Land Pride grading scraper
/ Land Pride grading scraper #241
jenkinsph said:
If your intention is to use it for gravel driveways I would set it 1" below the skids.
Let me know if this is clear enough.
Perfect!!!!!! Wow!!!!! That's a very good I idea! Well then I'm building it, and next week sometime I could build the adjustment then instead of wood I got 3in wide x 1 inch think solid bar I could easily bolt that on, and many different thicknesses, I can drill holes and tap into the solid bar! and laying new stone in the correct thickness just get thicker bar and bolt that on!!! Thank you!!!! Can't wait to get started tomorrow! Christmas morning
/ Land Pride grading scraper #242
You can use the thick bar but it would be alot more cumbersome to work with. That is why I suggested using the wood pieces, much lighter to work with and a lot less money. the wood shims could be stored in a pvc pipe with a screw in cap mounted to the rear cross tubing.
/ Land Pride grading scraper #243
Pic's of the one I built last year . 7' wide x 7' + long pulled behind a New Holland TC 30 HST with loader . Driveway is 800' + feet with at least 1/3 being a grade of 7 to 8 % . Crushed Shale , ( not 3/4 minus river rock but actual crushed shale ) is our road base . Blades are just 1/2" x 6" flat stock that I beveled on the lead edge with plasma cutter . They are attached to 3/8" 3"x3" angle that is welded 1/2" above the bottom of side skids . Slots in blades allow for 0" to 3" cutting , but 1/4" to 1/2" is really all I needed . Pictures were taken before I added additional cross braces , beveling blades , and something else I did (???? ) , But dang thing works and tractor pulls it great .
Fred H.
/ Land Pride grading scraper #244
well here's today's build progress, went and borrowed a plasma cutter and wow does that do a heck of a good job. going to go hunt down some cutting edges tomorrow, a local welding shop is big into handling plows and he always has a little of everything. but im just going to do a happy medium and go half an inch below the skids and later down the road build something else for it. but in really dreading drilling that 1/2 angle iron for the bolts. i just got the two pieces of tubing welded on before i ran out of gas for the welder :eek: should have looked before i started. should get more done tomorrow. :)
/ Land Pride grading scraper #245
If you borrowed the plasma cutter once , try again . Rather than drilling , plasma torch will blow threw your holes in just a few minutes . I did all my holes and slots in blades with-out pre-drilling . Just hold torch at a slight angle pointed away from you and squeeze the trigger . Took less than 2 seconds to blow threw 1/2" plate . Sure hole will not be perfectly round , but mine are pretty close for farm implements .
Fred H.
/ Land Pride grading scraper #246
When I drilled the holes I used a small pilot cnc bit 1/8" then ran a 5/8" bimetal holesaw. Works well enough and the advantage of using a hole saw is that it doesn't have to remove all the metal, having the slug or core makes it easier to drill. To assure proper fit and alignment I first clamped the grader blades in place and then used the graderblade holes as my giuides. Took about 1 1/2 hours to drill all 16 holes in the 5/8" flatbar. Just keep the bits cool with cutting oil and the holesaw will work fine.
I just checked the holes in my new grader blade and there is just enough play I will try the holesaw without a pilot bit, thinking that will save some time.
/ Land Pride grading scraper #247
Looks like you are off to a good start.:thumbsup:
If you are not planning on rolling the ends as I did then recognize that you will need to put stiffeners in from flange to flange. I rolled the ends of my skids because that makes them ride over the ground better and also makes the flanges stiff.
/ Land Pride grading scraper #248
Since I haven't welded the angle iron on yet I was thinking of using the drill press, once I mark up the holes for the cutting edge. I got C channel to build up the ends and then roll it out of 1/4 steel and make it look like yours.
/ Land Pride grading scraper #249
I have a 1hp drill press I was going to use but didn't have anyone to help tail it or help hold it. So I opted for the 1/2" corded drill. Make sure you check the fit for the plow bolts when setting this up, save enough room to get a socket on the insde.
Hope to find some deals on shorts/drops tomorrow at the steel place. I am hoping to find some rectangular tubing suitable for skids. This new landplane I hope to eliminate most of the horizontal surfaces that holds the gravel, it can be a pain to have it fall off on the roads or lawns.
