Comparison 4wd or 2wd Tractor??
/ 4wd or 2wd Tractor?? #1
shibaura_4043
Texas
Zetor 4341 Cab, Shibaura 4043
I am considering purchasing a new to me cab tractor probably in the 60-70hp range, I have found a couple nice NH 2wd cab tractors that im interested in... however I was hoping to get a few opinions from people with cab tractors in this hp range. Those of you with 2wd do you wish you had 4wd, and 4wd onwners how often do you need to engage 4wd? my little shibaura is 4wd and it comes in very handy especially dragging, but with a larger, heavier tractor I wonder if its really a necessity. thanks
/ 4wd or 2wd Tractor?? #2
I own a TN70DA It seems like I have it 4wd more than not
/ 4wd or 2wd Tractor?? #3
Flat Somewhat dry ground 2wd is okay. If you get on some slopes with a loader you are going to want 4wd real quick, just for braking alone.
/ 4wd or 2wd Tractor?? #4
I have an LS P 7010C (70hp) and with the front end loader on and loaded with dirt, it gets most of its traction from the front wheels. Granted I could increase traction with loading the tires but it is already in the 8500+# range and dents the soil pretty good without water. It is much easier to just use 4 wd since I have it. I think it would save money on traction losses when pulling ground engaging implements also to the point of paying for the cost in one farming season. You just dont loose much traction with it and it is much safer going down hill using the 4 wd locked in as you can then basically have 4 wheel or at least 3 wheel brakes. I dont know of too many 4 wd tractors with diff locks on the front.
I wouldnt buy any tractor without 4 wd. THey are just so much better than 2 wd. They are definetly not to be considered like 4 WD trucks that only help you get stuck more thoroughly although the same does apply if you do go down with one, you are thoroughly stuck. If you have an FEL and or a backhoe you can pretty much get out of everything short of quicksand but if you cant get unstuck using the 4 wd and FEL then be prepared to go get the big wench trucks or really big tractors/dozers
/ 4wd or 2wd Tractor?? #5
no matter what you own, you will find uses for the 4wd.
/ 4wd or 2wd Tractor?? #6
We have two tractors in the 70+hp range. One 4wd and other is 2wd. If all your going to do with it is generic farm work like move hay bales, plow and plant and such then 2wd will work. Most of us are hobby farmers and do many things with our tractors like dig, push over trees and mud work. We don't even get our 2wd out of the barn if mud is involved but when lifting is the objective then the 2wd is our choice. Most of the old time farms around us have large (100+hp) 2wd tractors and they pull 24' disks all the time. I'm not knocking or advocating 2wd tractors because they have their place on the farm. Being a hobby farmer as I am, all my machines from this point forward will be 4wd
/ 4wd or 2wd Tractor?? #7
I grew up farming in the flat lands farming with 3WD tractors and my brothers still use them out there, but we recently put a MFWD Massey Ferguson 375 out there for loader work and usually took one out to pull logs.
We might buy a used 2WD for bush hogging in the flat lands, but any new tractor will be MFWD/4WD, we use it on our hill farms every time we run them.
/ 4wd or 2wd Tractor?? #8
i live in flat dry areas.. thus 4wd is added expense for me.
if I did a ton of laoder work.. was in hilsl or loose areas.. i think 4wd might be an accessory.. :)
/ 4wd or 2wd Tractor?? #9
What is the turning radius of 2 vs. 4 wheel drive?
/ 4wd or 2wd Tractor?? #10
Probably depends on the tractor and may vary, but as an example, the Kubota M7040 2WD turning radius is 10.8' while 4WD is 11.8', both without brakes.
/ 4wd or 2wd Tractor?? #11
I would go with the 4wd over the 2wd unless if your using it for field work only. I have an oliver that is 2wd and having front brakes would be nice when you are using it for loader work. Find your self hanging on alot, as the rears will just slide in the grass. It does not take much to get a 2wd stuck. Once your front wheels drop down in to the muck your done. Two winters ago, i had to pull the tractor out every time i put hay in.
/ 4wd or 2wd Tractor?? #12
front axle width and wheel base will affect it too.
I have some 4 wheeled 2 wd tractors that will rotate a rear wheel.. of course they are rowcrop trikes.. but :) :)
/ 4wd or 2wd Tractor?? #13
Now that I have had a 4WD, I would never go back to a 2WD unless it was what I call a play tractor.
