Dirt Moving semi mount 4 bottom plow
/ semi mount 4 bottom plow #1
kelby
mcconnelsville
ford
how much would it cost to replace worn out moldboards on a JD 4 bottom plow?
/ semi mount 4 bottom plow #2
:welcome:
jdparts would be a good place to look. Put the model number in and then find out what the parts availability is and a price.
/ semi mount 4 bottom plow #3
Try shoup parts online also.
i don't have a parts number. i can't make out the serial plate,,, but it has the john deere paint still on..
/ semi mount 4 bottom plow #5
Then you might try taking off the part and looking for a stamped no. that Deere dealer can reference.
Or get the dimensions and try Shoup parts.
/ semi mount 4 bottom plow #6
:welcome:
Plow bottom parts aren't listed in the JD plow parts catalog. Bottom parts are listed in a parts book by themselves named plow bottoms. The part numbers should be stamped on the backside of the parts if they're not worn off.
/ semi mount 4 bottom plow #7
Its impossible for anyone to say what it will cost without knowing the model/plow bottoms. If possible start searching for pictures of JD plows till you find one identical to yours. That will give you a good place to start. Then you can figure out what it will cost. Otherwise, pull off the parts and look for the part numbers on the back side. Then you can look them up.
When you do find out what plow you have or what part numbers you have make sure you write it down somewhere. I like to write the model number in permanent marker on the frame somewhere.
/ semi mount 4 bottom plow #8
But because this thread is titled semi-mount 4 bottom narrows the plow bottom part #s drastically. The points are probably throw-away type points.
think its a 145,, compared to others... frame and where cylinder hooks up
/ semi mount 4 bottom plow #10
But without a model number or at least a picture its still impossible to give an actual answer as to cost.
/ semi mount 4 bottom plow #11
Probably either High Speed or New Universal bottoms. But still lacking sufficient info to provide a meaningful answer.
/ semi mount 4 bottom plow #12
Model of plow will not give plow bottom parts #s. One needs to know old part numbers on parts required or type of bottoms. When I stated semi-intergal plow narrowed the parts down is because that type plow will have the newer throwaway points not the ones that were blacksmith sharpened.
2012 Can-Am Spyder Motorcycle (A61569)
2012 Can-Am Spyder...
378908 (A61166)
378908 (A61166)
22" PIN-ON EXCAVATOR BUCKET W/PINS (A60429)
22" PIN-ON...
UNUSED JCT 72" HYD BRUSH CUTTER (A62131)
UNUSED JCT 72" HYD...
TAKEUCHI-VIRNIG TRRG72 - 72" HYD ROOT RAKE GRAPPLE (A62129)
TAKEUCHI-VIRNIG...
2020 Kubota RTV X1140 (A61166)
2020 Kubota RTV...
