Best DIY towable backhoe plans?
/ Best DIY towable backhoe plans? #1
REPO
I have been reading tons of posts around the net trying to figure out what is the best plans available to build my own towable backhoe? I am leaning towards the CADplans version. I do want to have the angled main boom. (30 degrees?) as from what I have read, you can dig a little deeper.
I have NO experience with building these, so I was hoping that someone who has actually built one, or knows of different variations could give their opinion. I want the best possible design, for digging, comfort of operation, strength, etc.
If you have saved links, pictures, etc, they would be great!
Thanks in advance!
/ Best DIY towable backhoe plans? #2
I do not have any experience with the towable ones however I did recently complete one for my tractor. I too used the curved boom design.
I am not certain however whether it contributes to digging depth, I was more of the impression it allowed you to dig closer the the tractor or in your case the transport frame.
I have been reading your post, you did an amazing job. What plans did you buy?
/ Best DIY towable backhoe plans? #4
P.F. Engineering.
I made a few minor modifications as is usually the case when building something. Like you I like the idea of a towable design. I guess you could say mine is towable as well. I bought a trailer that I can load the tractor and BH on. I wanted to build the trailer as well, especially since I work for a trailer manufacturer however, building two major projects at the same time would be more than I could handle, or the wife would allow!
/ Best DIY towable backhoe plans? #5
Dear REPO
I am also a new member and I am in the middle of installing a John Deere 46 backhoe subframe under a Kubota. the hydraulics will be powered by the kubotas mid PTO when on the tractor and the backhoe will be unbolted from the subframe and rebolted to the towable. A 10 Hp diesel will power the backhoe as I have installed a filter and pressure relief and gauge under the grating of the hoe. It has two 8 foot quick connect wet lines. It should work because I have already did some playing using the kubotas remote valve.
No pictures yet.
Craig Clayton
/ Best DIY towable backhoe plans? #6
Dear REPO
No pictures yet.
Craig Clayton
Sounds very interesting.
Look forward to the photos.
/ Best DIY towable backhoe plans? #7
J J, the CDP plan is the one I have been looking at the most. The PRO800 with the Extend-A-Hoe option is the one I like. I am just waiting for more info from him on this system, as there are no good pictures or info on the website to make an educated decision.
/ Best DIY towable backhoe plans? #10
Here is my CDP-500/600? Needs a little more work. It has the grapple on it right now.
I finally recieved a response from CDP. Apparently he has no pictures or any other info on the PRO800 or the Extend-A-Hoe. Seems a bit odd. If you are selling an item, you should be able to describe it right?
How many people have bought the CDP plans? Is this guy legit?
/ Best DIY towable backhoe plans? #12
REPO, I have purchased from him awhile back, and he had photos of all his products. The kits I purchased were all laser cut, with bushings, and all the small metal. parts. I only had to purchase the 3 x 3, 4 x 4 stock. I also purchased the grapple that fits on the boom. I agree with you about the PRO-800 kit, he should have photos of it, or go out and take some. I purchased the 3 pt kit, and adapted it to my Power-Trac, which you can see in the pictures.
/ Best DIY towable backhoe plans? #14
I built my backhoe from ubuildit plans and have gotten lots of use out of it. Built it 7 years ago. The learning curve was kind of steep for me as I had not done a lot of welding. Turned out ok and have only had to redo a few welds. Used a harbor freight welder and could have used a little more amps.
I found the cad plans after I started on my backhoe and I would probably go for one of their plans. They offer more options. That said the ubuild is a great little machine!:confused2::cool:
/ Best DIY towable backhoe plans? #15
Were I to do a tow-able, I'd definitely want it to be able to move some on its own power. When I use our 3 point backhoe, I am always digging a bit, then moving it a few feet then digging some more. A bigger unit will be able to reach more, but something is always going to be just out of reach. I imagine the tow-ables can move themselves a foot or two at a time, but that would get old quick on a larger project.
/ Best DIY towable backhoe plans? #16
I built my backhoe from ubuildit plans and have gotten lots of use out of it. Built it 7 years ago. The learning curve was kind of steep for me as I had not done a lot of welding. Turned out ok and have only had to redo a few welds...That said the ubuild is a great little machine!:confused2::cool:
I'm currently working on the ubuiltitplans backhoe. Overall it's been going together well, although now I'm down to the last major sub-assembly and the dipper arm plates are giving me a lot of trouble. With any luck I'll have the machine completely done -- painted and assembled -- by the end of May. If I have to completely re-do the plates... well... it will be longer.
/ Best DIY towable backhoe plans? #17
P.F. Engineering.
rbuterfield, I too would like to build a backhoe for my 2320. How is it attached to the tractor and are the Hydraulics powered by the rear pto? Exactly what mods did you make. I was thinking of purchasing the P.F. Engineering plans.
/ Best DIY towable backhoe plans? #18
I have the original Kelley 70 backhoe 3 pt hitch frame with oil tank I would like to sell. Would save a lot of work and welding. Just need to build & mount the hoe and stabilizers. Mine was converted to a fixed frame that mounts right to the tractor. PM me if interested.
Wooden Rocking Chair (A64127)
Wooden Rocking...
76in. Low Side Skeleton Skid Steer Bucket (A65640)
76in. Low Side...
LOAD OUT AND SHIPPING (A65583)
LOAD OUT AND...
2014 FVCG TRAILER (A61567)
2014 FVCG TRAILER...
2021 DITCH WITCH HX30 TOWABLE VACUUM TRAILER (A63276)
2021 DITCH WITCH...
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
