Bum Puzzled 275 gallon paletized tank with 2 inch gate valve
/ Bum Puzzled 275 gallon paletized tank with 2 inch gate valve #1
TGF
Gold Member
Blair, NE
3038E
I got me a great deal on these tanks. Free to be exact. It has a gate valve that appears to be 2 inch Male NPT but its not the 2 inch Female NPT is just a hair to small. Any of you run into these tanks before and know what the thread is?
/ Bum Puzzled 275 gallon paletized tank with 2 inch gate valve #3
I have several of those things, never have found fittings to fit them correctly, I use a 2" rubber coupling (fernco I think) from the hardware store to adapt to a 2" PVC to 2" MPT adapter. Then you have readily available fittings.
Thanks both of you will be examining both of these options.
/ Bum Puzzled 275 gallon paletized tank with 2 inch gate valve #5
I used a 2 inch cam lock from TSC for my pressure washer water supply.
Hey guys one more question, I did some more snooping at the parts store and I looked at the cam locks. I think this maybe a 2 inch cam lock compatible valve. Here are some pictures.
/ Bum Puzzled 275 gallon paletized tank with 2 inch gate valve #7
Looks same as mine 2 inch cam lock works. The ones I got had some chemical they use in the treatment of water.
Sounds like we got the same thing. I got mine from the local water treatment plant they had 8 of them they were going the throw away. They are a toxic and flammable 1 which is relatively safe. You can wash them out and use them for potable water, I just plan on washing them and using them for watering the orchard?
/ Bum Puzzled 275 gallon paletized tank with 2 inch gate valve #9
Seeing as these totes were for chemicals that may be the reason there is a different thread.
Might want to check chemical component suppliers to get a proper match.:)
Already there Egon
IBC,Totes New & used. Tank accessories.
Credit to Kernopelli for the link.
I am going to hit TSC and pick up a 2" Female camlock to 2" NPT and my problem is fixed. 12 bucks at TSC, less than 20 bucks over all for a couple nice poly tanks. Thanks for everyones help.
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
500BBL WHEELED...
