BX25 3PT Modifications?
/ BX25 3PT Modifications? #1
Artisan
Monrovia, California
Kubota BX25
For My BX25
Folks I am about to be launched into another area of tractoring that I
am not familar with, that being the 3 Point Hitch Assembly. (BX2506)
I took all parts out of the box and began to familarize myself w/ its
contents. It seems pretty straight forward EXCEPT, I am puzzled w/
Part #3 in the instructions, the Lower Link Pin. It is maybe 12" or so long
and maybe 3/4" wide and its exterior is smooth, end to end.
What keeps it from falling out? Falling out as in sliding from left to right
or vice versa. Or will it all become clear when I pull the BH off for the first
time and dive in tomorrow?
Additionally has anyone done anything trick or cool to there BX25's 3pt
hitch assembly to make it better or easier to deal with? All comments are
as always VERY appreciated... Thank YOU!
/ BX25 3PT Modifications? #2
The following is based on the assumption that it is like the BX 24. There are two round pieces that slide on that rod. They have flats that index them. There are holes that the rod can slide through to get it in place. Once you slide the two round pieces to the outside and index them the previous holes don't line up, thus keeping it from falling out. Then there is a piece that slips over the rod to keep the indexed round pieces in place.
Second thought - it will become obvious when you actually do it.
Take Care,
Doug in SW IA
/ BX25 3PT Modifications? #3
You gotta weld it in place!!! Grind it when you want to remove it!!!
Or just do what Doug said, it will be way easier!:laughing::laughing:
/ BX25 3PT Modifications? #4
In the kit you'll find two ~1" thick Link Pin Collets. I don't know if that's what Kubota calls 'em on the instructions, but that's their function. They are round with a flat section machined into the circumference. These fit into the subframe where the Lower Link Pin is installed.
When get the BH off, pull up a 5gal bucket to install the 3pt hitch. Will make life easier on old, tired backs! :laughing: Install the collets onto the Lower Link Pin and then move them to one end of it. Slide the Link Pin through the hole in the subframe, then slide a collet to the subframe, and by spinning it you'll eventually marry up the flat to the subframe and it will slide right into the subframe. Repeat the process on the other side and your Lower Link Pin is installed.
Yes, you have to install them as a unit... If you put the collets in place, there's not enough clearance to get the Lower Link Pin through the holes due to its length.
Friendly suggestion, once you've got it all installed, don't take it apart again to get it on and off the tractor. By disconnecting just a few pieces, you can remove the whole 3pt hitch as a unit and reinstall it as a unit. I'll grab my directions tonight so I can use the nomenclature that is on them and walk you through the removal process.
I've swapped 3pt implements and BH often enough that from start to finish, it's only about a 5-10 minute job to switch 'em out. Luck on the install! :thumbsup:
I am sorta following...and YES I so want to be able to pull the whole
shootin' match on and off as a unit. Can I forgo the cotter pins and use
Hairpins everywhere? Wait...if I want to pull it on and off as a whole I
better look at it first assembled. It is raining here, I just finished a job
and not wanting to go get all wet...
/ BX25 3PT Modifications? #6
Hey Artisan,
Just do it :laughing: Once you've put it on it will seem simple.
About the cotter pins: my 3PH uses hair pins and split rings. I'm converting to rings everywhere.
There's a plate that hangs on the lower bar. It keeps the arms separated and also keeps those big bushings on the ends of the bar in place in the tractor frame. That plate is held on by a little "spud" that came with a hairpin. Said pin and spud came loose somehow. Fortunately the plate stayed in place long enough for me to notice - or real hilarity could have ensued.
Long way of saying I don't trust hairpins in that application. Converted to a ring.
Z.
/ BX25 3PT Modifications? #7
This is the most frustrating and poorly engineered part of the BX25. I fought those cotter keys and the turnbuckles until I bought a QH. That really speeded up implement changes and no more groveling in the dirt and mud (Pacific NW normal). I change back and forth on the BH and 3PT a lot, probaly put more hours on the BH than any other implement. The lower rod assenbly, the plate and the turnbuckles are a PITA. I am toying with some ideas on that. Maybe the rod needs to be a threaded unit to expand and contract into the bushings by hand with a lock nut. Replace the turnbuckles with threaded, adjustable rods/flat bars also.
