John Deere In Water
   / John Deere In Water #1
BroBro
West Virginia
John Deere 3203
Just wondering if anyone has ever operated a JD in water for a extended length of time .
I have a JD 3203 with HYD. Tran's. and FEL and I am getting ready to load some creek gravel for my Rd. so I will be in water over the front wheel's for a while.
Has anyone had a problem with front end leak's ( Seal's) or tran's. problem's after operateing in water ?
Thank's
   / John Deere In Water #2
The front axle has a vent so that would be a concern. Might see if you can put an extension on it.
MarkV
   / John Deere In Water #3
I doubt you'd have any issue's but I would suggest keeping things greased up and when done(I assume it's 4wd) change the front axle oil.
   / John Deere In Water #4
The fan stops turning at one point !
[ame=http://www.youtube.com/watch?v=WIfJttXGMKg&feature=related]john deere and two case headers swimming - YouTube[/ame]
   / John Deere In Water #7
Thank's
Good luck when the DNR finds out you are altering a water, ruining fish spawning grounds and pitting gravel without a permit and not paying taxes.
   / John Deere In Water #8
Thank's
This would be a good question to ask one of your dealer's service technicians.
If you're going to be in water over the top of your front tires, the bottom of the engine (and the exhaust outlet) would also be underwater.
As MarkV wrote, the front axle has a vent...but there may well be other openings (vents or ports of some sort) that may be underwater.
The axle seals are to keep rain water out...mud too. I'm not convinced they would be sufficient for being totally submerged.
I'd also be very concerned about that exhaust being underwater...
At minimum, fresh grease in all the zerks berfore and after the work, each day (if the project is going to be more then one day).
   / John Deere In Water #10
Do you have a vertical exhaust? In which case I'd be very worried should it stall or get stuck, then you'll have water rushing in and would be very fun getting it out. Be cautions and you should be ok though.
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A51692)
2016 Ford F-550...
2022 CATERPILLAR 980 WHEEL LOADER (A52705)
2022 CATERPILLAR...
2019 KUBOTA SVL95-2S SKID STEER (A52705)
2019 KUBOTA...
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A54811)
Generac Yanmar...
