Gooseneck adapter
/ Gooseneck adapter #1
Bladehauler
Gold Member
Brookshire TEXAS
LS R4047
Hello all !
Going to look at a gooseneck trailer tomorrow , problem is it is setupp for a 3" style hitch with the pin hole and my truck has a 2 5/16 th flip over ball.
Does anyone know if there's an adapter made , or do i take a chance and drag it home like it is until I can change out the gooseneck tube ?? ( Id rather not !!!)
Thanks for any help !!
C-ya
Scott
/ Gooseneck adapter #2
B&W sell the pin hole style insert for their hitch.
/ Gooseneck adapter #3
If you are referring to the B&W hitch with the 3inch square reciever in the bed, it uses a 2 and 5/16 ball. Ive never heard of a gooseneck using any size other than a 2 and 5/16th.
/ Gooseneck adapter
Nope,
I have a curt 2 5/16 flip-over ball in my truck.
The trailer has the 30k 3 and 7/16 ( i believe ) coupler in it . I had that type 20 years ago, the ball has a horizontal hole and a pin goes though the hitch and the ball.
I'm trying to figure out if there is an adapter made to mate the two.
Sorry if I was unclear earlier
Thanks,
Scott
/ Gooseneck adapter #5
so the ball rotates?
/ Gooseneck adapter #7
Wow. I have never seen or heard of one of those and I have pulled goosenecks all my life.
/ Gooseneck adapter #8
They are an older unit, you just stuck a bolt through the gn tube. The ball rotates when you turn. The gn tube is just a piece of pipe with a hole drilled in most cases, I don't think I've seen any with any surface to sit on the ball.
/ Gooseneck adapter #9
If the truck is fitted with a 2-5/16 and the trailer is fitted with a 3" pin/eye hitch, the solution is easy.
Go buy a GN tube/coupler from TSC like this
Then drill a hole to fit the pin/eye on the trailer side. Slide the coupler into or over, depending on diameter, of the trailer coupler, run the 1" pin through both pieces, and you have successfully converted your trailer to hook to a standard 2-5/16 ball.
The only problem you may run into is the height of the hitch, if it's a long trailer, you probably won't notice, but a short trailer, it will be riding high in the front end.
/ Gooseneck adapter #10
Gooseneck Mfg. used them on some of their trailers in the 70s. The bad thing about them was that the ball rotated by turning in and out on the threads. That meant that the flange would be a hair above the plate and would allow for flexing. I was pulling a hill on a dirt road with a backhoe and had one break. Luckily, I was pulling with a flatbed and the tube hit the back of the hole in the bed and I was able to control it and get stopped. Had it been mounted in a pickup, it would have just torn the tailgate off and I probably would have wrecked both trailer and backhoe. We cut that thing off and put a Bulldog mount on.
/ Gooseneck adapter
Well I picked up the trailer today.
Its a 20' lowboy gn with ramps , 6 bolt hubs ( im hoping 5200lb axles and not 3500s ) it did have the old style 3 and a little bit coupler on it ( it does have a concave load bearing surface about 2.5 to 3 " inside.
I dropped it down on my 2 5/16 and prayed halfway across Houston.
tandem axle with brakes ( that arent hooked up ) on 3 hubs :confused:
guess a problem at sometime in the past !!!
I did stop by the trailer parts supply and picked up a bulldog weld on coupler. Gonna weld it on the bottom of the tube and get to bearings, brakes and wiring. For what I paid , I can afford to put a little money into it and still come out way cheaper than the next used trailer I had looked at !!
Thanks
Scott
/ Gooseneck adapter #12
Interesting thread. I recall seeing those old hitches years ago but had completely forgotten about them. Don't forget to post the before and after pics when you get finished with the trailer renovation.
Glad you made it across town. That can sometimes be a challenge even with a brand new trailer.
/ Gooseneck adapter
Huh !!!!!
Well, got the trailer home, had a tire going down( cracked valve stem ) I figured while the tire was off , that would be the first hub to get serviced.
pulled the dust cap off and...........grease ???? nope whole lotta rust and the brakes ..... nonexistent. PERFECT!!!!!!! Sooo I pulled #2 off same thing.!@#$%^ Well this is another fine mess I've gotten myself into.
So tomorrow I'll be shopping for 4 new complete wheel ends ( backing plates, hubs bearings ) oh and still gotta get that tire fixed.
Oh well , its only money, Right ????
hope Ya'lls day was better !!
C-ya
Scott
/ Gooseneck adapter #14
Bladehauler said:
Huh !!!!!
C-ya
Scott
Hope it works out for you. 9 out if 10 used trailers I see end up being money pits and in the long run cost about the same as new. Hope you fair better.
Chris
/ Gooseneck adapter
Chris
Thanks,
I paid $800 for it and just talked with the parts house ,
4 new 12"hubs with bearings,seals dust cup,axle nut ,cotter key and lugnuts,
4 new electric brakes ,new bolts to mount them
come to $408.
The welding on the coupler ( which was $51 ) i'll do myself so hopefully around $1300 and I'll be in business !!!!:D
/ Gooseneck adapter #16
Bladehauler said:
Thanks,
come to $408.
Yep, you will still be all right. How is the battery, brake away, wiring, lights, and wood deck?
Chris
2019 John Deere R-4038 (A61306)
2019 John Deere...
2022 Ford Explorer AWD SUV (A61574)
2022 Ford Explorer...
Champion Vibratory Roller (A60462)
Champion Vibratory...
2016 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A61573)
2016 Freightliner...
2023 VOLVO L90H WHEEL LOADER (A65053)
2023 VOLVO L90H...
John Deere 5055E (A64126)
John Deere 5055E...
