would prefer an MMM. While the LP 1648 does a good job of cutting I can not get into tight places. I would only go 60 inches wide on the MMM for getting into tight places. I think the B3200 would do awesome as a lawn tractor.
I have places I need to back over to mow and trees to mow around. Would prefer an MMM to mow around the trees. The MMM is going to be cheaper than a zero turn of comparable cutting width.
Kubota MMM's in my experience are not that easy to mount and dismount. Definitely look at the drive over model.
/ Mowing with a B Series #5
This is my 4th mowing season with my B3030 and I love it, couldn't be better, I mowed the 3 years before this with a BX23. I mow about 100,000 SF in 1 hour 20 minutes. I have a really nice lawn that I take pride in. I have a 60" deck on my 3030 and really wish I went with the 72" deck, oh well. It is plenty agile and even with loaded tires on a fairly wet site the worst it does is leave tracks in a couple spots that disappear. I love it for mowing.
In terms of taking the deck on and off, I have heard lots of folks say they have trouble with it, I don't see what the issue is. It goes on fast and with little trouble for me, much easier than my BX23 because there's way more room under there to hook up the PTO shaft. It goes on way easier and faster then my BH.
My neighbor mows with a zero turn Scag, it is much much faster but the cut quality is indistinguishable and the Scag doesn't have a very powerful BH or loader.
/ Mowing with a B Series #6
I would suggest a zero turn rider vs a b series tractor if mowing is your primary need for this machine. You can't beat the speed and maneuverability of a zero. Every time I use my b2320, I leave some sort of damage on the lawn. You can be more careful, but again your trade off is speed of getting the job done. If you decide on zero turn, you have several choices with various price points and features. I just picked up a 1 year old scag turf tiger with a 72 inch deck, which is bigger than I wanted, and my mowing time went from 1.5 - 2 hours to less than 30 minutes. Plus, these things are fun!
/ Mowing with a B Series #7
If you have a septic system, I would think long and hard before mowing over it with a 1 ton plus tractor.
/ Mowing with a B Series #8
I have septic systems at home and 6 at my rental property. I wouldn't be concerned about driving anything over them if the ground isn't wet. I actually have driven very heavy equipment over them. No issues at all.
/ Mowing with a B Series #9
If you want to maintain a pretty lawn you might get frustrated mowing with the tractor. In sharper turns they do tend to leave some marks.
If you want to keep the grass in check and not worry about a blemish here and there the B's are an excellent tool. I cut 2 -tree riddled - acres with a 72" rear mower and I'm happy with the result. Keep in mind that I don't give the least manure if the tractor happens to mark up the grass. It never failed to grow back.
/ Mowing with a B Series #10
When we had our septic system installed, we were told once it settled not to worry about driving/mowing over it; another one of those with varying opinion things.
/ Mowing with a B Series #11
For just over an acre I would be looking mainly at the BX line and a B2xxx at the most. I mow 3 acres with a B2320 and I wouldn't want anything larger.
/ Mowing with a B Series #12
I agree with this. A BX series would be more than enough machine for your 1 ac.
/ Mowing with a B Series #13
I have an acre and a half and the BX with a 60" MMM is plenty big. And it does a great job
/ Mowing with a B Series #14
I have a B3200 with a 60" MMM and it does mow very well. The quality of cut is very good and if you have turf tires I don't think it will cause much damage in a dry yard. I have the r4 tires and a couple of wet areas an it will leave marks. The quality of cut rivals all of my neighbors. The $2000 is hard to stomach but it does make the tractor more maneuverable IMO. It is much easier to get on and off comparable to the bx series.
2016 CATERPILLAR 259D SKID STEER (A64279)
2016 CATERPILLAR...
Kubota V3600-E3-EG60 Diesel Engine - 3.6L - Tier 4i - Irrigation Pump Takeout (A63689)
Kubota...
Wacker Neuson EZ26 (A60462)
Wacker Neuson EZ26...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A63689)
2022 Greenworks...
2003 Toyota Tundra Extra Cab Pickup (A62613)
2003 Toyota Tundra...
2013 Komatsu WA320 Wheel Loader (A60352)
2013 Komatsu WA320...
