JD 425/445/455 Quick hitch question
   / JD 425/445/455 Quick hitch question #1
chevy
Platinum Member
East Central, Indiana
Kioti CK3510SE HST, John Deere X739
Will a front JD Quick Hitch from the JD 425/445/455 garden tractors fit a JD X475 garden tractor?
   / JD 425/445/455 Quick hitch question #2
Yes, but you will have to route the hydraulic hoses to the other side of the tractor. It has been a lot of years, but I think? you may need to also get the optional change-over kit from Deere that is just a couple of hose extensions.
Thank you.
   / JD 425/445/455 Quick hitch question #4
I moved a 425/445/455 hitch to my X485 no problem.
Can't go backward with the X485 hitch tho.
I was looking at a hitch from a 455. I have found out that the new style hitch will mount on the tractor with the mower deck mounted. I like that idea for when I need to do a quick job, but I am not sure it is worth the higher cost.
   / JD 425/445/455 Quick hitch question #6
Life is full of choices. ;)
I found a new style front hitch with a blade on craigslist.
I picked it up this morning & I got it mounted on my X475.
   / JD 425/445/455 Quick hitch question #8
Great, good on ya!
   / JD 425/445/455 Quick hitch question #9
I know I am dredging up an old thread here, but what seems to be the going rate these days for a decent blade/hitch combo for the x475? I see prices all over the place on craigslist.
   / JD 425/445/455 Quick hitch question #10
Yep. Prices everywhere, depends on condition largely. I' ve seen $400 to $1500. Anything under $700 in good shape is a good deal, I would think.
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
UNUSED IRANCH 1R EXCAVATOR RIPPER (A54757)
UNUSED IRANCH 1R...
2 windsor 351 inboard motors w/transmissions shafts rutters and props (A53424)
2 windsor 351...
2022 BOBCAT T770 SKID STEER (A52705)
2022 BOBCAT T770...
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 150...
New Kivel Mini Skidloader Pallet Forks (A50775)
New Kivel Mini...
