Ballast Adding Backhoe- Ballast needed or not
/ Adding Backhoe- Ballast needed or not #1
kneedeep
AL Gulf Coast & MS Delta
Mahindra 3510 & 8560
I will be adding a Backhoe soon to my Mahingra 3510. When I purchased it, the dealer added drive tire ballast.
Is this extra weight necessary with the Backhoe added and if removed how will it affect plowing and grading?
Anyone have a 3510/4110 without rear ballast?
/ Adding Backhoe- Ballast needed or not #2
The rear tire ballast will also help your backhoe dig better.
/ Adding Backhoe- Ballast needed or not #3
Do you have a loader? Rear ballast is always welcomed when a loader is on a tractor.
The rear ballast won't affect the backhoe much at all, leave it in. As mentioned might help a little if you dip into hard ground.
--->Paul
Seems lik a lot of extra weight w/BH. I have the 112 FEL, thats why the ballast was added.
It is full up to the valve stem in the highest position.
About what weight am I looking at here in the tires?
I only have a 7000# gross gooseneck trailer.
/ Adding Backhoe- Ballast needed or not #5
If your ballast is water or water/methanol mix, you have approx. 440 lbs. of ballast in each tire, maybe a little more. Your tractor itself does not "carry" that weight on it's axles like it does the backhoe so it's not hurting anything as far as the tractor goes. The capacity of the trailer is a different story though - it does carry it for sure !! My 4110 has 55 gal. of methanol/water mix in each tire and mine is up to the valve stem when at about 11 or 1 o' clock. My 4110 with FEL and light duty 6' boxblade on weighs almost 7000 lbs, I would imagine yours would be over that with the backhoe onboard.
Your right! I did not think the ballast is weight to the ground and not 'on' the tractor!
The trailer will have to carry all that weight. I will probably have to change the axles to a 10K# set and bigger tires and wheels to make it work. It is a heavy channel iron frame trailer and I can get new springs, hangars, axles and wheels for a lot less than a new one cost.
:thumbsup:
/ Adding Backhoe- Ballast needed or not #7
:thumbsup:
Have you considered the weight of the trailer on it's axles. You have to subtract that weight from your load's weight for gross load weight.
hugs, Brandi
hugs, Brandi
Tractor, FEL, Ballast and BH will be right out gross weight without trailer weight.
The frame looks like your trailer( saw it in old post about Dump Trailer when you were repairing Washer line) and I can upgrade the undercarriage fom the 3500# axles to 5000# axles springs and hangars.
BTW- What is the gross on your trailer?
/ Adding Backhoe- Ballast needed or not #9
My trailer grosses 14,000 lbs. It weighs 2600 pounds on the trailer axles while hooked up to my truck. My Mahindra 6520 4WD with loader and Bradco 511 backhoe tips the scales at 11,300 lbs. So I am 100 pounds under gross with tractor on board. I will be upgrading to a dual tandem trailer in the future. Then I can load my tires and carry more than one attachment.....or a bigger tractor or an 8 ton excavator.
hugs, Brandi
hugs, Brandi
Does it feel like it is too much for the trailer?
/ Adding Backhoe- Ballast needed or not #11
Oh yeah. On bumpy roads it feels like the gooseneck is flexing, which it probably is. I told the guy that built it and he says his company has not had any gooseneck welds break. I suggest you trade in and upgrade, if you have any doubts. I plan on keeping this trailer for smaller equipment and supplies. Then I won't be scared to haul in the Hill Country.
hugs, Brandi
hugs, Brandi
Mine used to 'feel' like it was flexing also. That's why I asked!
I started centering the load over the front axle instead of runing it all the way to the front (w/ loader over gooseneck) and it helped to stop that. The position changed with 3PT equip. also although not much. My wife watched the tires and springs and would tell me when they seemed the same. Stopped all the 'jerking' on rough roads. Also chained the tractor down tight and not the equipment.
/ Adding Backhoe- Ballast needed or not #13
With my loader and backhoe, it is over 25 feet long. I have to park the loader bucket on top of the gooseneck. Which centers the tractor over the front axle. Backhoe bucket hangs between the ramps, which is behind the 20 foot bed. I never go anyway with out tight chains. I never turn around with the tractor on board either.
hugs, Brandi
2000 Mack CH613 Dump Truck (A59213)
2000 Mack CH613...
Zero Turn Mower (A59231)
Zero Turn Mower...
2022 All Aluminum Timpte 514 Trailer Electric Tilt (A63118)
2022 All Aluminum...
Mahindra 4550-4L Tractor with Front Loader - 49 HP, 4WD, Heavy-Duty Utility (A63118)
Mahindra 4550-4L...
2004 Ford E-450 Jayco Escapade 28G Class C Motorhome (A61569)
2004 Ford E-450...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
