Broken tie-rod
/ Broken tie-rod #1
scappoose
Member
Scappoose, Oregon
mahindra 2816/FEL
Yesterday as I was driving my Mahindra 2816 in my driveway a peice of 1/2" plywood stood up on edge and broke my tie-rod in half. I have discovered that the tie rod its self is only a rather thin metal sleeve with nuts on either end. I suspect that the sleeve could be threaded (like a turnbuckle). Does anyone know if it would be possible to repair and strengthen this tie-rod turnbuckle?
The tie-rod its self appears to totaly straight. does anyone know how long this tie-bar/turnbuckle should be?
My thought is to cut off the broken parts of the sleeve and weld a piece of steel rod inside and then reinforce the whole tie bar with angle iron.
What do you folks think of this solution?
Even if I buy a new tie-bar,I would still like to strengthen it in some way. does anyone have any suggestions
Thanks
/ Broken tie-rod #2
i routinely make draglinks for my fords. just metal tube / pipe ) with some sort of coupler ont he end, depending on the style and type of tie rod end.
I'd go pipe befroe i scabbed angle iron on.. if only for cosmetic savings.. :)
/ Broken tie-rod #3
Better to break the tie rod than what its connected to. You may want to keep that in mind before you build the worlds strongest tie rod. Good luck.
/ Broken tie-rod #4
Hey, Ken, thats experience speaking isn;'t it? A very good point, sometimes it's engineering, not just saving weight or being cheaper? But I tend to Gorilla weld it back??
2012 Gehl DL11-55 11,000lb. 4x4 Rough Terrain Telehandler (A61572)
2012 Gehl DL11-55...
4022CFL (A59228)
4022CFL (A59228)
Snap-On Gold Medal Tribute to Excellence Limited Edition 3-Bay Tool Box (A63689)
Snap-On Gold Medal...
Round Wooden Table (A64119)
Round Wooden Table...
2009 Honda Pilot AWD SUV (A61574)
2009 Honda Pilot...
2025 GIYI GY-PG72C 72in Dual Cylinder Hydraulic Grapple Bucket Skid Steer Attachment (A61572)
2025 GIYI GY-PG72C...
