Adapter for 16oz propane cylinder?
   / Adapter for 16oz propane cylinder? #1
Cord
Richfield, Wi
Resident Architect
Does anybody know of a screw in adapter for a propane lantern that is threaded for a 16oz gas cylinder? I'd like to adapt the threads to npt so the lantern can be hard piped.
   / Adapter for 16oz propane cylinder? #2
apparently my google skills are leet
ED YOUNG'S TRUE VALUE ~Mr Heater Propane and Natural Gas Fittings~
getimage.asp
It says you may find one at your local true value hardware store...
Those are the ones. Having just purchased 4 lanterns, I just realized that these things take high pressure gas because the regulator is in the lantern, not at the tank.
   / Adapter for 16oz propane cylinder? #5
I've also seen them with hoses for use with portable grills.
   / Adapter for 16oz propane cylinder? #6
good ole Harbor Freight has an adapter for filling the little bottles from a propane tank. I am sure you could adapt that to make it work
   / Adapter for 16oz propane cylinder? #7
that makes things worse because those normally use the reverse thread old propane threads on the other end.
you could machine it off, but then again, if you could do that you probably wouldnt be asking for an adapter.
   / Adapter for 16oz propane cylinder? #8
They have a dozen or so different adapters/hoses etc to suit your situation not just one. One I was referring to has straight connection to 30# and larger portable propane bottles to the small lantern bottles. Several others listed for adapting to other applications.
propane adapter - Bing Images
   / Adapter for 16oz propane cylinder? #9
I dont think I would want to be running 80-120# (normal pressure of a storage tank) pressured propane lines into my house to power lanterns. Buy the ones specific for low pressure (ounces rated )rather than high pressure. Or just hook the small bottle to them and refill when empty from your large storage tank assuming that they refill ok. I have not tried to refill any of them so I dont know how well that works, but if I had use for lots of them, I would certainly look into refilling them rather than continually buying those little portable lantern tanks.
   / Adapter for 16oz propane cylinder? #10
We use 1 lantern to light our entire barn every night. It is very, very bright, and lights outside the doors as well. It is the brightest lantern on the market. I bought a 30in propane tree/pole that mounts on top of a 20lb tank. It works great. Depending on the lantern, you can just use an extension hose. The lantern is a Coleman Max Northstar:Coleman Max Northstar Lantern - Walmart.com and the pole is Coleman 30-Inch Distribution Tree, Propane Distribution Tree, Propane Tank Tree, Distribution Tree They also sell the adapter Walmart.com: Coleman Propane Bulk Adapter: Camping
url
url
url
   / Adapter for 16oz propane cylinder? #11
Many years ago, I had a Spitfire propane torch that I really liked. And of course it was made to go on a one pound bottle. I went to Dallas Propane and bought the fittings and an 11' (no idea why the odd length) high pressure hose and used that rig on a 20# and later 30# propane bottle for over 25 years.
   / Adapter for 16oz propane cylinder? #12
Pipes containing unregulated LPG present risks worth considering. Be careful.
   / Adapter for 16oz propane cylinder? #13
That is a very good point! I know that the 20lb tanks that I get pre filled, have a regulator attached to the tank. That may not be the case if you buy one at a big box store, or have an old tank.
Challenger MT275B 40HP 4WD Utility Tractor w/ 76in. Rotary Brush Cutter Attachment (A59228)
Challenger MT275B...
2006 CHEVROLET EXPRESS SERVICE VAN (A59904)
2006 CHEVROLET...
2018 Ford Explorer AWD SUV (A59231)
2018 Ford Explorer...
2354 (A60432)
2354 (A60432)
2007 Ford F-150 Ext. Cab Pickup Truck (A59230)
2007 Ford F-150...
2006 CATERPILLAR 304C (A58214)
2006 CATERPILLAR...
