Comparison 4wd or 2wd Tractor??
/ 4wd or 2wd Tractor?? #21
My oliver i get stuck all the time in the mud. The snow wasnt so bad, i had good chains for it. My 806 is a much heavier tractor and even with junk tires that were almost completely gone it would do better in the mud then the oliver. It all came down to weight, how ever when i got that 806 stuck it was STUCK. Couple times my buddy and to come to the rescue with my dodge and 18,000 pounds worth of winch pulling power.
If your going to be doing any loader work at all, get hst. It is so much easier to make those little movements needed in loader work. With a gear tractor your going to be fighting your clutch all day, and imo is a pain in the arse. For a field tractor gear is fine. Like the other poster above said seriously look at a bobcat. I just recently got a t250 and i have done more work with it in a day then my tractor could even think about doing.
I've got three 2wd tractors and don't need 4wd. I use mine for making hay, shredding and dirt work in North East Texas. The larger 2wd tractors are hard to get stuck for what I'm doing.
thats kinda what i was thinking but I may pull the trigger on 4wd, this reminds me of buying my first new truck... I thought because 4wd was a bit more I could do without it to save the money, regretted that decision for 4 years until I finally decided to get my 4x4 dually! btw I live in north Texas too, where abouts are you??
/ 4wd or 2wd Tractor?? #23
I got the 4wd on the truck and I couldn't do without it. The good thing about the 4wd tractor is it would easier to sell the tractor down the road since everyone wants 4wd and a loader. You might pay more now, but you'll get it back if you ever sell it.
I've slopped around a lot of mud putting out hay, but haven't gotten stuck yet. I have gotten stuck before doing other stuff, but used the front end loader or pulled with the other tractor to get out. The 2 bigger tractors don't even have a locking rear end.
I'm in the Commerce area, how about yourself?
/ 4wd or 2wd Tractor?? #24
SELL???? hey buddy this is a family friendly discussion forum.. no curse words allowed here ;) :)
soundguy
/ 4wd or 2wd Tractor?? #25
soundguy
Ha ha, sorry about that, yes just keep adding to the collection.
/ 4wd or 2wd Tractor?? #26
I don't think a 2wd tractor would be so bad, as long as you have something else with a FEL and 4x4. If you are only getting 1 piece of equipment, I'd definitely make it a 4x4.
/ 4wd or 2wd Tractor?? #27
I think a 4wd tractor rides smoother in the field due to the larger tires. That's worth a lot to me. Growing up about 1 in 10 new tractors on the lots were 4wd, now that seems to be the other way around.
/ 4wd or 2wd Tractor?? #28
My JD 5225 4WD with 56 hp is just below the range you mentioned. But I've also owned a 2WD IH 45-hp 2400A. One of the few things I miss about the IH is the smaller turning radius - about 2 feet smaller. It was noticeable when I started mowing with the 5225, but I adapted to it. For you, I'd consider which jobs you want your tractor to do. For using a FEL, 4WD is much more efficient than 2WD, especially on uphill slopes. And 4WD can get you out of trouble that 2WD can't, like in soft- or wet ground conditions. For mowing/bush-hogging on flat-to-gentle terrain, 2WD works fine. And the smaller turning radius can be a blessing. 4WD can get you up steep slopes while mowing, especially if the grass is wet. I've never regretted upgrading to 4WD.
If you decide on 2WD, get one with a locking differential. Some tractors don't have that, but IMHO, it is a necessity.
/ 4wd or 2wd Tractor?? #29
depending on how they do the front axle, the tires won't be bigger in a 4x4 and neither would the turning radius. As a matter of fact, the turning radius can be tighter in a 4x4 because the front end pulls it around.
/ 4wd or 2wd Tractor?? #30
A couple years ago I decided I "needed" a tractor. I had in mind exactly what I wanted to. Four wheel drive, FEL, ROPS, live PTO,..... you get the idea.
