John deere 3020 pto problems
/ John deere 3020 pto problems #1
Ohrenberg
Hale, missouri
John Deere 3020
Hi, I am new to farms and tractors in general but I'm doing y best to learn. I have the general operations of my jd 3020 down however the pto is kinda spotty it'll work for a min then just stop working after the tractor hasbeen running awhile. I was trying to hook up the brushhog when engaging the pto it spun real slow barely turning the blades the. Quit working now the pto will spin freely by hand ? Any ideas on what I should do? Any help would be great
/ John deere 3020 pto problems #2
What is the serial number below or above 123,000? Late model 3020's have hyd engaged pto while early models are manually engaged.
Where do I find the serial number? If I remember right there are serial numbers stamped on the ballast on the front of the tractor. Sorry for my lack of knowledge I'm learning as I go and am new to all of this.
/ John deere 3020 pto problems #4
SN tag will be on diff housing just to the right and up from pto shaft. Where are the hyd and 3pt control levers ? on the dash or beside the seat?
The controls are all to the left of the steering wheel 3levers on dash and the lever beside fast for pto
/ John deere 3020 pto problems #6
I forgot to ask which type trans?? Syncro-Range(gear) or Powershift(semi-auto)?
So according to the tag by the pto it's a 3010?
/ John deere 3020 pto problems #10
According to SN your tractor is a '62 3010. On 3010's JD only built Syncro-Range trans. Powershift trans weren't introduced until '65. Since it's a 3010 then the pto is very different. Has the pto stub shaft on the rear that bolts on with 4 bolts been removed or become loose?? Non working pto could be pressure plate fingers worn off or a bad throwout(actually engagement) brg(parts key #32) or worn pressure plate fingers. You can remove inspection plate on the bottom of clutch housing and look inside. Or problem could be farther inside trans(2nd photo) which would be a bent/broken tiny pin(parts key #27). I have seen the stub shaft removed and a penny(1cent coin)inserted in the hole to push a bent pin in enough to engage drive gear when stub shaft is reattached,
Thanks for all your help, I was worried the tractor would have to be split to fix the pto but I'm hopeful now that it wot be as bad as I thought
/ John deere 3020 pto problems #12
The fingers can be replaced through the bottom inspection hole but the throw-out brg can't be replaced without a split.
/ John deere 3020 pto problems #14
Are you inquiring as to how to repair the oil leak??
/ John deere 3020 pto problems #16
drain hyd oil,support drawbar frame,put L/D lever in "D",remove caps on both sides of drawbar frame,drive out shaft,lower drawbar frame,remove seals,inspect shaft & bushings for wear,reassemble in reverse putting necessary shims between drawbar frame & trans case.