If you need 4WD, its needed and if it only bails you out 1 or 2 times a year, it is still worth having.:2cents::)
/ 4wd or 2wd Tractor?? #14
If your fronts are pushing or pulling you on reasonable ground with a front end loader you are way overloading the front end and tractors will not stand up to that abuse for a long time. The weight on the front end should not exceed the weight on the rear even with a full bucket. I have $3000 in final drives to prove this and it is why you see almost every farm with 100 head has either skid steers, or pay loaders and usually both. Even big tractors have light front ends compared to construction equipment. That being said I like the 4x4 for a lot of things and I too am guilty of not enough ballast but be warned it is a double sided sword. I have dug some god aweful ruts with a 2 wd tractor and not gotten stuck. I like the 4x4 real well just not for the front end loader.
thanks for all the quick replies... sounds like the same rule for compact tractors applies to the bigger tractors...My gut tells me to stick with 4wd because it has definitely been nice to lock in 4wd and not worry about getting stuck when puttin out a roll of hay or just operating in unknown terrain conditions. On the flip side I sure have seen alot of nice 2wd drive cab tractors for sale, but I suppose the versatility of a 4wd might be the reason I see more 2wds than 4wds for sale :). That being said I now have my eye on a couple of used 4wd kubota's an 03' L4330 4wd 700hrs(23,000 usd) and an 04' L3430 4wd 1100hrs(18,000 usd) they are a little smaller than I would like but I think the 4wd will help. Any opinions on which direction I should go? I'll be using the tractor for mowing, ocasional dirt work, puttin hay out, fertilizing, arena and roundpen maint. I might even start square baling a few acres. Im sure you get the idea basically most of the jobs I need to get done on the farm it needs to do it.
/ 4wd or 2wd Tractor?? #16
After 4wd, more horsepower is the typical discussion. Agreed, I'd never, again, have a 2wd tractor, just too many instances where 4wd makes the difference between continuing on and having a problem/difficulty. The right tractor choice keeps a smile on your face and sweat from your brow:thumbsup:
/ 4wd or 2wd Tractor?? #17
This is like the discussion between hst and gears. What do you prefer - there is no right answer - but a few weeks ago my neighbor was loading 5-6 ton spreader loads of lime using a skid steer and doing it faster than I could think about using the tractor loader and so much better. A bit later he was carrying 2 large baleage bales with it and then cleaning out the free stall with the bucket. Quick attach is a must and eaiser to change from a skid steer then a tractor. I'm thinking you would use a skid steer most to the time. Spend $7 - 8 thousand on a decent 2 wheel tractor and the rest on a skid steer. And no I don't own a skid steer but I really like the quick attach on the tractor if I ever get back friom the shop.
Bob
/ 4wd or 2wd Tractor?? #18
My neighbor in his 80's has made do with a 2wd 75hp tractor for the last 30years but it stays in the fields or in the barnyard, and he has to work with the conditions. Certain hills and slopes he can't go on unless its dry, etc... So it can be done, but it takes patience and knowledge for what you can do and what you can't today, or ever.
If you don't live on a dry plain, you probably will never regret getting 4wd. For me I'm crawling around on all sorts of slopes on clay and moving dirt so 4wd makes it possible.
Also if you have a Kioti dealer nearby, go check them out, the DK40/45/50 are a heavier tractor and have a strong loader for the money.
/ 4wd or 2wd Tractor?? #19
We use to only have 2wd tractor growing up on farm and made due,now I run 4wd and dont know how anything got done really cause it seems I stay in 4wd but also pulling bigger shredders and doing more loader work. I think it just seems like im not near as worried about doing some kind of work around farm,cause I know I can always use 4wd,it will either get it out or get it worse.
/ 4wd or 2wd Tractor?? #20
I've got three 2wd tractors and don't need 4wd. I use mine for making hay, shredding and dirt work in North East Texas. The larger 2wd tractors are hard to get stuck for what I'm doing.
2017 Ford F-150 Ext. Cab Pickup Truck (A61572)
2017 Ford F-150...
FUEL DRUM APPROX 150 GAL (A63291)
FUEL DRUM APPROX...
Caterpillar D5H Series 1 and 2 Dozer Service and Parts Manuals (A63117)
Caterpillar D5H...
Rogator RG1300C (A63688)
Rogator RG1300C...
2023 JOHN DEERE 550P LGP CRAWLER DOZER (A64279)
2023 JOHN DEERE...
Challenger MT900B series tractor service manuals (A63117)
Challenger MT900B...
