Making drain holes in old tires
   / Making drain holes in old tires #1
BeezFun
IL
Kubota B2710
I use old tires to hold down tarps on my manure pile. They fill up with water, can't get it out. I tried drilling holes in the tire, the rubber just closes up. Same thing when I used a .22 to shoot a hole. Any ideas on how to make a hole big enough that won't clog up, like at least 1/4" in diameter? I was thinking maybe heat up something with a torch and burn a hole, not sure if the steel belting will stop that.
   / Making drain holes in old tires #2
Metal cutting hole saw and a portable drill. :thumbsup:
   / Making drain holes in old tires #4
Yep,
I hang an old tire on the brick frame of my pallet forks as a bumper, it has about half dozen 1 inch or so holes in it that I drilled with a hole saw, probably 2 inches between centers.
If you have a SHARP hole saw it will zip right through steel belts, just be careful handling the cut out plugs.
After a year or so the steel ends rusted to dust, so cleaning out leaves isn't a hazard.
   / Making drain holes in old tires #6
We've done it the same way as bigfoot62 says for years. Drill them in the crown of the sidewall. Works best. May your pile be big and rich
Why didn't I think of that. I actually moved my hole saws to get at the drill I tried to use.
Tnx to all for ideas and entertainment
   / Making drain holes in old tires #9
I've used a log splitter.
2024 Chevrolet Silverado Pickup Truck Bed (A49461)
2024 Chevrolet...
2014 Volkswagen Passat Sedan (A50324)
2014 Volkswagen...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A51219)
2018 INTERNATIONAL...
PALLET OF FUSION EQUIPMENT (A50854)
PALLET OF FUSION...
2020 KUBOTA SSV75 WHEELED SKID STEER (A51242)
2020 KUBOTA SSV75...
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A51039)
3-Point Hitch Root...
