Time to buy tires.
/ Time to buy tires. #1
whistlepig
Elite Member
Preble County, Ohio
Kubota B7800 with FEL
My OEM Bridgestone Duellers on my 2007 Chevy Z-71 have 96,000 miles on them. Even at that they have more than 1/16" tread left. I am pretty amazed that I could get this kind of life out of any tire. But it's tire time. For value and wear I would consider these Bridgestone Duellers second to none. The Bridgestone Duellers that came on my truck are horrible in ice and snow. By far the worst tire I have ever owned for ice and snow use. I am considering Michilen LTX M/S2 tires. Not cheap. But I live in the middle of nowhere and come home from work at 3:30am. Getting stuck is more of a priority than tire life and price for the way I use my tires.
/ Time to buy tires. #2
I would keep looking. Replaced a set of LTX with Toyo open countty. The LTX would load up and not clean off. Other than the long mileage that they lasted, not worth a hoot.
Also, get LT tires, well worth it. They should not be putting Passenger tires on trucks.
/ Time to buy tires. #3
So what are we doing here?
Are you asking for recomendations?
I like the Goodrich tires... they seem to last a long time. I replaced the original tires with this tire, because the original OEM tire lasted so long.(Goodrich)
The only thing I know about snow is what I've seen in the pictures here on TBN...... Looks like nasty stuff.
Anyway, should you ever decide to move south........
The temps here in the summer are well........ 'Africa hot'.
Hope this helps
Hope this helps
Since 1979 I have owned five 4x4 pickup trucks. I have tried a tire brand or two. I will have to admit that the one set of BF Goodrich KO's that I have owned where the absolute best tire that I have used in ice and/or snow. But I had the KO's a long time ago. The wear for sure wasn't 96,000 miles on them. Maybe 65,000 as I remember. So maybe a little comprise that I am looking for. Some good tire life and really good traction. I am willing to pay a little extra for that.
/ Time to buy tires. #5
I finally decided to run a set of Toyos and was hooked. They are tough, easy to balance and run a long way. The best brand I have ever run in a lot of years with heavy duty pickups. I spend a lot of time in the mountains, in all seasons and towing some of the time.
My only complaint is the Toyo AT tires don't have as much traction in the snow as BFG all terrain TAs do. But the quality and strength of the tire more than makes up for it. The Toyos are far better quality and much tougher.
/ Time to buy tires. #6
How many times did you get stuck in 96k miles?
96k miles I would replace them with the same tire? The generals on my 07 GMC dually have 40 k and will never see 60 k .
/ Time to buy tires. #7
How about cooper tire there only made a 100 or so miles from you location
/ Time to buy tires. #8
If Yokohama has a tire in your size and class I would go there in a heartbeat. For a 1/2 ton pickup(135K miles) I am on my second set and couldn't be happier with the quality and the price of admission was sweet.....Gary
Stuck twice in 96,000 miles. Some close calls where the truck wanted to swap ends at 55 MPH but I do still have enough reaction time left in these old bones to have saved it. I am kind of considering the Bridgestone Duellers again. It's a 68 mile round trip to work and back every day so I can rack up some miles in a year. Still thinking about it. 96,000 miles out of a set of tires is maybe something that isn't broke and doesn't need fixing.
/ Time to buy tires. #10
You got me thinking about duellers.....96 k is real good. I just sold my truck with goodyear duratracs and I only got 40k and they were pretty much worn out. They were awesome for snow and mud and ok on shear ice. fairly quiet tire considering the aggressive tread.
/ Time to buy tires. #11
I guess its all how you use your truck. My neighbors truck came with them and he got 35,000 miles out of them. Same out of Goodyears, and Coopers.
I have never owned them but have never got more then 40,000 miles on the 15 plus trucks. Did get 73,000 miles on a suv.
Chris
Chris
I really don't know what caused the 96,000 miles. I do rotate and balance but haven't been all that religious about that. Mostly highway miles to and fro to work. I am not a user of brakes on my truck. I stay well back from what's in front of me. Let those that want to cut me off have their way. Saves them that extra .00001 second at the next stoplight you know. I don't pull trailers that much anymore. Maybe once or twice a year.
/ Time to buy tires. #13
Mastercraft C/T's are a good tire. They're in between the AT and the mud tire. Used to be reasonably priced but everything is going up like crazy these days.
/ Time to buy tires. #14
On our 2009 GMC; original tires were Goodyear Eagle LS-2 - very poor mud/snow traction.
I wanted Bridgestone Dueler A/T Revos that I had on my last '02 Silverado - 2 thumbs up. But they were unavailable in September (when I had to get tires for our snowy winter in NH - except this year; only plowed 4 events).
So I now have Firestone Destination AT tires. They have good traction, but don't track as well as the Bridgestones on the interstate at 73 mph.
The local tire chain rep (Tire Warehouse) demonstrated on samples that tires don't extend the sipes all the way down to the base. Therefore, after the tread wears down to the (shallow) sipe, the tire is dead. Be sure to look at the sipe depth.
/ Time to buy tires. #15
I put a set of Toyo open country (285-70-17)on my 2500 about a year ago . I like them. Bought them from an online tire co. I mounted & balanced them. Didn't have to use much weight to get them balanced.
/ Time to buy tires. #16
Go with the michilen tire.Best truck tire on the market IMHO.I have run BF goodrich,michieln,coopers and the Bridgestones.coobie
/ Time to buy tires. #17
Chris
everyone i know is in pretty much the same boat. i think between everyone i talk to nearly every common make of tire and tread has been tried, and 30k-40k is about it. of course, most everyone i know is running a 3/4 ton and a few are single wheel 1 tons, but they're all heavy and get worked to varying degrees. murphy's law always kicks in too - you get down to where you still have usable tread left, but it's really not enough to chance over the winter months, so you waste 5k miles rather than take a chance.
my first ever new truck was a 93 gmc 1500 shortbed that came with wrangler td 265/75/16's and i had close to 50k when i lost the sidewall on one. that's the best i ever got out of a fairly light truck. a couple years ago i saw you could still get those for around $100 each. i always liked the tires, especially for that price.
/ Time to buy tires. #18
Whoever posted about the costs of new tires is not S***ing there!!
While having a 3 axle alignment done on my semi this morning , priced 4 Toyo A/T's , 265 x 17 with mount and balance = $ 1147+ some change .:confused2:
Currently have a similar brand but a H/T type on our Dodge while our old Ford has a M/T tread type . Did not want to go that aggressive so settled on the A/T tread .
May be cheaper just to trade truck in and get a new one every couple of years instead of buying tires .:cool:
Fred H.
