homemade tracked vehicle.
/ homemade tracked vehicle. #1
thatrandomguy
Toro Wheel horse 12-32xl
Hi al.
im thinking about building a tracked vehicle.
it will be made out of scrap and lawnmower parts.
i am thinking about just using a lawnmower frame,engine,transmission and tires.
the engine is problably going to be a 12 horse or somehing, the transmission like a 5 speed and a C frame(problably from a toro)
for tracks i wil bent some pieces of metal and weld them on chains.
kind of like this: tracks.jpg
the only thing that kind of concerns me is the steering.
because the lawnmower transmisson has an open differential im planning on putting brakes on both tracks so i can brake them independently.
but i think the problem i am going to run into is that it wil only power one tracks at the time.
im not sure what speed im going with, problably a 1 to 1 ratio.
im going to afroad with it and climb hills and such so it needs power, but i also want to have a nice topspeed, so im thinking about 10 to 15 mph and then in low gear i will have plenty of power.
it's just going to be a cheap, fun build.
Sander Albers.
/ homemade tracked vehicle. #2
That sounds really cool. Cant wait to see pics.
Are you talking about single track power while braking?
/ homemade tracked vehicle. #3
If you do individual brakes for steering, then you will have to do some sort of individual clutching as well. One axle locked up with the other trying to power you around is gonna have bad results. What about a pair of hydraulic drives?
/ homemade tracked vehicle. #4
or some centrifugal clutches, since its only 12hp -/plus, even though hydraulics would mean much more power for your 12hp or so
/ homemade tracked vehicle. #5
If its an open differential, with twin braking steerage, I don't see why he would need twin clutches. He would find that on a hard turn where one side is almost stopped, that the power to the opposite side would be greatly reduced while it was trying to spin at double the previous speed...
/ homemade tracked vehicle. #6
hmmm..never really thought about the double speed issue...ok, bad idea
/ homemade tracked vehicle. #8
The Struck Magnatrac M-1800 uses a Peerless 4 speed transmission for the rear end, and uses brakes on each track to turn.
The clutch only disengages the engine from the transmission.
/ homemade tracked vehicle. #12
this may be a little closer to what hes after
[ame=http://www.youtube.com/watch?v=GRPHT9wm5cI&feature=related]Personal Tracked Vehicle - YouTube[/ame]
Maybe, you can drop one of these guys a line nd they will throw some insight on how they rigged theirs up.
LOAD OUT AND SHIPPING (A65579)
LOAD OUT AND...
Case IH 800 (A64127)
2018 JOHN DEERE 844K-III AG HANDLER WHEEL LOADER (A65053)
2018 JOHN DEERE...
2005 Peterbilt 379 Extended Day Cab (A62613)
2005 Peterbilt 379...
2019 Toyota Mirai Sedan (A61574)
2019 Toyota Mirai...
2012 John Deere 135D Excavator (A65579)
2012 John Deere...
