masssey 130 prestone leak
/ masssey 130 prestone leak #1
jdhatt
liverpool N.S.
massey 130
i got a 1969 massey 130 i had the head off and put new head gasket in it thinking that was the problem but it never fixed it its getting prestone in the oil it will drain the rad in about 30 min of running anyone have any ideas would really like the help
/ masssey 130 prestone leak #2
does the tractor have wet sleeves if so the oring on the bottom of one is leaking and it time for a overhaul
are the piston sleeves pressed in?
are they just normal o rings sorry im just new to this tractor use it for on my drive way and hauling alittle wood. so you can get them out without messing them up ?
new with this tractor stuff does anyone know if you can take the base pan off the 130 4 cycle perkins without hauling the whole motor
/ masssey 130 prestone leak #7
The head on those engines are well know for cracking between the valves. Did you check close for cracks? My next door neighbor has one and I know he's had the head off it 4 times. Next time I talk to him I'll ask for some details.
You can go over to yesterdays tractors web site and they have a MF forum that may give you answers much faster than here also.