What have others done to simplify this hookup?
Ron
/ BX25 3PT Modifications? #8
Sweet post.
I'm in the same bucket. Just got my kit also.
Planning on taking the backhoe off late this month and getting a box blade.
I'm watching this thread with great intrest. :laughing:
I am prob wothin 24 hours of this mission. MUST FOCUS! :D
I hope someone who has a/some killer upgrades chimes in. :thumbsup:
Thank You ConcordDriver...
I got-er-done, I should have kept my mouth shut and just gone and went
N' done the job w/o the 3 act play! HA!
Oh well, here are some pics, payin' it forward. The first two pictures are
both the left side only, a left and a right side view of the same hole. I
could have worded it better in the pics...oh well...anyone that's
upset I will refund all the money you paid me, maybe, someday. :D
/ BX25 3PT Modifications? #12
Sorry Artisan, I got sidetracked and didn't get back to you on this. Looks like you got it on, good deal! :thumbsup:
Nice idea on the lynch pins on the upper arms, gonna have to steal that one... As far as taking it off as an assembly, you've probably figured it out by now, but here goes and this seems to work best for me.
1) Loosen your sway arms so there's alot of play in them
2) Remove the keeper pin from the Lower Plate assembly
3) With the pin out, and enough play in the sway arms, you can rotate the Lower Plate off the Lower Link Pin
4) In your case, remove your lynch pins from the upper arms and pull the bolts out and you'll be able to set the assembled 3pt hitch on the floor.
5) Push your Lower Arms to the center of the Lower Link Pin and you'll be able to slide the Lower Link Pin out of the collets and you're home free!
First time putting it on assembled will be a bit tricky, but you'll get the hang of it...
edit: I thought you had a cotter pin in the Lower Plate Pin, now that I look again I see it's a hairpin.
No problemo...
I see why some guys loath these things but it is actually a pretty cool
design. The heim ends stuck w/ rust or paint and the forethought to make
the check chains lengths the same and the myraid of almost infinate
adjustments can easily trip up a DIY'er / Weekend Warrior mechanic. I
bet ya I will find some cool ways to make this unrulie attachment attacher
attach attachments better some day. ( Did I just write what I thought I wrote? :laughing: )
So I added some Lynch pins at the top, OK THERE IS AN UPGRADE that
will facitilate an "easier' removal of the 3PT assembly as a whole when a
guy wants to re-laod his BH.
I hope some other cool 3PT upgrades materialize from other folks... I think
I rememebr seeing a hydraulic top link somewhere...
What did you* do to your 3PT hitch to make it "better" ?
*you=lurkers :D
/ BX25 3PT Modifications? #14
Great job on the hitch install! :thumbsup:
Did you have to drill out the holes in the upper link pins for them to accept lynch pins?
/ BX25 3PT Modifications? #15
Oh, and the nuts on the turnbuckles might need to be "broken free". I did not even know they moved till I asked on here...:D
/ BX25 3PT Modifications? #16
Artisan,
Yep, I quickly decided the cotter pins had to go after I snagged my skin too many times, did same as you. The bottom assembly is the real PITA getting all that assembled. As mentioned I am thinking the solution. I found out real fast that if there is any slack in the chains those 4 little shackle units bend all out of shape and wear through. Replaced two sets before I got the QH. Now I snug them up and they are solid.
I am thinking for the bottom bar to use a piece of 1" hex bar; weld a short piece of the existing rod and the bushing on one end; weld a 1" rod coupling on the other end about 2" short of the inside space; weld a piece of the existing rod and bushing to a cut off 1" bolt: put a 1" nut on the threaded portion as a lock nut: weld a handle on the nut; this way it can be shortnened to insert, screwed out to length, and locked by hand (no tools required); weld onto the center of the hex bar unit attachment points for the chains.
Still thinking the chains. Leaning toward a solid unit with the same type adjustment arrangement and maybe ball units on each end for flexibility. Infinite adjustability w/o tools.
Comments please before I start.
Ron
/ BX25 3PT Modifications? #17
No problemo...
*you=lurkers :D
Yeah, what you saw was the HydrauLink I'd guess... There's a huge thread somewhere on TBN about this piece of equipment. I really don't want to start another "war" on this, but I've got one and I wouldn't trade it for anything!
