Bush hog busted?
/ Bush hog busted? #1
stormpetrel
Gold Member
Block Island R.I.
ym2210D
Howdy everyone!! It's been a long winter......my tractor was down with the 4wd gearbox bearings needing replacement. I finally got it back together, and have been working the tractor like crazy this past week; I have cleared brush and trees that haven't seen daylight in decades, got stone walls cleared, and in general had a great time improving our place.
This morning I hit a rock while backing the bush hog into very thick brush. The pto shaft is turning, but the blades are not. Is there something in the gearbox that shears off to prevent damage, that I must now replace? Or is it worse than that?
/ Bush hog busted? #2
should be a pin(bolt)where the pto shaft meets the gear box on the mower, it might look like its still there but you will probably find its only half there......
/ Bush hog busted?
Thanks.......that's what I was hoping!! Where do you get a new one?
I see we're almost neighbors.......:)
/ Bush hog busted? #4
You should be able to buy a new shear pin at TSC or other farm supply type places. Of course, you need to figure out the size. If you happen to have a manual for the bushhog, that gets really easy. :thumbsup:
/ Bush hog busted?
Thanks folks.....I'm very relieved. I guess I hit one too many rocks.......:eek:
/ Bush hog busted? #6
is that what you found ? If so you can use a hardended bolt,check the size as stated and start the mower off easy so it doenst break again....
Yes, we are close, i was born in RI at Kent County hosp....
/ Bush hog busted? #7
...If so you can use a hardended bolt...
I know some people do this, but it seems like borrowing trouble to me. It's a nuisance to replace a shear bolt, but the shear bolt is also protecting the tractor and the mower from some of the horrific impact forces when the blades bang into rocks. As tough as a shear bolt can be to replace, I'd rather mess with one of those than the innards of the tractor.
I don't know for sure that is the choice: Hardened bolt vs PTO components of the tractor, but if the bashing is sufficient to shear the bolt off, it has to be rattling the tractor's powertrain, too. I'd rather err on the easier side than the more abusive side.
/ Bush hog busted? #8
I use a grade 2 bolt with a nylock that is what the manufacturer recommended but my hog is only rated to 60 hp
/ Bush hog busted?
Funny you should mention bolts, cause that's exactly what was on there!! I have used the tractor for bushogging 4+ acres.......HARD for over a full season. When I knocked the remains of the "pin" out, I noticed the end of a bolt on the deck, freshly sheared,and it fit perfectly with the other half.
I guess the guy I bought it from had a steak of Swamp Yankee in him. Certainly, as someone who lives on a little island with no Tractor Supply store, you can bet I found another hardened bolt and put 'er right back in!!
We'll see how she works....I expect it'll do fine, the other one seemed to. I guess a bolt is just weak enough to be able to shear off before any damage is done to the gearbox on the deck or the powertrain.......
/ Bush hog busted?
Mine's a 5', on a 22 hp PTO output tractor. I doubt it's even rated for 60 hp....
/ Bush hog busted? #11
There was a "bolt" in it cause thats waht a "shear pin" IS. For your size tractor you need to use a grade 2 bolt. If it was a bigger tractor you can use a grade 5 but DO NOT use a 5 in your tracotor. Other wise next time you may be writing about how to replace busted PTO gears or what to do about a busted gear in your bush hog. Go get a hand full of bolts and nuts and keep them on your tractor so that if it happens again you just punch the old half out and put a new on in there.
/ Bush hog busted? #12
Most of the time a grade 2 bolt is what is specified. A hardened bolt may damage the shaft more than the specified grade 2 bolt, and/or likely shears at a higher torque on the PTO. I'd go with the softer grade 2 if it were me.
/ Bush hog busted? #13
Please don't use a "hardened" bolt. That would be a grade 5 or 8 and neither is good as shear protection. 4520RX is right. So is BARTCEPHUS. If you are going to use a hardware store bolt, make sure it is a grade 2. Grade 2 is soft enough to provide shear protection. 5 or 8 may/will not shear, thus not protecting your equipment.
/ Bush hog busted? #14
most say only to use a grade 5 bolt in a larger say 55+ hp tractor as their gears are tougher to take the HP. BUT the bush hog may not be? Like i and others said take that 5 outta there, it would be fine if in an area known to be rock free to get you through a day but you NEED to put a grade 2 bolt in there.
/ Bush hog busted? #15
... unless you're looking for a good excuse to buy a new tractor. :D
/ Bush hog busted?
Ok, I'll put a #2 bolt in. But......won't a hardened bolt shear quicker, due to being more brittle? Any metallurgists out there that can answer this? ;)
/ Bush hog busted? #18
NO it will shear at a higher PSI due to having a HIGHER shear strength!! higher grades are stronger in shear strength and tensile strength. I promise. My bush hog (Jbar brand) manual says to use "grade 2" bolts i think its 3/8 size? if you dont trust us that much i can copy it if i ever find it but you can just look up Bush hog brand online, they post all their manuals, and you can look it up, or look at king kutter they all take bolts, grade 2!!
/ Bush hog busted?
It's not that I don't trust anyone,it's just a question based on my own experience with softer metals that bend and don't break, where harder metals crystallize/snap real easy because harder metal usually = more brittle metal. Just curious. You did see where I wrote I would put a grade 2 bolt in, right? :)
/ Bush hog busted? #20
I have sheared many bolts. I use the cheap bolts from Lowe's / hd. I have several spares on hand.
Haven't seen you around in a while
By the way Grapple is working GREAT !
2001 Ford F-550 (A66408)
2001 Ford F-550...
1997 Fontaine FTW-5-8048WSAW 48Ft 34 Ton Flatbed Trailer (A64194)
1997 Fontaine...
NEW Wolverine GB-11-72W Skid Steer Grapple Bucket (A62679)
NEW Wolverine...
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
2025 GIYI GY-P45 Hydraulic Breaker Mini Skid Steer Attachment (A64553)
2025 GIYI GY-P45...
Spartan RT-HD Zero Turn Mower (A66285)
Spartan RT-HD Zero...
