JD 425/445/455 Quick hitch question
/ JD 425/445/455 Quick hitch question #1
chevy
East Central, Indiana
Kioti CK3510SE HST, John Deere X739
Will a front JD Quick Hitch from the JD 425/445/455 garden tractors fit a JD X475 garden tractor?
/ JD 425/445/455 Quick hitch question #2
Yes, but you will have to route the hydraulic hoses to the other side of the tractor. It has been a lot of years, but I think? you may need to also get the optional change-over kit from Deere that is just a couple of hose extensions.
Thank you.
/ JD 425/445/455 Quick hitch question #4
I moved a 425/445/455 hitch to my X485 no problem.
Can't go backward with the X485 hitch tho.
I was looking at a hitch from a 455. I have found out that the new style hitch will mount on the tractor with the mower deck mounted. I like that idea for when I need to do a quick job, but I am not sure it is worth the higher cost.
/ JD 425/445/455 Quick hitch question #6
Life is full of choices. ;)
I found a new style front hitch with a blade on craigslist.
I picked it up this morning & I got it mounted on my X475.
/ JD 425/445/455 Quick hitch question #8
Great, good on ya!
/ JD 425/445/455 Quick hitch question #9
I know I am dredging up an old thread here, but what seems to be the going rate these days for a decent blade/hitch combo for the x475? I see prices all over the place on craigslist.
/ JD 425/445/455 Quick hitch question #10
Yep. Prices everywhere, depends on condition largely. I' ve seen $400 to $1500. Anything under $700 in good shape is a good deal, I would think.
EZ-GO SHUTTLE 2X2 TXT GAS GOLF CART (A63276)
EZ-GO SHUTTLE 2X2...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
2009 STERLING LT9500 (INOPERABLE) (A63569)
2009 STERLING...
2009 Ford F-450 Liftmoore 5000 2 Ton Crane Service Truck (A61573)
2009 Ford F-450...
Four (4) Michelin 520/70R38 Mega Bib Floater Tires (A63116)
Four (4) Michelin...
2016 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2016 UTILITY VS2RA...