First, let me say, the HydrauLink IS NOT a Top-n-Tilt device. It does not allow for true hydraulic control of your attachment. You can adjust your attachment on the fly, but only in the "down" direction, because Mr Gravity is on your side... :)
What it really is is a no-muss-no-fuss fully adjustable toplink. Yes, most toplinks are adjustable, but with the screw types you adjust, test, adjust, test, adjust and then use. Most of the adjustment is done with the implement just touching the ground or barely off the ground, with you off the tractor doing the adjustment. If you load up your implement with ground contact, you can barely budge the screw adjustment because of the load on it.
With a HydrauLink, all that goes out the window... For instance, if I've got my Grading Plane on the 3pt and I really want to recondition my gravel drive to get the ruts out of it, I run the 3pt control fully down, crack the valve on the HydrauLink and ease forward just a bit. Close the valve and I'm now fully engaged on both blades of the Plane. If I've got a low spot in the drive, I can mound some gravel up on the low spot and then back over it the Plane. Then, instead of going with a full-down position, I'll set the Plane down and with the valve open, back up just a bit. This extends the 'Link and now only the back blade of the Plane is really doing work. Smooths the pile of gravel right out. And note, I never got off the BX to do these adjustments, just swiveled in the seat and worked the valve a bit.
For a rank amateur like me, it really makes it easy to figure out how your implements work at different positions, how much "bite" your going to get out of your Plane or Box. Drop the implement, crack the valve, move forwards or backwards (and I'm not talking alot here, just enough to put tension on the link and change the implement orientation), close the valve and try again.
One other good thing about it is that it does have some "flex" to it. If you have the teeth down on your Box and you're really digging with it, if you snag a big root or rock, the box will work around that obstacle a little better because there is some give in the system. Less broken tips or bent scarifiers... On the other hand, that flex sometimes inhibts your ability do dig with a Box. If I'm in really tough ground, I'll swap out the HydrauLink with an screw-type solid toplink and use it until I'm through with the really hard digging. But when I start smoothing things out, I'll find myself putting the HydrauLink back on.
If you're looking for an easily adjustable toplink, this one works really well... I'd say it's the toplink of choice, for what I do, for about 95% of my tasks.
Eagle
/ BX25 3PT Modifications? #18
congrats on getting it done. three things I would suggest to change. The top lift arms, I used hairpin instead of lynch pins. Those lynch pins tends to pop out when its flipped wrong way.
The top link pin, put flat side on left, it will prevent the lynch pin rubbing on the sleeve jacket for pwrbynd.
third, the pin that holds lower plate on bar, remove the pin that goes upside down with tiny hairpin and get out your tap and tap it out for a bolt. This way you can use a bolt on top and just unscrew it just enough not to fall out but still can remove lower plate. No more tiny pin and hairpin clips.
/ BX25 3PT Modifications? #19
Eagle
Well, this is timely as just today I was spec'ing out a possible two spool valve for my BX25 that I'd hook into the BH power beyond loop so I can use my old hydraulic top link. With fittings/adaptors and quick connects it was looking close to $300, then I'd need hoses. I know about the Hydraulink and had been waiting for them to intro the SCUT version but looks like that's never going to happen. So my question to you is which Hydraulink cylinder did you buy and do you find it too long for your BX (how long is it min/mas)? The first one they put to market was for larger tractors than the SCUTs, I thought. Any pic's if I may ask?
/ BX25 3PT Modifications? #20
Eh... Well, I can't rightly remember what model I ordered?? :eek: I know it works fine on my BX-25 running Land Pride implements. Got a 4' Box and Plane (model numbers in the sig block) and also have a just calibrated FIMCO 40gal sprayer that it works with too.
Make ya a deal... If you can sit tight for a couple of days, I'll get you the model number I'm using and some pics of it compressed and extended so you can get a good idea of the range of motion it will support. More to follow...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7731 Miles (A63688)
2019 Cadillac XTS...
MASSEY FERGUSON 2605 TRACTOR (A62130)
MASSEY FERGUSON...
2022 John Deere 616R Sprayer (A63111)
2022 John Deere...
Generator (A61572)
Generator (A61572)
2019 CUSHMAN HAULER PRO ELECTRIC GOLF CART (A58375)
2019 CUSHMAN...
