John deere 3020 pto problems
/ John deere 3020 pto problems #1
Ohrenberg
Hale, missouri
John Deere 3020
Hi, I am new to farms and tractors in general but I'm doing y best to learn. I have the general operations of my jd 3020 down however the pto is kinda spotty it'll work for a min then just stop working after the tractor hasbeen running awhile. I was trying to hook up the brushhog when engaging the pto it spun real slow barely turning the blades the. Quit working now the pto will spin freely by hand ? Any ideas on what I should do? Any help would be great
/ John deere 3020 pto problems #2
What is the serial number below or above 123,000? Late model 3020's have hyd engaged pto while early models are manually engaged.
Where do I find the serial number? If I remember right there are serial numbers stamped on the ballast on the front of the tractor. Sorry for my lack of knowledge I'm learning as I go and am new to all of this.
/ John deere 3020 pto problems #4
SN tag will be on diff housing just to the right and up from pto shaft. Where are the hyd and 3pt control levers ? on the dash or beside the seat?
The controls are all to the left of the steering wheel 3levers on dash and the lever beside fast for pto
/ John deere 3020 pto problems #6
I forgot to ask which type trans?? Syncro-Range(gear) or Powershift(semi-auto)?
So according to the tag by the pto it's a 3010?
/ John deere 3020 pto problems #10
According to SN your tractor is a '62 3010. On 3010's JD only built Syncro-Range trans. Powershift trans weren't introduced until '65. Since it's a 3010 then the pto is very different. Has the pto stub shaft on the rear that bolts on with 4 bolts been removed or become loose?? Non working pto could be pressure plate fingers worn off or a bad throwout(actually engagement) brg(parts key #32) or worn pressure plate fingers. You can remove inspection plate on the bottom of clutch housing and look inside. Or problem could be farther inside trans(2nd photo) which would be a bent/broken tiny pin(parts key #27). I have seen the stub shaft removed and a penny(1cent coin)inserted in the hole to push a bent pin in enough to engage drive gear when stub shaft is reattached,
Thanks for all your help, I was worried the tractor would have to be split to fix the pto but I'm hopeful now that it wot be as bad as I thought
/ John deere 3020 pto problems #12
The fingers can be replaced through the bottom inspection hole but the throw-out brg can't be replaced without a split.
/ John deere 3020 pto problems #14
Are you inquiring as to how to repair the oil leak??
/ John deere 3020 pto problems #16
drain hyd oil,support drawbar frame,put L/D lever in "D",remove caps on both sides of drawbar frame,drive out shaft,lower drawbar frame,remove seals,inspect shaft & bushings for wear,reassemble in reverse putting necessary shims between drawbar frame & trans case.
Year: 2018 Make: GMC Model: Terrain Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 116,222 Pla... (A66738)
Year: 2018 Make...
1 PALLET OF JACK & IMPACT GUNS (A66091)
1 PALLET OF JACK &...
Unused 2023 Del Morino CS158M Agricultural Flail Mower Tractor Attachment (A66734)
Unused 2023 Del...
Dixie Chopper (A64557)
2024 CATERPILLAR 255 SKID STEER (A65056)
2024 CATERPILLAR...
2008 FORD F350 CREW CAB STAKE BED TRUCK (A66091)
2008 FORD F350...
