HomeMade Quick Hitch hooks
/ HomeMade Quick Hitch hooks #1
LD1
Epic Contributor
Central Ohio
Kubota MX5100
Thought I'd make me some quick hitch hooks like the carter EZ-hitch ones:thumbsup: Seems every one likes them that has them. And my implements have just gotten too heave for me to want to wrestle around. A 700lb blade and an 1050lb bushhog arent fun to hook up.
Here is Where I am currently. Had a peice of 1" x 4" x 12" steel. I have got the slots milled currently.:thumbsup:
Back to work on them:confused2:
More pics as we go.
Got the holes drilled, and rough cut. Just need to do the beveling
Finished product. Now all I need are some 3/16 cotter keys or 3/16 lynch pins. I havent decided yet:confused2:
/ HomeMade Quick Hitch hooks #4
LD1,
Great job!!!:thumbsup:... They look nice!.. Post some pictures when you get them mounted!
Thanks for sharing!:)
/ HomeMade Quick Hitch hooks #5
Nice workmanship. I am not familar with that type of quick hitch. How do they fasten to the lift arms.
Bill
LD1,
It will probabally be a couple of weeks before I get them mounted. And then who knows how I may have to modify the blade since it is a cat II with pins turned in.
I am working on the washers now and will post some pics when I get them done.
Bill
They get welded on-top of the lift arm, just above the lower-link.
As promised. Heres my take on the washer things to keep the implement on.
/ HomeMade Quick Hitch hooks #9
The washers look nice too!!!:thumbsup:
I didn't understand how they would fasten to the lift arms either... But I do now!:)
I think that's a great idea!!!... Very simple and they should work great!
Again, Nice job!!!
/ HomeMade Quick Hitch hooks #10
I dig the washers. I just bought a Pat's Easy Change and it came with 3 sets of their washers, but I like yours better. Guess it's off to the shop to go make some. :thumbsup:
Again, Nice job!!!
Here is a linc to Car Doc's thread where he bought the "real" ez-hitch from carter. It shows how they get installed. http://www.tractorbynet.com/forums/yanmar/224495-weld-quick-hitch-hooks.html
Yea, I thought I'd put my own twist on them. Instead of just the bent washer, or smaller washer welded to big one, I thought this would help keep the wasker from flopping around as much and doesnt look as tacky.
Thanks for all the compliments everyone:)
Well...I got around to installing them today.
The welder was at dads and I didt want to cart the tractor over there so that is why I said it would be a few weeks earlier. BUT, I just took the lower arms off and ran over there.
They work pretty good:thumbsup:
/ HomeMade Quick Hitch hooks #15
Nice lookin' job!!:thumbsup:... I really like those because they stay on the lower arms all the time!!
Thanks for sharing!!:)
/ HomeMade Quick Hitch hooks #16
Nice work, and they look good too! That should help things hook up a lot easier.
That's very cool. Always on the arm, but out of the way in case you need to use the original mount holes. Very slick design. Thanks for sharing.
Thanks for the complement, but I must confess, it is not my design. It is made by carter and sons tool and die. I just copied the idea the best I could.
/ HomeMade Quick Hitch hooks #20
