First Project with New Welding set up
/ First Project with New Welding set up #1
welderboy14
Surrey, BC
John Deere 325
I recently Acquired a Miller Dialarc HF-P Tig/Stick & Miller Regency 200 CC/CV with Aluminum Spool gun, The first Project i am Doing with it is a rake that will clamp on to the edge of an excavator bucket for spreading mulch.
So Far i have tacked the bottom and top lengths of angle together and tacked on 8" with 6" stick out pieces of 1" Rebar for the Tines, i still have to weld on some gussets behind the tines and attach some chain to hold it to the bucket.
Heres some Pictures of what i have so Far.
First is the 2 pieces of Angle tacked together
attachment.php
Second is with the Rebar tines sitting in place to finalize placement
attachment.php
Third is with the Rebar tacked on and rake set on bucket lip for test fit
attachment.php
/ First Project with New Welding set up #2
I hope it does what you want it to. Looks like it should work. I once thought about mounting my landscape rake to my backhoe for cleaning limbs from under trees where my tractor won't go without knocking me out of the seat. In my opinion anything beats a hand rake!!
/ First Project with New Welding set up #4
What's the plan for attaching it to the bucket? Bolts? Clamps?
/ First Project with New Welding set up #5
/ First Project with New Welding set up #6
looks good :thumbsup: By the way. How's your home made towable backhoe coming along?
Chad
/ First Project with New Welding set up #7
Duck tape? :laughing::laughing::laughing:
No chance of you being a Red Neck. :laughing::laughing::laughing:
If Duct Tape wont do it, Hardly worth doing. :dance1::drink:
/ First Project with New Welding set up #8
Iplayfarmer Re: First Project with New Welding set up
I haven't even thought about a plan, just an idea so far. The duct tape mentioned don't sound to bad:laughing: The way I operate a backhoe (just learning) it don't need to be mounted to rigid or I'll rip it apart. Someday I may really think about mounting it (probably with clamps) something simple if possible.
WelderBoy 14 didn't mean to hijack you thread. I'm kinda new here what's the word about your towable backhoe? My brother had one but the hydraulics that were used were very touchy meaning when you tried to move the boom it was (all or none) no smooth operating. He sold it.
I plan on welding chain to the corners of the angle then run it ether under or over the bucket to the back where there is a Lifting hook that i will attach it to, then it will be tightened with a Chain sinch
Chad
Haha Long story.....Needed money to finish it which i got then i found the Welders Both for $1000 :shocked::D and there went the money i had for the backhoe. I figured get the welder which i can then use to weld up stuff for other people then make back the money then i can finish the backhoe...atleast thats the plan anyway if i succeed is a whole other story :laughing:
/ First Project with New Welding set up #11
:laughing: Sounds like something I'd do too, if I found a deal like that. I finally got mine working good and was able to put my water line in about a week ago. I was so happy to have it going.
I used my rear differential out of my old 1981 Buick Regal. The plan is to use a hydraulic motor to drive the differential, and then put a front end out of a pickup and add a steering wheel to the side. This way I can drive it.
I currently (temporarily) have 2 old car rims welded to some pipe to use as stabilizers, and it actually keeps it from dragging around. (works better than I thought)
I wanted to take pictures and a video but my camera quit on me. I'm gonna have to purchase a new one when I can get some more money.
Hope your able to get yours going pretty soon.
Chad
iDrive TDS-2010H...
John Deere 6320 (A64126)
John Deere 6320...
2012 UTILITY VS2RA 53X102 REFRIGERATED TRAILER (A59914)
2012 UTILITY VS2RA...
Case SV280B (A60462)
set of 4 tractor trailer tires Roadforce (A63689)
set of 4 tractor...
Used 20' Container (A62679)
Used 20' Container...