/ Land Pride grading scraper #250
Well I had some success at the steel yard.:)
Found a piece of 2x8x3/16" boxtubing for the skids, a piece of 4x4x3/8" for the blade mounting and a 6x36x1/2" flatbar for the hitch parts. Buying from the drop pile saved a few bucks as I didn't have to buy these full length.
Steel bar and angle was running $ .56/lb and the boxtubing was $8.38/ft.
So with the boxtubing in my rack and assorted other stuff I think I have everything but time to complete this project.:)
/ Land Pride grading scraper #251
Looks like you struck out pretty good jenkinsph! I did get some more done on my landplane today, had to do parts errands today so didn't have time to stop to get a couple plow edges. also have to get a new 7/8 drill bit as I broke one in about 10 seconds. Should have it hooked up to the tractor tomorrow, then just have to make the rounded skids, finish the blades holes and weld on the blade support! The last picture is how I cut the upright for the toplink to keep it from breaking the weld, but it's all taking shape now!
/ Land Pride grading scraper #252
Looks good:thumbsup: Are you going to set the blades straight or angled.
Also do you see using it primarily for driveway work or land leveling?
/ Land Pride grading scraper #253
Thank you! I can't wait to see your "mini" landplane, I am setting them straight. In the picture there are just setting in it and won't be at that angle. It will be mostly for driveways and irrigation lanes but also for the big parking areas that are uneven and potholed. On occasion it will be used for smoothing and finishing new yards, also we do new orchards, plant grass, and trees. So this will be very interesting on how it works this summer.
/ Land Pride grading scraper #254
It's really neat following you guys and your projects, makes me want to build something, too, and get in some welding practice.
If someone had told me two years ago I'd be drooling over a pile of steel, I'd have thought they were nuts. Not any more!:laughing:
/ Land Pride grading scraper #255
stopped at the plow dealer today he only had 1 cutting edge so i got that (which when i got home i cant use it), and then he asked how about some 3/8 hardened steel. so i got that to 3/8 x 3 x 64 1/2. perfect then got some 1/4 x 4 x 64 1/2 hardened steel. also got 20 plow bolts and nuts. then he said take it! no charge. its scrap anyway. all he said was to just keep buying snow plows from him! so i'm pretty happy :D .Now all i got welded up today was the hitch, was welding the top link on didn't realize one of the flat pieces got welded crooked but hey it works, going to pick up actual pins tomorrow (used bolts today). All i have in this right now is only a whopping $15 :thumbsup: as for the blades im going to to put the 3/8 on front and the 1/4 on back with straight blades and 1/2 deep! should have this working this weekend and with some better pictures.
/ Land Pride grading scraper #256
I got it finished and I can't believe how well this works. Been using it all day on bad potholed lanes. Why didn't I have a landplane sooner, for real hard packed I run it a couple extra times and turns out fine! I'll have pictures up later
/ Land Pride grading scraper #257
So how did you finish off the ends...and...yes we need pics! :D
/ Land Pride grading scraper #258
Here's some pictures, I was using it on some lanes as the ruts were very bad and it smoothed out very good. But I'm going to look for a landscape rake as the rocks are pretty good size that the landplane is bringing up. hopefully CL will bring out something good.
/ Land Pride grading scraper #259
If you think it works good now.... Put 6 or 8 scarifiers in the front. It makes a enormous difference. You can rip out the potholes and not just fill them.
/ Land Pride grading scraper #260
Catdozer,
What I do when I bring rocks up such as yours is carry them as far as possible then scoop them up with the fel to remove. Then run the plane again. I don't necessarily try to dig up the large rock beneath a drive if I can avoid it, usually I would smooth the base course above the rocks. While I agree with ripping out the potholes and a boxblade can do that if you have one you might consider a heavy home made roller build instead of a landscape rake.
Keep up the good work,:thumbsup::)
I am going to try to build the mini plane later this week and will post pics.
2004 Caterpillar 315C Hydraulic Excavator (A64194)
2004 Caterpillar...
2012 HINO 268 4X2 S/A BOX TRUCK (A59914)
2012 HINO 268 4X2...
2006 Ford Freestyle (A64557)
2006 Ford...
Copper Horse Weathervane (A65583)
Copper Horse...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
1993 International 4900 Utility Flatbed Truck (A64194)
1993 International...
