John Deere In Water
/ John Deere In Water #1
BroBro
Member
West Virginia
John Deere 3203
Just wondering if anyone has ever operated a JD in water for a extended length of time .
I have a JD 3203 with HYD. Tran's. and FEL and I am getting ready to load some creek gravel for my Rd. so I will be in water over the front wheel's for a while.
Has anyone had a problem with front end leak's ( Seal's) or tran's. problem's after operateing in water ?
Thank's
/ John Deere In Water #2
The front axle has a vent so that would be a concern. Might see if you can put an extension on it.
MarkV
/ John Deere In Water #3
I doubt you'd have any issue's but I would suggest keeping things greased up and when done(I assume it's 4wd) change the front axle oil.
/ John Deere In Water #4
The fan stops turning at one point !
[ame=http://www.youtube.com/watch?v=WIfJttXGMKg&feature=related]john deere and two case headers swimming - YouTube[/ame]
/ John Deere In Water #7
Thank's
Good luck when the DNR finds out you are altering a water, ruining fish spawning grounds and pitting gravel without a permit and not paying taxes.
/ John Deere In Water #8
Thank's
This would be a good question to ask one of your dealer's service technicians.
If you're going to be in water over the top of your front tires, the bottom of the engine (and the exhaust outlet) would also be underwater.
As MarkV wrote, the front axle has a vent...but there may well be other openings (vents or ports of some sort) that may be underwater.
The axle seals are to keep rain water out...mud too. I'm not convinced they would be sufficient for being totally submerged.
I'd also be very concerned about that exhaust being underwater...
At minimum, fresh grease in all the zerks berfore and after the work, each day (if the project is going to be more then one day).
/ John Deere In Water #10
Do you have a vertical exhaust? In which case I'd be very worried should it stall or get stuck, then you'll have water rushing in and would be very fun getting it out. Be cautions and you should be ok though.
/ John Deere In Water #12
Used to loosen the mount bracket on the generator (now alternators) and let the belt just slip when it was gonna be deep..!! :laughing:
AKfish
/ John Deere In Water #13
I remember a time not that long ago when DNR came out to our small bridge construction job site and saw dozer tracks going down the bank to the water edge, and then on the other side back up the bank. Although the contractor did not get caught red handed, he did get fined and most importantly the job site shut down until he could convince them he would be a good boy from then on.:confused2:
Roy your right I will contact my dealer.
Sound's like I may have more trouble with the DNR than the tractor.
Think I might just buy some stone.
Don't want to kill any snail darter's !!!! Ha, Ha, Ha, :laughing:
/ John Deere In Water #15
Sound's like I may have more trouble with the DNR than the tractor. Think I might just buy some stone.
That's no joke. The fines from the DNR for disturbing a waterway can be quite steep. Buying crushed stone would be the best and safest option.
/ John Deere In Water #16
Yup they don't play nice and all it takes is a neighbor or someone walking by to call. Someone around here cut some trees within the buffer zone of a lake and they had some crazy rate they charged him per inch of stumpage cut, it ended up being 10's of thousands! I'm way more careful around my waterfront areas now after hearing that!
/ John Deere In Water #17
If you are just pulling a little gravel out of a smaller creek once in a while, I wouldn't worry about it, but thats not the lawyer side in me talking. The lawyer side of me would say ask first.
/ John Deere In Water #18
We had a farmer neighbor just come in and fill in a little swampy area and dig another ditch. To increase his crop area..He is still paying the lawyers and FINES?
2020 Peterbilt PB337 S/A Dump Truck (A61573)
2020 Peterbilt...
2025 DE14 Tophat Dump Trailer (A64047)
2025 DE14 Tophat...
16ft Cattle Panels (A64047)
16ft Cattle Panels...
2017 Dodge Ram Promaster 2500 Van (A63116)
2017 Dodge Ram...
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
SET OF (3) CHEMICAL HOSE REELS (A63569)
SET OF (3)...