Then I went and priced them. Then I went and found an old Ford 3400 that I could afford to buy and had FEL and ROPS (needed because of the amount of hills and my inexperience).
Yes four wheel drive would be nice to have (for that matter so would a live PTO). I live on fourty acres that was never considered to be "farmable" (while half of it) because of the clay, springs here and there, and gullies carved out by the creek. There are places that are always wet.
I have never been stuck to the point that I could not push it out with the FEL. Are there things that a nice new 4WD tractor would do better? Sure, a lot of them. However I will lose $00 on this if I sell it and I could afford to buy it. If money was not an object I would have gone down to the JD dealer and purchased exactly what I wanted and yes it would have been 4WD. Most things are a compromise. The only thing it is not doing as well as I would like is digging a pond but that is really a job for an excavator anyways.
15-20 miles southwest of Greenville
thanks for all the great feedback everyone has some really good points unfortunately now I 'm on the fence again :confused:.
/ 4wd or 2wd Tractor?? #33
don't worry... you'll get off the fence.. though you might get back on it 3-4 more times before you buy... by then you will be good at climbing though!
LOL... at least I'll be good at climbing!! :laughing:
After viewing comments on the forum about Mahindra I decided do look up a new Mahindra 5010 cab gear drive with loader and much to my surpise it seems like a reasonable deal. Called the local dealer they said MSRP 26,500. I have a couple of questions for you guys who bought new from any dealer but ideally Mahindra.... Was there any negotiation or was it take or leave it type deal? the 5010 comes with a one rear remote... how hard is it add another one or two remotes? Any helpful tips for getting the best deal possible would be awesome! I think this might be the direction I go Mahindra is offering 0% for 60 months or up to 84 months @ 4.25% any thoughts on this?? thanks
/ 4wd or 2wd Tractor?? #36
Shibaura, I bought my New Holland TND70D new in 2000. I am sure that things have changed some in the meantime. I opted for the front wheel assist option because I knew from the git go that I was going to be doing a lot of fel work. The FWA option cost about $4k and has been well worth it. I also got a 12 speed (geared) transmission with an electric shuttle. My tractor came with rear remotes some of which were used to power the FEL. I was left with one rear remote. I also wanted a remote mounted on the FEL so that I could operate the side shift on my pallet forks and a hydraulic auger drive. My FEL has a quick-tach so that I can use many of the same implements on my tractor that I use on my skid loader. I was able to negotiate the addition/installation of the front remote for very little money when I purchased the tractor. I later had another rear remote installed to power a back-hoe attachment. As I remember, that one was significantly more expensive to install. Twelve years later I am still very happy with this tractor. I have had very little trouble with it and it has proven very versatile.
Good luck with your purchase. My recommendation to you, if you buy a new tractor, is get everything you even think you might want on it at the time of purchase. Since tractors are usually a long term investment, you won't be sorry.
Tim
thank you Tim. I will definitely consider that.
/ 4wd or 2wd Tractor?? #38
Tim
I agree. Having only had my new tractor for little over a week. I wish would have gotten box blade or scrape blade when purchased.
/ 4wd or 2wd Tractor?? #39
You might get some pricing on Mahindra in the Mahindra forum so you can compare. Just ask for pricing on the model that you are interested in and the features that you want. I'm sure someone has bought one recently.
Negotiation on the price is up to the dealer. I have heard of them that wouldnt budge from their price while others do. Lots to do with the sales commission that the owner has set for the salesmen or if they work on salary alone (not to common)
LAWSON AERATOR (A63291)
LAWSON AERATOR...
KBH Tank Trailer (A63688)
KBH Tank Trailer...
Ford Tractor (A62613)
BOBCAT CT4058 TRACTOR (A62130)
BOBCAT CT4058...
2021 Bobcat UV34 4x4 Utility Cart (A61572)
2021 Bobcat UV34...
Snap-On Southern Thunder Edition 24-drawer tool box (A63689)
Snap-On Southern...
