Winch mount, RTV 900
/ Winch mount, RTV 900 #1
R_Walter
Gold Member
Lindrith, NM
Kubota L4240
I just purchased the Kubota V4254 winch mount kit which came from Kubota with absolutely no instructions as to what kind of winch, how big of a winch and, most importantly, how to install the kit with a winch. [I've not yet bought a winch, but purchased the kit on-line with a bunch of maintenance items for my l4240 and my RTV 900.]
Has anyone used this kit to install a winch and which winch did you install? I'm planning on a Warn 4000 minimum.
/ Winch mount, RTV 900 #2
FWIW, my dealer installed winch was an 2500 or 3000#. I wonder if there is room for a 4000# winch.
Ken
/ Winch mount, RTV 900 #3
/ Winch mount, RTV 900 #4
I put a 4000lb Viper on mine using their included mount with minor adjustments; no problems
I got the Kubota mount for my RTV1100(different mount then the 900) and it was drilled for the Warn 3000 pound winch. Got a KFI mount when I upgraded to the Warn 4000 and put the 3000 on the back with a 2inch receiver.
RTV900 - Winch Mounts - KUBOTA - RTV900 - KFI ATV Winch, Mounts and Accessories
Does not look like the 2009 and newer RTV have a Warn 4000# bracket.
David Kb7uns
Looks like KFI only sells a KFI-branded winch. No Warns on their website. Will their KFI mount for the Warn 4000 actually fit a Warn 4000? I know it's a bit silly to ask this question.
/ Winch mount, RTV 900 #6
R_Walter,
Go to the WARN website as you will find a page that gives the on center bolt pattern for the winch of your choice. Compare it to your winch mount and go from there.
I have the WARN RT40 mounted (on a different brand of UTV) to an aftermarket mount and had to LIGHTLY edge drill out two of the holes and am very satisfied with the results. I even got that big diesel slug stuck in a bog down to the axles and the RT40 pulled 'er out.
Since you're going to do this, you will need some other tools in your arsenal, one being a snatchblock, two being matching the power draw of your winch of choice to your existing battery capability.
2020 Kubota RTVX1140 (A62183)
2020 Kubota...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
New 2025 NextGen 7x20 Equipment Trailer (A61166)
New 2025 NextGen...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61568)
Pallet of...
Bobcat E42 (A60462)
Bobcat E42 (A60462)
