Hello from Western PA
/ Hello from Western PA #1
tractorthatcan
Western Pa
Kubota BX25
Hello and Thank all of you for sharing your wealth of information. As a first tractor owner I have used this information as a HOW TO and in some case a Sanity Check. Over the last year and a half there is nothing that I could not do with my BX25 therefore, my tractor nickname "The Little Tractor That Can" Again Thank You!!
As I wonder further into the weeds I do have a question. I have noticed that the right outlander has some play in it (front to back along the bottom pins(frame and cylinder) but no up and down play. My guess is around 3/16 inch. Left outlander solid as a rock. As the right side is greased it becomes rock solid which I do each time before I use it. Looked at parts diagram and could not see any shims just the pins. Could they be worn both??
Any suggestions?
/ Hello from Western PA #3
Welcome to the forum from Oklahoma.
Ken
/ Hello from Western PA #4
Welcome to TBN from Missouri. There are a lot of BX25 owners on the Kubota "Owning and Operating" forum who can help you.:)
Thanks!!!
Made a copy of initial post and put it in Kubota owner operating section. Did not know how to move it over there. Still feeling my way around the site. Probably made myself a mess figuring where to look for any response to either one
/ Hello from Western PA #6
Thanks!!!
Only a moderator can move a post which they often do, I wouldn't worry about it since you will be getting responses over there. Yours certainly won't be the first double post if they do.
/ Hello from Western PA #9
welcome to tbn. i am a proud kubota owner myself. not sure about your issue, but i wish you good luck.
/ Hello from Western PA #10
Welcome! I am glad you joined. Hope you get your question answered!
John Deere 5090GN (A60462)
John Deere 5090GN...
UNUSED RAYTREE RMBD50-50" HYD DRUM MULCHER (A62131)
UNUSED RAYTREE...
2024 John Deere 6R 130 Tractor Loader (A63109)
2024 John Deere 6R...
Yamaha Golf Cart (A64047)
Yamaha Golf Cart...
KUBOTA KX057-5 EXCAVATOR (A62129)
KUBOTA KX057-5...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A62131)
UNUSED WOLVERINE...
