Extension Cord for welder
/ Extension Cord for welder #1
Sublifer
Gold Member
LS 4047
Okay, looks like it is going to cost an arm and a leg to run a new outlet for the welder. As a workaround until I one day get a real workshop I am thinking of running it off my oven's outlet. It is on a 50amp break and is just inside my garage door. (10 feet maybe). So I figure I want 50' cable to be able to get outside my garage when needed but I am not sure on where or how to get the cable.
Hardware store people are stupid about welders so if you tell them 50 amp they will say 6 gauge. $200 just for a 125' length ($180 for 75' and there is no 50')
RV cords can have the 14-50 plug already but for some stupid reason often have a 20amp twist lock at the receptacle end. Some of these at 50' can be had for $100-$130.
Anybody have a good recommendation? :confused:
/ Extension Cord for welder #2
. . . I am not sure on where or how to get the cable.
Any electrical supply should have the cable, and will cut it to any length you want. They will also have the plug ends.
It does require a 6 gauge, and if you go over 100', you will need a 4.
/ Extension Cord for welder #3
Nothing will ruin a good welder's performance faster than using a marginal extension cord unless it is welding blindfolded with your feet after guzzling a 6pak.
Pat
/ Extension Cord for welder #5
I got the photographer drunk and stole the negs and burned them. Didn't happen. I maintain plausible deniability. I have witnesses that can place me a long way from wherever anyone says this happened.
/ Extension Cord for welder #6
I've mentioned this before, but I've found nice cable at my friendly neighborhood metal scrappers. Check 'em out. They might even call you if you leave a card and promise a small reward.
/ Extension Cord for welder #9
The cord on my welder is a 12/3. I have really long leads so I dont need an extension. But my question is, why would you need 6 ga wire for an extension cord when the welder has a 12 ga pigtail and the outlet is wired up with 10 ga from the breaker? Im not trying to be a smarty pants, I just want to understand it.
/ Extension Cord for welder #11
Because voltage drop is a function of both wire size and length. the cord on your welder is pretty short (they saved money in gauge and length) A long extension cord of 12 or even 10 gaq is a bad idea.
Pat
/ Extension Cord for welder #12
That helps, thanks.
/ Extension Cord for welder #13
I bought cable at Lowes. They sell 6 gauge cable by the foot as well as the plug and receptacle. I don't think it shows up on their website but it's on the 'wall of wire' that rotates. I think it was about $1.60 a foot.
I'm about to head to the hardware store so I'll take a look.
/ Extension Cord for welder #15
That's a legit question.
The OP stated that he needed 50 amps. Yours is probably a 30 amp, if it's got a 10 ga supply wire.
Okay, so 50 amps would be nice but in actuality I will rarely if ever use more than 2/3s the power on this welder.
Do you think 8 gauge would be okay? Seems very rare to find a welding extension, aside from custom made, that is bigger than 8 gauge...
/ Extension Cord for welder #17
So far I haven't seen ANY indication that you will be drawing anywhere near 50 amps, you indicated that the outlet in your garage is on a 50 amp breaker...
Well ...so what ?
If you have a 90 amp wire feed flux core HF "welder" or whatever you have, look up the input current spec and take things from there.
You can probably save a LOT if you just size the cord to the current you will actually DRAW.
/ Extension Cord for welder #18
8 ga is fine. Just put in a 40 amp breaker. You never want your breaker to have greater capacity than the cable. (fire hazard)
/ Extension Cord for welder #19
The local electrical supply houses wanted over $2 a foot for 8 guage wire, and almost $60 for the male and female plugs. After exploring my options, I wound up buying a 50 foot Yellowjacket 10/3 extension cord (after asking lots of questions and reading lots of posts on some welding forums) for $80, and I found Fourney 50 amp male and female plugs at Ace Hardware, for about $30 total. I have been using it for about 6 months now, and it has worked great with my Hobart 190 amp mig welder.
Northern Tools sells a 50 amp, 25 foot welding extension cord for $99.
Century Wire and Cable Right Angle Welding Extension Cord with Progrip Safety Handle — 25Ft., 50 Amp, Model# D13308025 | Welding Accessories | Northern Tool + Equipment
/ Extension Cord for welder #20
Pat
It's also duty cycle. If the duty cycle is low it will allow time for the wire to cool down.
2027 . 500k BTU Wellhead  Heaters (A67714)
2027 . 500k BTU...
2014 CHEVROLET CAPRICE CAR (A66091)
2014 CHEVROLET...
1024 (A63111)
1024 (A63111)
2012 Mercedes-Benz GL 450 AWD SUV (A66738)
2012 Mercedes-Benz...
100 GALLON FUEL TANK/ FUEL NOZZLE (A68842)
100 GALLON FUEL...
2022 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2022 FREIGHTLINER...
